cileee 1 Posted January 25, 2015 Kod mene kad je prazan aku. ne prijavljuje nista od gresaka. Nije bitna cena zato sto moj auto nije Fiat (ja koristim Pezoovu elektroniku). Sve sto je Fiatovo na njemu je znak i oznaka u saobracajnoj JTD. Zato nisam napisao tacnu cenu u dinar jer mislim da je bespotrebna posto je mozda razlicita za Stila. Quote Share this post Link to post Share on other sites
Ivan 17683 Posted January 25, 2015 Za Stila je cak i zamenski skuplji od tog, bili su oko 850 din, pa navise... Quote Share this post Link to post Share on other sites
cileee 1 Posted January 25, 2015 Ja se secam da sam platio tacno oko 490-500 dinara. Nov. Quote Share this post Link to post Share on other sites
gocamanja 0 Posted January 27, 2015 (edited) jebeni imbus na senzoru nece da se odvrne...sad je proklizio sta da radim? Abs zadnjeg tocka Edited January 27, 2015 by gocamanja Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted January 27, 2015 Gde je proklizao, na navoj ili na mestu za kljuc tj imbus? Quote Share this post Link to post Share on other sites
gocamanja 0 Posted January 27, 2015 (edited) tu gde ide imbus Edited January 27, 2015 by gocamanja Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted January 27, 2015 (edited) Pa vidi uzmi sledeci veci, nabij ga nekako, malo udari cekicem, pa odvij senzor, i posle zameni taj sraf drugim. Edited January 27, 2015 by Buca_Tipo Quote Share this post Link to post Share on other sites
Markobgd 609 Posted January 27, 2015 Nakucaj torex ključ odgovarajući i odvrnućeš. Posle zamena šrafa i gotovo Quote Share this post Link to post Share on other sites
gocamanja 0 Posted January 27, 2015 posto je dijagnostika pokazala abs zadnjeg desnog tocka moguce je lezaj kao sto kazu majstori posto mi se cuje u voznji da nesto cvili Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted January 27, 2015 Cvili ili bruji? Lezaj bi trebalo da bruji? Mozda gresim, nek me neko ispravi... Quote Share this post Link to post Share on other sites
gocamanja 0 Posted January 27, 2015 (edited) Ne mogu vise ni to posto sam rezao sraf da udje srafciger pa ni to nije upalilo sad mu negine rezanje. ...budala Edited January 27, 2015 by gocamanja Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted January 27, 2015 A sa klestima, da malo jace uhvatis i da popusti, a mislim da bi mogo sa toreksom da probas ako imas Quote Share this post Link to post Share on other sites
gocamanja 0 Posted January 27, 2015 Nema prilaza za klesta...mislim da je jedino resenje skidanje celog diska i kocnica a ja bas nisam strucan za sve to...Jel neko zna za taj lezaj abs-a ili sta je to? Quote Share this post Link to post Share on other sites
RubeJTD 0 Posted April 13, 2015 Imam problem.Upalim kontakt upali se i ugasi lampica od ESP ABS ASR , i sve ok. krenem sve zavisi nekada odmah pri kocenju a nekada posle pola sata voznje , nema pravila.... od jednom u toku voznje se popale sve lampe od navedenih delova. sta moze biti? Quote Share this post Link to post Share on other sites
Dusan 4 Posted April 13, 2015 Ono sto meni odmah pada napamet je senzor obrtaja tocka (ima ih 4 na svako tocku po jedan), moguce da je prljav ili da brljavi, ali da bi bio siguran sta je, mora dijagnostika... Quote Share this post Link to post Share on other sites
RubeJTD 0 Posted April 17, 2015 Evo resen problem....Danas je odradjna diagnostika, senzor na papucici od kocnice je lazirao i ne pravilno radio... pa je davao lazne signale, zbog toga se sve popali.Resenje je jednostavno ocistiti kontakt ili kupiti drugi senzor... Ako sam nekome pomogao, drago mi je... pooz Quote Share this post Link to post Share on other sites
