voodoons 349 Posted March 29, 2019 Pa nije da nije 100kg može biti i litar u gradu.. Quote Share this post Link to post Share on other sites
FantomX 5 Posted April 6, 2019 @marko.jovanivickoji bre 2.0 tdi ti vozis?Opet neki trulex? Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 6, 2019 najbolji od svih 2.0 tdi vozi Marko,BKD oznaka Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted April 7, 2019 Juce uradjen mali servis i prvi put auto onako detaljnije pregledan na dizalici... Bez zamerki doduse, motor malo mas'an od dole, moj majstor mi kaze 'svaki je' Quote Share this post Link to post Share on other sites
cika_kole 825 Posted April 7, 2019 tvoj majstor Djura nema pojma, da se dulo pita on bi to poterao u ovlasteni servis! Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 18, 2019 Nikad udaran, prva farba Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted May 18, 2019 Kad udari brat na brata 2 Axic and rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
nstyner 171 Posted May 18, 2019 I bre komso,sta to bi? Quote Share this post Link to post Share on other sites
silenci 2337 Posted May 18, 2019 ejbg,pa kako,mnogo se vole pa se poljubili Ma sredice se sve to Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 18, 2019 Isao u Ilije Bircanina i gospodja izleti iz Janka Veselinovica (ja imao prednost), nesto se zamislila i nije stala i jbg... Naravno da ce se srediti. Kolko sam uspeo da vidim, samo je limarija stradala... Dovezao sam ga kuci najnormalnije. Popunili evropski pa u ponedeljak u Dunav osiguranje na procenu... Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted May 18, 2019 Neverovatno far izgleda netaknut, a sve oko njega zguzvano, mada verovatno su stradali nosaci fara sto je nista realno. Quote Share this post Link to post Share on other sites
nstyner 171 Posted May 18, 2019 To kod umetničke škole?Tu sam bio prisutan više puta kada prolete kolima ni ne pogledaju da li neko nailazi! Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 18, 2019 6 minutes ago, vagenovac said: Neverovatno far izgleda netaknut, a sve oko njega zguzvano, mada verovatno su stradali nosaci fara sto je nista realno. Upravo tako, faru nista, bukvalno nista, samo je nosac puko.. i iscurela mi tecnost za brisace, ne znam da li je pukla posuda ili crevo. U sustini, krilo, hauba i branik, to je steta. Felna netaknuta, bez ogrebotine 7 minutes ago, nstyner said: To kod umetničke škole?Tu sam bio prisutan više puta kada prolete kolima ni ne pogledaju da li neko nailazi! Da, bas tu.. cesti su sudari na toj raskrsnici, ljudi koji idu iz Janka Veselinovica istripuju da imaju prednost, Ne znam zasto Quote Share this post Link to post Share on other sites
voodoons 349 Posted May 19, 2019 Jer kroz celu J.Veselinovica imaju prednost pa kontaju da i tu imaju... A sto je najgore sa obe strane imaju dva trougla za nailazak na put na kom nemaju prvenstvo... Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 21, 2019 U Dunav osiguranju procenili stetu na 90.000 i prvo sam pomislio da je to dovoljno, medjutim kad sam krenuo da zovem za delove, neprijatno se iznenadih. Ukratko, za delove mi treba oko 500 e, + farbanje posto nisam nigde uspeo da nadjem delove u istoj boji + ruke majstora... + ako se ustanovi jos nesto sto se ne vidi dok se ne poskidaju delovi. Kad sve saberem, prelazi tih 750 e koliko dobijam od Dunava. Tako da sam otisao opet do njih i uzeo spisak servisa sa kojima saradjuju, i sve preko tih 90.000 ce Dunav uplatiti na racun serivsa koji bude radio auto.. Od meni poznatih servisa, na spisku su 'Arsenov' i 'Gabika'.. Tu je jos i 'Auto Nesa' i 'Grubic auto' od farbara. Ima li neko preporuku za neki od ovih servisa? Quote Share this post Link to post Share on other sites
darkman14 5901 Posted May 21, 2019 zar su toliko delovi? Najbolje oteraj u servis sa kojim saradjuju i nek ti urade. Naravno, detaljno pregledaj posle Quote Share this post Link to post Share on other sites
Mirko_NS 19 Posted May 21, 2019 (edited) 2 hours ago, rkoma1986 said: Od meni poznatih servisa, na spisku su 'Arsenov' i 'Gabika'.. Tu je jos i 'Auto Nesa' i 'Grubic auto' od farbara. Ima li neko preporuku za neki od ovih servisa? Ja sa "Arsenov" servis imam dobra iskustva u smislu da su nijansu pogodili perfektno, cak i za male povrsine. Uglavnom su ispostovali dogovorene rokove. Edited May 21, 2019 by Mirko_NS 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 21, 2019 1 hour ago, andreja.micovic said: zar su toliko delovi? Najbolje oteraj u servis sa kojim saradjuju i nek ti urade. Naravno, detaljno pregledaj posle Branik sa maskom nema ispod 200 (lik iz Kaca mi trazio 300), hauba 120, krilo 80.. far 60-80, posuda za tecnost za brisace 10-20, i ima jos neka plastika sto ide preko veznog lima. Far moram ceo jer niko ne prodaje samo nosac fara posebno. Mislim da ce "Arsenov" i biti na kraju.. 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted May 21, 2019 gabika drugaru omasili nijansu, posle ga ubedjivali da to tako mora, grubic ok ofarbao, ali traljavo zastitio, ono pored vrata i u zazorima bilo nabijeno one bele skamenjene prasine od polir paste. Nezahvalno davati preporuku, ja sam davno farbao branik na pasatu kod gabike i bilo super i preporucim drugaru i njemu omase nijansu, svakako nije gabike sto je nekad bio. Cuo sam za nekog talijana u gradu da hvale, ali nemam direktno iskustvo, a pitanje je da li je samo izvikan i da li se pokvario. Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 21, 2019 Jest nezgodno preporucivati. Al opet dobro dodje da cujes neko iskustvo Quote Share this post Link to post Share on other sites
danijel55 700 Posted May 21, 2019 To mi je poznata prica da tako treba da bude.Drugar farbao leva vrata i vidi se razlika u boji,kaze farbar to ce sunce sve da ujednaci i budala poveruje u to. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 21, 2019 Pa ne prave limari boju, bar ne ovde kod nas. Kad promase boju ovaj u prodavnici mu pravi ponovo, jedino sto limar smirgla i farba za dz. Quote Share this post Link to post Share on other sites
darkman14 5901 Posted May 21, 2019 @Dule 021 je preporučivao nekog. A i ja sam čuo za nekog iz Budisave kad sam se raspitivao za farbanje. Mogu pitati ponovo pa javim Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted May 21, 2019 Idem kod nekog od ovih koje sam gore nabrojao, moram zbog osiguranja. mislim mogu ja da resavam kod koga kod hocu ali se plasim da ce me izaci skuplje od tih 90.000 pa zato Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 21, 2019 Uvek najsigurnija solucija je da uzmes agenciju koja ima advokata, sudskog vestaka i lika koji radi defektazu i das im 20% i radis auto gde zelis, sigurno ces dobiti love da pokrijes stetu a i prekipi. Taj far sto mu je polomljen nosac ce ti izvariti u servisu... 2 neshaoct and darkman14 reacted to this Quote Share this post Link to post Share on other sites
