Ivan 17680 Posted December 20, 2015 Mislim da je vec bilo, ali pisite slobodno i ovde kontakte, ako bude bilo zainteresovanih forumasa. Quote Share this post Link to post Share on other sites
danilov 0 Posted December 27, 2015 Može li broj i adresa od majstor Ivana sa Dedinja? Quote Share this post Link to post Share on other sites
amladenbk 1 Posted December 28, 2015 (edited) Kolega,Krupanjska ulica na Dedinju.Telefon je:064 212 83 15Pozdrav, Edited February 3, 2016 by Woodoo Quote Share this post Link to post Share on other sites
kroki23 3 Posted December 28, 2015 I od mene sve pohvale za Ivana, resio mi problem sa strujom na puntu, posle par "majstora". Pregledao mi kompletan auto i rekao sta je jos za zamenu. Dobio gratis zamenu gume na zadnjem brisacu Quote Share this post Link to post Share on other sites
amladenbk 1 Posted December 29, 2015 vajdica .... Quote Share this post Link to post Share on other sites
Ivan 17680 Posted December 29, 2015 Eto, smesan gest (100 kinti je gumica od 60-70cm, moze da izvuce i za 2 zadnja brisaca ), a znaci za musteriju. Quote Share this post Link to post Share on other sites
amladenbk 1 Posted December 29, 2015 jeste .... kupio te je za sva vremena .... Quote Share this post Link to post Share on other sites
Baya 0 Posted January 13, 2016 Vidim da svi nahvaliste Ivana sada, pa me interesuje da li ima još neko iskustva sa njim i da li je on majstor koji je radio kod Gorana na Altini, pa sada sam radi? Hvala... Quote Share this post Link to post Share on other sites
underground79 19 Posted January 13, 2016 Jeste.. Taj Quote Share this post Link to post Share on other sites
alexpapi 0 Posted January 13, 2016 Bgautomoto u vodovodskoj . Veoma korektni i profesionalni. Resili problem za koji 5 majstora rekli da nema spasa Quote Share this post Link to post Share on other sites
amladenbk 1 Posted January 13, 2016 (edited) koji problem ... Edited January 14, 2016 by Woodoo ne citiraj upis iznad Quote Share this post Link to post Share on other sites
slashnp 0 Posted January 19, 2016 Stojanov Novi sad Punto classic, 1.2 Početak septembra, km sat na nekih 99.000 km, odvežen na servis zbog provere stanja pred put (grčka, cca 2k km). Sve u redu, nema nikakvih problema. Početak oktobra (vratili se iz grčke pre 5 dana) opet vozim auto na isto mesto iz apsurdnog razloga. Žena, koja ga je vozila nije vodila servisnu knjižicu, pa je mislila da na 103.000 km je red na veliki servis.Međutim, ispostavilo se da je servis za nekih 10k km, ali zato ovaj put je rečeno da moraju da se menjaju sva 4 amortizera, diskovi, pločice, paknovi. Neozbiljnost povodom vođenja servisne knjižice, koje je po meni apsurdno za ovlašćeni servis (po sistemu, žena je to, lako ćemo), recimo da sam bio kod Gorana na Altini, sa starim doblom jtd, dva puta bio, dva puta dobio servisnu knjigu. Druga bitnija stvar je sledeća : da li je moguće da sam na tako dug put išao sa glavom u torbi ? Malo mi nemoguće deluje da su amortizeri crkli za tako kratak interval (kočnice manje više). Ili su svi navedeni problemi nastali ranije, pa sam išao u grčku na sreću, ili sam izmužen za 300e. Baš me zanima vaše mišljenje o ovome. Srdačan pozdrav Quote Share this post Link to post Share on other sites
SrdjanNS86 20 Posted January 19, 2016 (edited) I ja ga zaobilazim u sirokom luku.Isao prosle godine sa Puntom dok sam imao na zimsku proveru i sve sam pregledam ono sto mogu oko.Primera bocicu antifriza.Znam da stoji na normali.Odem kod njega i pregleda auto brze nego sto sam stigao da sednem gore gde se ceka dok se radi neki servis na autu.Kazu fali ti antifriza u boci i moralo bi se menjati komplet.Ja reko pa ima.Kazu oni odnosno tamo majstori zanata svog kao fali evo vidi.Ja se samo nasmejao i spustio haubu kupio lepo tecnost staru ispustio ozracio sistem,Cisto da zna kojim se cakama i bave.Mnoge stvari koje sam ja sa svojom dijagnostikom video ovom obicnom da kazem oni mi nisu rekli ili naveli u onaj opis gresaka,Kad god imas problema ili planiras neki ozbiljniji servis pravac Goran sa Altine,za neke manje tipa mali servis plocice...to mozes sam kupiti pa neka ti neko zameni naravno u tvom prisustvu cisto da budes siguran u ove poducene majstore Edited January 19, 2016 by SrdjanNS86 Quote Share this post Link to post Share on other sites