Arguso 0 Posted May 19, 2015 Pozdrav! Na mom Fiat Stilu 1.8 16v, na displeju mi već duže vreme izbacuje tekstualne greške ABS, ESP i ASR failure a na tabli mi sijaju lampica od ABS-a i ona druga sa prikazom "trougla sa uzvičnikom u krugu" (predpostavljam da je to ili ASR ili ESP greška).Konačno je došlo vreme da i to sredim na autu i na dijagnostici su ustanovili da je problem u senzoru prednjeg levog točka.Hteo bih sam to da zamenim, zato što postoji mogućnost i da se samo zaprljao (tako rekoše....), pa mi treba savet/uputstvo kako da to uradim sam i slike ili video tog senzora (na youtube svih automobila ima ali za stila nisam našao).P.S: Molim vas samo konkretne postove, pročitao sam svih 10 stranica ove teme i sve je "trla baba lan" ili "otiđi kod majstora", ili samo problemi (čast izuzetcima), nigde nekih slika, videa ili drugog uputstva, što mi moglo da pomogne i meni i drugima. HVALA unapred! Quote Share this post Link to post Share on other sites
Mijailović P. 3451 Posted May 19, 2015 Budi prvi i pokupi zasluge! Bez šale, ako si vičan majstorisanju neće ti biti problem da dođeš do senzora. Verovatno (nisam čitao temu) ljudi nisu imali problema te vrste pa otud i nedostatak slika. Dosuše, ima na engleskom forumu sigurno. Pozdrav! Quote Share this post Link to post Share on other sites
SikterBre 31 Posted May 20, 2015 Meni se nekad na paljenju javlja ovaj problem + alternator failure, a ECU je sredjen kompletno.. Quote Share this post Link to post Share on other sites
majkicbane 58 Posted May 20, 2015 I meni takodje nekad pri paljenju, kad ga ne palim par dana. Verovatno akumulator Quote Share this post Link to post Share on other sites
statichawk 72 Posted May 20, 2015 (edited) @ArgusoMoze biti da se prekinuo kablic, kao sto se meni desilo. Edited May 20, 2015 by Ivan Skinut nepotreban citat Quote Share this post Link to post Share on other sites
M-a-r-k-o 3 Posted June 3, 2015 Meni se taj simptom prvi put javio sa slabljenjem akumulatora i to odmah nakon kupovine auta a greška se toliko brzo pojavi i izgubi da sam jedva stizao da je pročitam. Desilo se par puta i aku je vrloo brzo nakon toga riknuo i nakon stavljanja novog nikad se više nije palila ista greška. Quote Share this post Link to post Share on other sites
lan_fan 36 Posted June 20, 2015 Nadam se da je i kod mene slična situacija i da ću zamjenom aku dovesti stvari u red...jutros ni mrc, ne vergla, pojavi se rečena poruka, provjerom akua utvrdim da je pred izdisajem, BOSCH silver star 7-8 godina...dopunio sam ga, ali primjetno teže pali nego recimo prije 2 dana...jeli moguče da se tako brzo strmoglavi snaga?...u Utorak planiram novi kupiti, molim za prijedlog snaga i marka. Hvala. Quote Share this post Link to post Share on other sites
Ivan 17683 Posted June 21, 2015 Odgovarajuca tema, imas masu preporuka i iskustava konkretno za Stilo JTD (koja marka, Ah, startna struja...): https://www.fiat-lancia.org.rs/forum/index.php?/topic/31753-o-akumulatorima/ Quote Share this post Link to post Share on other sites
m1lanch3 0 Posted July 1, 2015 (edited) Juce sam menjao lezaj prednjeg levog tocka. Zamenjen je samo lezaj a onaj neki senzor nije diran, lepo je sve raspakovano i spakovano kad se radilo. Cim sam krenuo pokazao mi je gresku ASR i ABS failure i majstor mi rece da ce to da prestane samo za koji dan dok valjda taj senzor nesto uhvati neki magnet nesto pitaj boga i ako ne bude da dodjem da promenimo naknadno i senzor. I ajd sve to tako prodje, ja, kad pokaze gresku i zapisti, stisnem dugme menija da sklonim te greske sa ekrana i desava se sledece. Pocnem da kocim, lagano, malo jace, nebitno kako i pocinje nesto da struze napred kao ono kad hoces u brzinu bez kvacila pa pocnu da struzu zubi, zatim pocne papucica kocnice da vibrira onako solidno, kao da je nesto otpozadi kucka i malo slabije koci. Sta bi to moglo biti i koliko je opasno? Edited July 2, 2015 by neshaoct spojeno Quote Share this post Link to post Share on other sites
