milan-jtd 319 Posted May 8, 2014 Imam ja neku mapu madjarske, ako hoces daj mail da ti saljem, iz 2011. je, nije bas sveze ali ako se ne snadjes... Quote Share this post Link to post Share on other sites
razor_amd 0 Posted May 8, 2014 Sad cu da zapakujem mapu pa ti okacim, najsveziju od TopMapa i HERE-a. Pozz Quote Share this post Link to post Share on other sites
underground79 19 Posted May 8, 2014 Evo imam ja iz marta 2013.. https://www.dropbox.com/s/4h010pizz44v7vu/Hungary_83_TM_2013.03_130312.fbl Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted May 8, 2014 Probaj odavde 2013 Q3 trenutno ih koristim http://kickass.to/igo-r3-here-2013-q3-europe-truck-map-t8931624.html Quote Share this post Link to post Share on other sites
razor_amd 0 Posted May 8, 2014 Evo komplet sve za Madjarsku i od TopMap i od HERE-a. Unutra imas i building i poi i mape i dodatno jos nesto... Skidaj sta ti volja... Pozzhttp://www.mediafire.com/download/45v073nf2gzod61/Madjarska.rar Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted May 14, 2014 Fala drugari! Ne znam na kraju sta sam skinuo jer je bilo kasno uvece. Uglavnom je ta odradila posao za sve pare. U stvari ovo su ti fajlovi : Quote Share this post Link to post Share on other sites
Iggy NS 0 Posted June 16, 2014 Pozdrav!Imam pitanje: Imam telefon LG L7. Kod mene je oko dve godine...Sve radi ok, neke vece probleme nisam imao, instalirao sam i Igo primo, mape iz 2013, itd...E sad, pre par dana mob se update-ovao preko LG Support Tools-a na 4.1.2., verzija 20c...Ima novina i novih ikonica, ali sad mi ne radi Igo...Deinstalirao sam ga, ubacio ponovo i on opet ne radi, ni da krene...Izbacio poruku: "global_cfg not found", drugi put kaze da rezolucija ne valja...Sta da preduzmem? P.S. Uzeh u Vipu ovu Lumiu 630 pre 10 dana, pa bas bih da uporedim Igo i Here drive + kako rade...Hvala Vam Quote Share this post Link to post Share on other sites
razor_amd 0 Posted June 16, 2014 Imali smo problem da za L7 nadjemo verziju iGo-a koja radi, i meni se desilo da kod 2 drugara nije hteo ni jedan iGo koji sam imao. Konacno smo nasli verziju koja radi, ako se ne snadjes u medjuvremenu, cim je pronadjem, uploadovacu ti i postavljam link... Quote Share this post Link to post Share on other sites
Nidzo 2 Posted June 16, 2014 (edited) Iggy poslao sam ti iGO pa probaj. Obriši staru verziju i folder iGO.Izašle se nove TomTom mape 2013.12Contrast, kako se priča, napušta ovu priču sa mapama za iGO. Edited June 16, 2014 by Nidzo Quote Share this post Link to post Share on other sites
Iggy NS 0 Posted June 16, 2014 @Razor, skinuo sam sve one fajlove koje ste postavili u cloudu na 17 strani, ne radi mi ni jedan, sve nesto kao krene, pa stane i izbaci ili mu nesto fali...Hvala Vam mnogo na trudu i ponudjenoj pomoci... @Nidzo, hvala i Vama na poslatim Igo-ima ... Skinuo sam oba, instalirao sam samo prvi, proradio je...Treba mu vremena da nadje satelite,,,Ovaj dugi cu da cuvam za rezervu i za svaki slucaj...Dodao sam nesto mojih mapa, poi-a, kamera...Jos samo da uporedim kako rade obe... Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted June 16, 2014 Imao sam i ja problema sa nalaženjem satelita i to posle fabričkog update-a androida. Prvi put ih je našao za oko 1 min, posle toga još brže, nakoj update-a nije mogao ni posle pola sata, nađe on 10 kom ali navigacija ne radi. Burazer je samo rutovao tel. i sve je profunkcionisalo. Znači za tren je našao i navigacija radi. Nidžo šta ima novo sa kartama ? Quote Share this post Link to post Share on other sites
Nidzo 2 Posted June 16, 2014 Nisam ništa primjetio ali ispravljene su neke greške kojih je bilo u 2013.09. Ajde postaviću je negdje pa ću ti pustiti link. Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 18, 2014 (edited) Pozdrav drustvo !!!Treba mi pomoc, imao sam instaliran iGO na http://www.mobilnisvet.com/mobilni/3489/Samsung/Galaxy-S-Duos-S7562 telefonu i radio je dobro, brzo nalazio satelite itd...Kada sam hteo da instaliram iGO i na drugarovom telefonu, skidao sam mape sa mog i moj se iGO zaglupeo i nece da radi/pokrene...Brisao sam folder, deinstalirao, ponovo instalirao, ali nece...Imate li neku noviju verziju ili proverenu koja bi radila kod mene.Voleo bih da proradi, ali moguce da su ostali repovi od starog iGO-a...Ima li neki nacin da se sve od starog izbrise pa da se krene iz pocetka? Pozdrav i hvala... Edited June 18, 2014 by pedjabj Quote Share this post Link to post Share on other sites
underground79 19 Posted June 18, 2014 Najnoviji iGo.. Iskopiraj folder i startuj 'changed' apk.. Ako ne radi kako treba, cimaj pa cu ti izmeniti sys.txt... https://www.dropbox.com/s/mdnh79o0qlgim8g/iGO.rar Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 18, 2014 (edited) Hajde da krenem iz pocetka, da procita jos neko ako ima problem kao i ja...Da deinstaliram moj stari, koji je u telefonu i koji ne radi, iGO?Folder, raspakujem i snimim na sd karticu?Pokrenem "changed".apk, (ok?), ali ima dva, koji bas?Davim, znam, ali hajde da probam... Edited June 18, 2014 by pedjabj Quote Share this post Link to post Share on other sites