alexpapi 0 Posted January 29, 2016 Samo da pohvalim AP sporting kupljen maf senzor auto radi jos gore nego sa fabrickim drzi obrtaje a pri paljenju podigne na 3500 obrtaja ,diagnostikom i pozajmicom drugog maf ustanovljeno da ne radi kako treba i uz racun naravno ne moze da se zameni nego mora na vestacenje. Iako imaju svoj recimo servis odma do radnje i moju konstataciju da dovedu svog elektronicara ili elektricara da vidi ako ne veruju odgovor je da nemaju istog . Njihovo resenje je kupi drugi senzor za 6500 din pa ovaj ostavim pa ako ustanove da nevalja vratice pare .??? Da ustanovice kako da ne da ne radi kako treba sve sumnjam . Inace veoma sam smiren bio al njihov sef iliti staje vec bi mogao na neki trening komunikacije ili sta vec.Elem nije prva zezancija sa njima al su zaboravili kako su prosli kad su uvalili remontovane viljuske ko nove kako su prosli (dobio nove i jos besplatno montirali) tako da cu i sad da ih ganjam najstrasnije . Nabavio maf senzor na drugom mestu a ovaj ce vestace al na drugom mestu ne neki njihovi pa ce se igramo sa inspekcijom .. inace prodaju senzore u kutiji zatvoreno m&d a senzor unutra kao bosch nalepnica a ovaj pokvareni koji su uvalili meni samo pise m&d made in brazil . Iliti cuvajte se prevaranata i cuvajte racune ... Quote Share this post Link to post Share on other sites
vukajlo 4 Posted January 31, 2016 m&d je ok ako znas tacno sta kupujes unutra. Evo primer (sa orginalnog sajta): http://www.meat-doria.com/product_meat/86015 lepo pise 86015 genuine part (ovo je Bosch) a 86015 / 1 zamenski (ne pise kineski ali jeste). E otprilike im je kod nas i duplo razlika u ceni gde ja ovaj kineski ne bih nikada stavio,a ovaj genuine je bio isti kao onaj sto sam skinuo sa auta. E sad zvao sam i Bosch i skuplje bi me izasao isti ovaj.Naravoucenije ja vec godinama kad krecem u kupovinu delova se naoruzam kataloskim brojevima (ma koliko to bilo naporno i smorno), bas zato sto su mi uvaljivali sve i svasta , ali nije mi se desilo da mi ne vrate pare nazad. Quote Share this post Link to post Share on other sites
Kaniđa 1 Posted February 1, 2016 Samo da pohvalim AP sporting kupljen maf senzor auto radi jos gore nego sa fabrickim drzi obrtaje a pri paljenju podigne na 3500 obrtaja ,diagnostikom i pozajmicom drugog maf ustanovljeno da ne radi kako treba i uz racun naravno ne moze da se zameni nego mora na vestacenje. Iako imaju svoj recimo servis odma do radnje i moju konstataciju da dovedu svog elektronicara ili elektricara da vidi ako ne veruju odgovor je da nemaju istog . Njihovo resenje je kupi drugi senzor za 6500 din pa ovaj ostavim pa ako ustanove da nevalja vratice pare .??? Da ustanovice kako da ne da ne radi kako treba sve sumnjam . Inace veoma sam smiren bio al njihov sef iliti staje vec bi mogao na neki trening komunikacije ili sta vec.Elem nije prva zezancija sa njima al su zaboravili kako su prosli kad su uvalili remontovane viljuske ko nove kako su prosli (dobio nove i jos besplatno montirali) tako da cu i sad da ih ganjam najstrasnije . Nabavio maf senzor na drugom mestu a ovaj ce vestace al na drugom mestu ne neki njihovi pa ce se igramo sa inspekcijom .. inace prodaju senzore u kutiji zatvoreno m&d a senzor unutra kao bosch nalepnica a ovaj pokvareni koji su uvalili meni samo pise m&d made in brazil .Iliti cuvajte se prevaranata i cuvajte racune ...Senzor u ruke i kod nekog ovlašćenog servisera i da on lupi svoj pečat da je senzor neispravamn onda sa time odeš u AP i kažeš im izvoli račun,izvoli deo,a evo i poruka od ovlašenog sevrisera da je deo neipsravan vrati novac ili se vidimo na sudu,a sud će da ih košta kao godišnja zaliha tih delova. Quote Share this post Link to post Share on other sites
