@bane@ 102 Posted January 12, 2016 Opruga omeksa tj. nema silu da drzi zatvoreno,i voda stalno prolazi ka hladnjaku.Kad sonda izgubi gas nema sile da savlada oprugu i termostat je zaglavljen. Quote Share this post Link to post Share on other sites
Dragomir m 6 Posted January 12, 2016 Pa da,znaci moze ostati otvoren i zatvoren Hvala Quote Share this post Link to post Share on other sites
@bane@ 102 Posted January 12, 2016 Svaki termostat od bilo kog proizvodjaca. Quote Share this post Link to post Share on other sites
Dragomir m 6 Posted January 12, 2016 Ok Bane hvala Quote Share this post Link to post Share on other sites
Mihailovic 29 Posted January 12, 2016 Između ostalog navedenog, mora da počne da u kabini duva mlako već posle 5 min. To znači da se greje samo "mali tok" rashladne tečnosti: blok motora + radijator kabine. Quote Share this post Link to post Share on other sites
Dragomir m 6 Posted January 12, 2016 Samo mozda je bolje iscupati stari termostat iz kucista.Mislim da je to moguce kroz otvor koji dolazi na motor .Meni super ovaj radi,i odmah greje tj kroz neko vreme.,ali mozda se smanji protok vode kroz dva termostata. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 12, 2016 Moguce je, ja samm izvadio stari, ali sanse su 50-50 , tj.vrlo lako moze da se slomi kuciste Quote Share this post Link to post Share on other sites
Dragomir m 6 Posted January 12, 2016 Moram i ja da probam iscupati. Sigurnije je.Ako slomim ima kod mehanicara koliko hoces neispravnih. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 12, 2016 Ja sam prvo nasao neispravan za svski slucaj Izvadio sam bez problema doduse, dok je drug na alfi slomio kuciste iz prve Niko ne vadi stare, mozda znam dva-tri coveka koji su vadili, svi ostali samo dodaju nov. Quote Share this post Link to post Share on other sites
Dragomir m 6 Posted January 12, 2016 Probacu i ja:-) Quote Share this post Link to post Share on other sites
Ivan 17679 Posted January 12, 2016 mozda znam dva-tri coveka koji su vadili, svi ostali samo dodaju nov.Neko vozi bi-turbo, a Srbin bi-termo . Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 12, 2016 Hahaha, sta ces. Veliki mrazevi su kod nas Quote Share this post Link to post Share on other sites
Ivan 17679 Posted January 12, 2016 Po toj logici pretpostavljam da kad crkne Rendzin termo, onda se u crevo samo ugura jos jedan novi .Fiat Stilo JTD Bitermo, ne zvuci tako lose Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 12, 2016 Hahaha, nikom jos nije crko. Videcemo sta se tad radi. Javice se neki taxista vec Quote Share this post Link to post Share on other sites
Dragomir m 6 Posted January 13, 2016 Kazu -17 za vikend moracu jos jedan staviti:-):-) Quote Share this post Link to post Share on other sites
OlyPk 0 Posted November 30, 2020 Pozdrav braco imam jedno pitanje. Vozim stila 1.9 multijet i imam problem sa dizanjem temperature. Vozim auto 30-ak km temperatura se jedva digne do prve crte. Oseti se mlak vazfuh ali nike to to pogotovo kad je hladno. Zanima me da je do termostata ili je mozda nesto drugu? Quote Share this post Link to post Share on other sites
Martin 799 Posted November 30, 2020 Najverovatnije da je termostat. Ali, i pored isparvnog termostata, mjetu treba malo veći gas u toku zime - da bi se zagrejao, vožnja ne bi trebala da je ispod 2000 obrtaja. 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted November 30, 2020 TermostatПослато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted July 14, 2021 Dobro je, mislio sam da se ujutru bacim u vadjenje starog termostata, izgleda da me on zeza, ne otvori skroz...ali sam pročitao temu... Ipak ću ostaviti auto majstoru pred radionicu... Sent from my Redmi Note 8 Pro using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7735 Posted July 14, 2021 Zbog?Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted July 15, 2021 Danas kad se zagrejao ja stanem i vidim da je boca za antifriz puna do čepa, ja ugasio klimu a on posle par sekundi odvuče antifriz u hladnjak...ne znam zašto je tako odreagovalo...Ali sam sad video i da su izgoreli džekovi na reostatu, pa on ne upali uvek ventilator na prvu brzinu...to ću da očistim i da zalemim malo.Taman imam i pitanje.Na hladnjaku ima dva šrafa za odzračivanje.Na ovom desnom (bliže termostatu) voda izbije u mlazu kad ga odvrnem...ali na onom sa leve strane ne izbija voda...izašlo par mehurića i to je to... Ugrejan je sistem bio skroz i vidi se da ima antifriza tu, samo ne izbija.. Sent from my Redmi Note 8 Pro using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted July 15, 2021 da se nije malo zapušio hladnjak ? Smanjio protok ? U kakvom je stanju pumpa ? Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted July 15, 2021 Pa izgleda da je negde smanjen protok...e sad gde je ne znam...Sredio sam džekove na reostatu, istopili se načisto, jedva očistih one pipke...stavio buksne i zalemio sve lepo... Bolje je ali ima tu još neki problem, verovatno skuplji... Sent from my Redmi Note 8 Pro using Tapatalk Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted July 31, 2021 Čitajući forum pomislih da je naučna fantastika izvaditi termostat iz kućišta izvadio za pola sata... Sad samo da vratim sve pa da vidim šta će biti... Quote Share this post Link to post Share on other sites
