kolega.jankovic 23 Posted May 5, 2014 Ja sam nasao u gvozdjari Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted May 5, 2014 Moze i tako, ali u biblioteci i knjizari nema Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted May 5, 2014 Postovanje SVIMA,Zna li neko gde u BG-u mogu da kupim crevo koje ide od filtera goriva do pumpe viskokoh pritiska (stilo 1.9 multijet, 120 ks, 2006. god)? Okreni, pitaj ima li:064/1299305, Dejan Quote Share this post Link to post Share on other sites
DjoleKG 0 Posted May 5, 2014 hvala na odgovoru beli Quote Share this post Link to post Share on other sites
Woodoo 23015 Posted May 5, 2014 U vezi creva, probaj i ovde 064/63-95-872, trebalo bi da su kvalitetnija i da duže traju od Dejanovih. Quote Share this post Link to post Share on other sites
bglion 401 Posted May 5, 2014 Woodooda li su to pravljena creva i da li su za gorivo ili ima i za turbo? Quote Share this post Link to post Share on other sites
totti 13165 Posted May 7, 2014 Gde može da se nađe ovaj držač za naočare (ili sličan, nebitno)? Quote Share this post Link to post Share on other sites
diskusija 9 Posted May 7, 2014 Možeš zalepiš samu futrolu od naočara Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 7, 2014 E to bih i ja hteo da stavim u stila, samo ne znam da li je to ikada islo fabricki u stila ili bi morao od nekog drugog auta?Sent from my HTC Desire 601 using Tapatalk 2 Quote Share this post Link to post Share on other sites
Djole_M 150 Posted May 7, 2014 Kod Kineza garant ima ili u nekoj optičarskoj radnji Quote Share this post Link to post Share on other sites
totti 13165 Posted May 7, 2014 Evo, nađoh nešto...http://www.lavauto.rs/elektronski-katalog.html?page=shop.product_details&category_id=137&flypage=flypage.tpl&product_id=31028 Mada, deluje onako malo bezveze, al' otići ću da ga pogledam. Quote Share this post Link to post Share on other sites
Woodoo 23015 Posted May 7, 2014 Woodooda li su to pravljena creva i da li su za gorivo ili ima i za turbo?Jesu pravljena, ne znam ko ih pravi, kontakt koji sam ostavio je od prodavca, ne od proizvođača. Najbolje je da pozoveš. Quote Share this post Link to post Share on other sites
steel 21 Posted May 8, 2014 Gde može da se nađe ovaj držač za naočare (ili sličan, nebitno)? Ovo i ja jurim , znam da ima fabricki na reno lagunama Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted May 8, 2014 Ja se ubih trazeci plasticne cepove koji pokrivaju srafove stop svetala za Punta mk2 sa troja vrata. Svi sto rade sa polovnim delovima kazu da to ide zajedno sa tapacirom stuba. E, da ga...ako neko naleti, nek pusta link ili kontakt. Quote Share this post Link to post Share on other sites
totti 13165 Posted May 8, 2014 Ima fabrički na dosta kola, ali je pitanje da li ti fabrički mogu baš uvek naknadno da se ugrade... Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted May 8, 2014 Gile kad dodjes u sd, svrati do debelog Ivice, onaj punto od njegovog suraka cerupa kako ko stigne, mozda i ti nadjes ono sto ti treba Samo ne pominji da sam te ja poslao Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted May 8, 2014 Seticu se valjda. Nasao sam ovde par plastika i nekih zabica koje su falile, ali to-nikako. Hvala na info. Quote Share this post Link to post Share on other sites
Axic 20048 Posted May 8, 2014 Mislim da ih ja imam gile i to dva komada samo ne znam da li je isti jer mislim da su moji za onaj sa petoro vrata. Ako nema razlike potražiću ih negde pa ako ih nađem javljam ti. Quote Share this post Link to post Share on other sites
diskusija 9 Posted May 9, 2014 gde bih mogao da kupim desni (suvozacev) far za Zastavu 10 tj Punta? najvise bi mi odgovaralo neki polovan ali u dobrom stanju? Quote Share this post Link to post Share on other sites
igor0511 2882 Posted May 9, 2014 Kreni po redu po otpadima. Najbolje je što više da ih pozoveš jer imaju dosta različite cene Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 9, 2014 @totti pogledaj na nekom 307 ima nesto tako, ili su pak kod njega ona vratanca kod unutrasnjeg osvetljenja, skoro videh kod koleginice u 307... Pogledacu sutra da l je to ili se otvaraju vratanca... htc evo 3D Quote Share this post Link to post Share on other sites
totti 13165 Posted May 9, 2014 Mislim da se kod 307 otvaraju vratanca, ali ipak pogledaj Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 9, 2014 Hocu. Samo da se dovucem sutra u firmu a znam da sam na nekom autu to video, i prikaceno sa zabicama na rukohvat, tako nekako... Samo da se setim...htc evo 3D Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted May 9, 2014 Mislim da ih ja imam gile i to dva komada samo ne znam da li je isti jer mislim da su moji za onaj sa petoro vrata. Ako nema razlike potražiću ih negde pa ako ih nađem javljam ti.Eto, samo treba covek da napise sta mu treba i ovde sve ima. kao robna kuca smo. Imam ovde i jednog Classica, kog mi je ostavio ortak da mu ga cuvam,. Skinucu sa njegovog da probam, pa ako odgovaraju, da se dogovaramo za cenu. Quote Share this post Link to post Share on other sites
Axic 20048 Posted May 9, 2014 (edited) Mislim da ih ja imam gile i to dva komada samo ne znam da li je isti jer mislim da su moji za onaj sa petoro vrata. Ako nema razlike potražiću ih negde pa ako ih nađem javljam ti.Eto, samo treba covek da napise sta mu treba i ovde sve ima. kao robna kuca smo. Imam ovde i jednog Classica, kog mi je ostavio ortak da mu ga cuvam,. Skinucu sa njegovog da probam, pa ako odgovaraju, da se dogovaramo za cenu. Daj da se menjamo. Meni fale one dve plastike što drže zadnji deo neba a nalaze se iznad zadnje klupe, preciznije iznad zadnjih naslona za glavu. Evo napisao sam i u oglasu na forumu da tražim to ali se niko ne javlja. http://www.fiat-lancia.org.rs/forum/index.php?/topic/64180-k-plastika-za-nebo-punto-mk2/#entry1033177 Edited May 9, 2014 by Axic Quote Share this post Link to post Share on other sites
