Boki Bugiboy 14 Posted May 9, 2022 (edited) Zdravo,vreme je da predstavim svoj prvi Fiat.U pitanju je Bravo 2008 godište,TJET 1.4 sa 150 ks sa odličnom opremom i po meni najlepšim enterijerom,izdvojio bih fabrički blow off ventil (nisam ni znao da ima fabrički ).ugradjeni distanceri na točkovima i prednje H&R crvene opruge.Za sada je sve kako treba,jedino možda vratim njegove prednje sport opruge Edited May 9, 2022 by Ivan Sredjene slike 9 dach@, Mijailović P., Dzimbo and 6 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted May 9, 2022 Bas lep bravo. Sad si ga kupio?Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Boki Bugiboy 14 Posted May 9, 2022 Pre 15 ak dana,hvala Quote Share this post Link to post Share on other sites
ISV_01 4035 Posted May 9, 2022 Lepo očuvan Bravo, sport oprema mu baš daje dobar šmek. Neka te lepo služi PS Ugradi tempomat (ne vidim na slici da li je prisutan), bagatela je ručica, instalacija verujem da je već razvedena fabrički pa ti ostaje samo plug n play Quote Share this post Link to post Share on other sites
Boki Bugiboy 14 Posted May 9, 2022 Hvala,nema tempomat,nisam znao da je to vec razvedeno,pogledacu na forumu kako se to radi,ili ima neko strucniji Quote Share this post Link to post Share on other sites
neshtry 14867 Posted May 9, 2022 Lutka od auta!Da služi dugo i bez problema Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Boki Bugiboy 14 Posted May 9, 2022 (edited) Hvala. Edited May 9, 2022 by Ivan Ne citiraj prethodni post Quote Share this post Link to post Share on other sites
MS PK 7734 Posted May 9, 2022 Koliko te je kostao, ako nije tajna? Послато са SM-A307FN помоћу Тапатока 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
Boki Bugiboy 14 Posted May 9, 2022 Nije tajna 4000 eura 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted May 9, 2022 Očuvan eksterijer i enterijer. "Baci" neku sliku motornog prostora. Kako se ponaša na osamneskama, inače mu jako lepo čučnule. Quote Share this post Link to post Share on other sites
Boki Bugiboy 14 Posted May 9, 2022 Zaboravio sam na motorni prostor,bice update uskoro,svaki auto koji sam vozio bio je na sirokim gumama tako da sam navikao na tvrdocu,medjutim stabilnost i odziv je za svaku pohvalu Quote Share this post Link to post Share on other sites
Ivan 17677 Posted May 9, 2022 (edited) Distanceri su pun pogodak, ne znam zasto su sa fabrickim 18'' ukenjali motku sa prilicnim ET. Jeste sama felna sira pola cola (7.5'') od 16'' i 17''. Ali su ET povecali sa standardnih ET 31 na ET 35, povukli je ka osi vozila i delimicno ponistili efekat sirine. Pa kao debilan rezultat toga dobijes da fabricka restyle Sport 17'' (samo 7'' siroka ali sa ET od 26 mm), ima siri trag tockova od 18'' . Ako ti opruge napred nisu pretvrde, meni licno ovo deluje kao super visina. Imam najnizu fabricka verziju opruga (nista nisam cackao), najniza tacka auta je na 9 cm od tla i nema nekih problema u voznji ili pri parkiranju. A deluje mi slicna visina kao kod tebe. Sa malo krofnastijim 225/45/17 sasvim korektna i udobnost, a bas lepo se vozi po krivinama. 7 hours ago, Boki Bugiboy said: Utvrdili smo zasto na Bravu/Delti, pozute 90% leve maglenke . Kod mene su se leva i desna maglenka gadjale u mesec proizvodnje, desna dobra, a leva je bila pozutela. Vidim da je i kod tebe slicna situacija. Meni je bas bolo oci pa sam menjao vozacku, cene novih su ti od 30-40 EUR za zamenske (DEPO, TYC), do oko 80 EUR iz originala. OEM polovnjake zaboravi. 7 hours ago, Boki Bugiboy said: izdvojio bih fabrički blow off ventil (nisam ni znao da ima fabrički ) Ako je do zvuka, da ne mislis mozda na Wastegate ventil (rasterecenja turba, na izduvnom delu)? Koje je godiste Bravac po ePeru? Obicno su ove bele table gurali u pocetne serije iz 2007., pa su brzo prebacili na crne, sa crvenim detaljima. Malo oduzih svoja zapazanja - da te autic lepo sluzi, deluje bas lepo sacuvan za ta godista (pre restyle se cesto sljusti volan/menjac/rucna, pootpadaju bedzevi, pozute otvori ventilacije). Navrati na nedeljno druzenje kod Intera da pojacas Bravo Sport ekipu i da malo potegnemo MultiAir i T-Jet . Edited May 9, 2022 by Ivan Quote Share this post Link to post Share on other sites
Boki Bugiboy 14 Posted May 9, 2022 Hvala na pozivu,da 2007 godiste je a prva registracija je Februar 2008,sto se tice maglenki vozaceva je zuta i pomalo smeta ali to cu u dogledno vreme resiti,sto se tice blow off ventila,tako mi je majstor rekao kada je gledao motor ja iskreno nisam primetio drugaciji zvuk vec sam preneo njegovo zapazanje.Kada sam bio kod njega jednu stranu creva je otkacio i imao je taj zvuk pri turiranju.Sto se tice opruga,visina je odlicna ali kad naletim na neko udubljenje na asfaltu imam utisak da tabla hoce da iskoci iz auta doduse levi amortizer ima jako malo ulja na vrhu mada taj majstor kaze da su za sada dobri,hvala na lepim zeljama Quote Share this post Link to post Share on other sites
Ivan 17677 Posted May 9, 2022 55 minutes ago, Boki Bugiboy said: Hvala na pozivu Juce sam bas bio posle 100 godina , bani kada si dokon nedeljom, uvek ima drugara forumasa: https://www.fiat-lancia.org.rs/forum/index.php?/topic/27773-redovno-fiat-lancia-okupljanje-beograd/&do=findComment&comment=1647067 1 Boki Bugiboy reacted to this Quote Share this post Link to post Share on other sites
BaneAK74 113 Posted May 10, 2022 Lep Bravonja! Da te lepo sluzi! Quote Share this post Link to post Share on other sites
vicent 1263 Posted May 18, 2022 Čestitam, lepo izgleda. Puno bezbrišnih km !Poslato sa JSN-L21 pomoću Tapatoka Quote Share this post Link to post Share on other sites
OMP 2215 Posted May 19, 2022 Lep bravo....Svaki turbak ima taj zvuk kad se otkaci crevo neki cak i preprave nacin kacenja creva da bi se stalno tako culo ali meni je to ruzno. Quote Share this post Link to post Share on other sites