underground79 19 Posted June 18, 2014 (edited) Deinstaliraj stari, obrisi stari igo folder, iskopiraj moj i startuj instalaciju koja ima sufix changed.. Druga nije changed vec 'not changed' Edited June 18, 2014 by underground Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 18, 2014 Hvala...instalirao i radi...nije nasao satelite, ovde gde radim je zeznuto, ali cu i to javiti kada se desi...Mogu li dodati Grcku, Makedoniju, Bugarsku i Madjarsku?Da li cu nesto zeznuti posto sam bas tako i zekio...Imas li te sveze mape?Mogu li i drugaru instalirati s'tim da je njegov 7582, iste rezolucije?Hvala ti i dubok naklon... Quote Share this post Link to post Share on other sites
underground79 19 Posted June 18, 2014 Nema na cemu ! Mozes sve da ubacujes : mape, poi, voice, lang.. Sve radi.. Ako nekom treba mogu i mape da spakujem. Instalacija je koliko ja imam iskustva univerzalna, samo na nekim tabletima treba promeniti malo sys.txt... Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 18, 2014 (edited) Ako ti nije tesko i ako nije cimanje, spakuj ove mape za koje sam pitao, kapiram da ce ljudima letos pomoci...mozes da dodas i Bosnu, Tursku i Crnu Goru, pa da ljudi koji planiraju letovanja te ne cimaju kao ja za svaku zemlju ponaosob...Naravno za mene nije hitno, ali sezona uskoro krece...Kada vec pomenu tablet, mogu li da instaliram i na njega, cisto da vidim kako izgleda?Ali to tek kada dodjem kuci i napise model. ps...Citao sam unazad i nasao Madjarsku, ali ako ti nije cimanje napravi paket od ovih pomenutih drzava i ima da budes najomiljeniji lik letos ovde na forumu :-) !!! Bugarska vec pomenuta, greskom sam napisao drugi put nju, mislio sam dodati jos i Bosnu, Tursku i Crnu Goru... Edited June 18, 2014 by pedjabj Quote Share this post Link to post Share on other sites
underground79 19 Posted June 18, 2014 (edited) mape:srbija https://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Serbia_83_Contrast_2012.07_120910.fblgrckahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Greece_83_Epsilon_2012.07_120910.fblmakedonijahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Former_Yugoslav_Republic_of_Macedonia_83_Navigo_2012.07_120910.fblcrna gorahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Montenegro_83_Contrast_2012.07_120910.fblmadjarskahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Hungary_83_TM_2013.03_130312.fblBiHhttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Bosnia_Herzegovina_83_Navigo_2012.07_120910.fblsloveniahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Slovenia_83_Monolit_2012.04_120626.fblhrvatskahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Croatia_83_Navigo_2012.07_120910.fblbugarskahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Bulgaria_83_MMCN_2012.07_120918.fblturskahttps://dl.dropboxusercontent.com/u/382795/igo%20new/mape/Turkey_83_Basarsoft_2012.10_121212.fblpoihrvatskahttps://dl.dropboxusercontent.com/u/382795/igo%20new/poi/Croatia_Navigo_2012.07_120726.poimakedonijahttps://dl.dropboxusercontent.com/u/382795/igo%20new/poi/Former_Yugoslav_Republic_of_Macedonia_Navigo_2012.07_120726.poicrna gorahttps://dl.dropboxusercontent.com/u/382795/igo%20new/poi/Montenegro_Contrast_2012.07_120924.poi Ovo su mape koje ja imam i koristim .. Nisam siguran da su sve najbolje i sa najvise detalja.. Uvek mozete imati 'backup' mapu, pa ako jedna ne radi kako treba iskopirati drugu u isti folder igo/content/map ... isto vazi i za poi ja uvek pred put skinem sve moguce mape za odgovarajucu zemlju/zemlje i probam sve mape.. sve zavisi gde putujete i u koji deo odredjene drzave .. SRECAN PUT Edited June 18, 2014 by underground Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 18, 2014 Hvala !!!Bugarska i Turska ??? Quote Share this post Link to post Share on other sites
underground79 19 Posted June 18, 2014 ubaceno .. Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 18, 2014 H V A L A !!! Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted June 18, 2014 (edited) Šta se mučite, ovde su vam svežije mape. Koristim ih i sasvim su OK, čak mi je za nijansu bolja od Contrast 2012,07. Ovde je torent pa izaberite koje zemlje hoćete. Probajte. Meni se čine o.k. za ovo područje kojim se ja švrljam i koliko koristim navigaciju.Zadržite i staru Contrastovu samo je prebacite u drugi folder ili je preimenujte u npr. Srbija.fbl.bakiGO_2013.Q3_HERE_Europe_Maps.rar Evo i svežijih Here 2013.Q4 http://kickass.to/igo-2013-q4-here-europe-maps-t9140941.html Srbija preko 10 MB Edited June 18, 2014 by ivan.ik Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 18, 2014 Ja ne znam da skinem sa tog linka... Quote Share this post Link to post Share on other sites
