OlyPk 0 Posted March 17, 2016 Pre nekoliko dan mi se upalila lampica za airbag odnosno pise STOP ENGINE AIRBAG FAILURE. To se desavalo i pre ali se gasila a sad nece da se ugase. Isao sam kod majstore na dijagnostiku i pise da je previsok pritisak u bocnom vazdusnom jastuku kod vozaca. Sta je najbolje da uradim ako neko moze da mi pomogne? Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted March 18, 2016 Možda otpor a ne pritisak. Dakle konektor/i idpod vozačevog sedišta. Quote Share this post Link to post Share on other sites
OlyPk 0 Posted March 18, 2016 Jel ima neko u blizini Prokuplja ko zna to da mi resi da ne petljam sam? Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 18, 2016 Mića ima veliko iskustvo. Quote Share this post Link to post Share on other sites
DaliborLazarevic 4 Posted March 18, 2016 @OlyPk Ispod sedišta imas 3 dzeka uzmi raskaci i naprskaj malo kontakt sprej i vrati nazad.Ako i dalje imas upaljenu lampicu onda idi kod majstora. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 18, 2016 Ispod vozackog sedista su 2 dzeka, narandzasti je airbag. Tri dzeka su u verziji sa OCS pre restyle i to samo na suvozackoj strani. Mica je cuveni ekspert za trudnicu na tabli . Quote Share this post Link to post Share on other sites
OlyPk 0 Posted March 18, 2016 Mica elektricar u Novo naselje? Jel na njega mislite? Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 18, 2016 Izvini, salimo se malo interno, mislimo na naseg jedinog i neponovljivog @MS PK . Voli trudnice, pa nek su i na tabli. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted March 18, 2016 @Ivan A gledaj show sad, i ja sam Mica i ja sam autoelektricar i jednu ulicu sam ispod njega Trudnice ne diram Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 18, 2016 On kad upali tu nema gašenja. Quote Share this post Link to post Share on other sites
DaliborLazarevic 4 Posted March 18, 2016 a kada ugasi onda ga je ugasio hahahahahahah Quote Share this post Link to post Share on other sites
OlyPk 0 Posted March 18, 2016 Resen problem. Samo sam izvadio i vratio onaj dzek ispod suvozacevog sedista i ugasila se lampica. Izgleda ima neki prekid ali bitno je da znam sta je. Videcemo da li ce opet da se upali. Pozdrav Quote Share this post Link to post Share on other sites
DaliborLazarevic 4 Posted March 18, 2016 odlicno bitno da je reseno Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 18, 2016 (edited) Nije u pitanju prekid, nego promenjena otpornost na koju Comp reaguje. Posto sam znao da ce auto biti duze kod mene i da necu menjati sedista, ja sam te dzekove totalno izbacio i direktno prevezao i zalemio zice. Od tada godinama ni jedan problem sa kontaktima ispod sedista. Kupe je problematican jer se sedista non stop krljaju napred-nazad. I ja sam se pre nedelju-dve pridruzio Mici sa trudnicom, pa treba da resavam to. Nisam kacio auto na dijagnostiku, ali mislim da mi se zabola Airbag centrala. Flesovanje 20-30 EUR, polovna centrala kod Pedje u Indjiji 1000 kinti (pisem ako nekome zatreba info). Nova je kostala cca 200 EUR, Stilo srpski Bogotac za odrzavanje. Ne znam kako ljudi mogu da trpe ono pistanje i crvenu lampicu na tabli i teraju tako godinama . Edited March 18, 2016 by Ivan Quote Share this post Link to post Share on other sites
Markobgd 609 Posted March 18, 2016 Zar nisi to skoro flešovao centralu? To se često dešava ili? Neki teraju godinama i bez brisača Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 19, 2016 Mića je bar siguran da ima jastuke. Ime, możda centrala registruje pomeranja sedišta kao i ritmične oscilacije. Quote Share this post Link to post Share on other sites
Robin Hood 0 Posted March 19, 2016 A jel' mogu da vas zamolim da izmenite naslov ove teme? Užasno me nervira! Airbag-a ili erbega Quote Share this post Link to post Share on other sites
mikesha 0 Posted March 19, 2016 Zdravo I ja sam nekoliko puta vadio i prskao dzekove ispod suvozacevog sedista, ali bezuspesno. I dalje signalizira i pisti greska Airbag. Nisam vozio kod majstora da vidimo koja je greska, to bih trebao da proverim u ponedeljak. Ali kako mi se čini , sve miriše na senzor sedista. Da li moze jos nesto biti osim senzora i dzekova? Pozdrav Quote Share this post Link to post Share on other sites
lakicevicboris 7 Posted March 19, 2016 Pa postoje dzekovi i ispod vozacevog sedista, postoje dzekovi u kaseti ispred suvozacevog sedista. Treba ih sve raskacit, naprskat kontakt sprejem, i mozda malo zenske delove dzeka stegnut da bude bolji kontakt Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 20, 2016 Hoće i same žice da popuste. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 20, 2016 On 18.03.2016. at 3:01 PM, Markobgd said: Zar nisi to skoro flešovao centralu? To se često dešava ili? Jesam, pre oko godinu i kusur, bas u ovom periodu kada je bilo hladno i vlaga. Nisam kacio auto jos na dijagnostiku, ali nesto tipujem na nju. Ako jeste opet ona u pitanju, ocigledno da ima neki zez, u tom slucaju bih je zamenio. Em je kod Pedje bagatela za Vajferta, jeftinije i pametnije nego da radim opet flesovanje. Samo nisam siguran da li moze prosto da se zameni (fizicki je lako, za pod je drze 3 srafa i ima dva konektora) ili mozda mora da se odradi i Proxy... Quote Share this post Link to post Share on other sites
Markobgd 609 Posted March 20, 2016 A tebi je inače taj proxy baš kritična stvar....nikako nisi u materiji Quote Share this post Link to post Share on other sites
nemanjas 0 Posted March 20, 2016 meni je receno za centralu airbaga da ne treba nikakva podesavanja samo je udzekas,ali je jako bitna stvar da ne kupis centralu koja je ispucala airbagove,i da kupis sa novijeg modela gde nema ocs senzora Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 21, 2016 Ako bih menjao, uzeo bih naravno identicnu po serijskom broju kao trenutnu. A u takvu kupovinu je pozeljno ici sa dijagnostikom. Quote Share this post Link to post Share on other sites