lomisa 9 Posted February 3, 2016 Preporuka za servis Auto expres. Nalaze se kod iskuljucenja sa autoputa kod steco-a. Mali servis za Fiat Brava, 1200 din. Servisna knjizica, potpisan racun, uredan prijem, vrhunske masine..Usput testiran antifriz, akumulator i anlaser i pregledan trap! Imaju i svoju prodavnicu delova i opreme.http://www.autoexpress.rs/ Quote Share this post Link to post Share on other sites
Dezurni 399 Posted February 3, 2016 Šta mali servis 1200 din? Quote Share this post Link to post Share on other sites
Ivan 17680 Posted February 3, 2016 Verovatno ruke. Quote Share this post Link to post Share on other sites
lomisa 9 Posted February 4, 2016 Samo ruke, ulje i filteri kupljeni u AP sportu! Quote Share this post Link to post Share on other sites
krsma86 0 Posted February 6, 2016 Upravo sam imao vrlo negativno iskustvo u servisu Ninic. Imao sam problem sa elektronikom na FIatu Stilo 1.6 16v posle predjenih 130000km.Poceo je da guta knedle i da prijavljuje problem sa senzorom za temperaturu vode, da se nasumicno gasi. Uzmem 5 dana godisnji (ocekujuci komplikacije).Zakazem i odvezem im kola u ponedeljak. Tek u sredu javljaju da je motorni kompjuter(t9 dosta redak) pokvaren i da treba da se menja (predlazu da mi ugrade nov za 50000).Iscimam se i nekako uspem da im dostavim polovan(200 EUR) u cetvrtak ujutru. U petak oko 4 mi javljaju da je auto popravljen.Vec sutra, skoro isti kvar isti problemi. Vratim se odmah kod Ninica - obrazlozenje: Sto nisi sacekao mesec dana i paltio 50000 za nov kompjuter, jer ni ovaj ne valja - pokvario ti se izmedju petka i subote.... Mozemo gratis da ti ga zakacimo za akumulator pa ce mozda bolje da radi. (Taj auto je presao 130000 sa komjuterom na motoru!!) Zakljucak je da su skupi i spori i da ga nisu istestirali kako treba. (Da jesu vratio bih komp i spasao 200 EUR) Potroseno: 200 EUR + 7200 dinara + 5 dana godisnjeg + 5 kila zivacaRezultat: Nula Meni vise ne pada na pamet tamo da idem. Ima li neko preporuku za nekog drugog majstora za FIATA, koji ima diagnostiku? Quote Share this post Link to post Share on other sites
MS PK 7735 Posted February 6, 2016 Ja za taj 1.6 stilo ne bih smeo da preporucim nikoga! Imas ovde na temi dosta pozitivnih iskustava sa nekim servisima, pa sam odluci Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 6, 2016 Deo je prebačen u odgovarajuću temu:https://www.fiat-lancia.org.rs/forum/index.php?/topic/42358-različite-cene-servisa/?p=1309696 Quote Share this post Link to post Share on other sites
brankoz 5 Posted February 14, 2016 Samo da pohvalim servis TIM na Vidikovcu kod okretnice 53 i 23! Dosao sam nenajavljen i trazio Mikija jer sam za njega dobio preporuku da je odlican majstor, naravno, kao i svi u TIM-u. Dok je radio, usput sam se sa njim konsultovao i zakazao termin kada da dodjemda mi pogleda sveze kupljen auto i uradi mali servis. Video covek sve, uradio servis, posavetovao vezano za mane koje ti modeli imaju, pregledao kompletan auto i dao misljenje i predloge. Korektni su sa cenom i ne mrzi ih da odgovaraju na 1001 pitanje koje im ljudi postavljaju! Sto se kaze, deluju zainteresovano kakav god problem na autu vozac ima. Preporuka! Trenutno sam u fazi traženja servisa za nedavno kupljeni Stilo. Pošto sam sa Ceraka gledam neki dobar servis koji bi mi bio relativno blizu. Čitajući postove iz ranijih godina video sam dosta pohvalnih postova o TIM servisu i majstor Mikiju (@mikisxy) (koji je jedno vreme bio stalno na forumu i davao savete). Idući unazad po postovima ovo je poslednji post (avg. 2013.) u kome je pohvalno pisano o ovom servisu, pa me zanima da li znate:- da li je ovaj servis i danas OK?- šta je bilo sa Mikijem i da li i dalje radi u TIM (ako ne, da li se zna gde)? Quote Share this post Link to post Share on other sites
totti 13165 Posted February 14, 2016 Na Vidikovcu imaš i servis Abarth Quote Share this post Link to post Share on other sites
