Muske 14 Posted August 29, 2013 Ima u smederevu jeftinije, 3000 din. Quote Share this post Link to post Share on other sites
bobosport 0 Posted October 1, 2013 a za clanove foruma moguc dogovor i lep popust na kolicinu ako imate predstavnika, organizatora ili slicno javite se na 0606671336 Uros, sa ostalim auto-forum klubovima smo napravili dobar dogovor i redovni su gosti Quote Share this post Link to post Share on other sites
Muske 14 Posted December 12, 2013 Ja javio adminu.... ali on nista... Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted December 12, 2013 Kad dođe na red. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted February 12, 2014 Jel dodje na red? Quote Share this post Link to post Share on other sites
Semi 94 Posted January 23, 2015 Bilo je proslog vikenda organizovano merenje snage kod Bobo-a u organizaciji Arcs-a.Ja, nazalost, nisam bio u Sd-u, ali je merenje bilo 15e. Tako da ako ima zainteresovanih, verovatno bi cena bila ta za grupnu posetu :-) Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted January 23, 2015 Jos samo da budu tacni podaci Quote Share this post Link to post Share on other sites
cane 205 Posted January 23, 2015 Poprilicno je tacan dyno u bobo-u, ali uvek ce biti hejtera koji ce da pustaju rovca po forumima. Kad neko kaze da je chipovao auto i da je dobio xy ks, odmah ih napadate kako to nije tacno jer nije izmereno, a kad izmere onda ne valja dyno... Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted January 24, 2015 http://arcs.org.rs/forum/viewtopic.php?f=29&t=58566Ja sam svoje dokazao... I mogu da dam jos primera gde se dijagrami poklapaju kad nekima mere samo snagu/moment, a kad cipuju onda odmah dolazi do ne slaganja i moment u srednjim obrtajima sto se svi pale danas je veci od realnog... Treba samo malo znati kako funkcionisu dijagrami da se vidi da li je diagram pravi ili ne... Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 24, 2015 U svakoj temi od svega pravite problem ... normalan covek nikako ne moze da razume o cemu vi pricate Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted January 24, 2015 (edited) Nisu nase jedinice ali ta je poenta: Ukratko, dijagrami momenta i snage su uzajamno povezani kroz obrtaje... Ako imas 100Nm na 3000 obrtaja, onda na 3000 obrtaja ce da ima ~43ks bez obzira na auto koji imas... Formula za racunanje: T[Nm]=P[kW]*9550/n[rpm] T - moment P - snaga n - obrtaji pri kojima se ostvaruje ta snaga Potrebno je samo KS pretvoriti u kW... 1.36*kW=ks Edited January 24, 2015 by YUgisa Quote Share this post Link to post Share on other sites
Semi 94 Posted January 25, 2015 Mislim da su valjci poprilicno tacni tamo.Izmerena je jedna jtd 16v fabricka i izbacila je oko 137 konja, a fabricki je 140.Ostale Alfe su bile cipovane lepo, sve su bile jtd 8v. Od njih jedna sa ubacenim turbom od 16v i ona je imala negde oko 162-163 konja. Quote Share this post Link to post Share on other sites
mladenke 7 Posted January 25, 2015 Tacni su dijagrami sa zadnjeg merenja kolega sa arcs foruma. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 25, 2015 I ja sam bio kod boboa i izbacio je 114.9konja za mog stila od 115 konja..... Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 25, 2015 A koliko obrtnog? Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 25, 2015 Ne secam se tacno ali 250inesto.... Quote Share this post Link to post Share on other sites
Semi 94 Posted January 25, 2015 Pa, to je to :-) Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 25, 2015 Da da, taman je pokazalo. Tj za nijansu manje.Samo sam merio, nisam cipovao i jos uvek je tako a do kad.....ne znam. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 25, 2015 Pa dok ne cipujes Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 25, 2015 Tako nekako Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted January 25, 2015 Ajd da probam jos jednom: Audi TT 2.0TFSI sa 197ks i 280Nm. Ako neko vidi problem, vidi, ako ne, ja ga ne znam bolje ubediti... Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted January 25, 2015 Kako meri od nule ? Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted January 25, 2015 Ne znam, nisam ga ja crtao Ali verovatno isto kao sto na 3500 obrtaja meri 358Nm umesto 301Nm... Quote Share this post Link to post Share on other sites
mladenke 7 Posted January 27, 2015 (edited) Yugisa, po mom merenju odstupanja za NM i HP za ovog TT-a se razlikuju -+ 2 od dijagrama. Kako si ti stigo do brojke od 301Nm? 357Nm na 3497rpm... 237hp na 3497rpm 210Nm na 6176rpm... 248hp na 6176rpm Edited January 27, 2015 by mladenke Quote Share this post Link to post Share on other sites
