abarth
    262
About abarth
  • Birthday 05/02/1975
  • Website URL
    http://
    NS
    Lancia Delta 1.9 TT
4843 profile views
  1. na prodaju najbolja verzija delte, uvezen iz švajcarske pre 2 godine na točkovima, utegnuta, servisirana redovno, veliki servis urađen pre 10k km, zamajac i set kvačila pre 4k km, nema ulaganja, led svetla, 2 ključa. knjige, malo oštećenje na desnom zadnjem blatobranu. zimske gume na 17 felnama i letnji set na 18 felnama. 2010. god 189000km NS tablice, registrovan do 06/26 5450eur tel 0641254846
  2. Zamajac i set kvacila sa druk lezajem. Novo, neotpakivano. Za fiat bravo 2.0 mjet, lancia delta 2.0 mjet, 1.9tt, alfa . .. 600eur 0641254846
  3. Pa naravno da ne rade sve vreme. Po logici stvari rade u leru po potrebi, a ja sam upravo tu osetio razliku.
  4. During the combustion process, if the combustion cycle doesn’t meet the required temperature, not all of the fuel will burn. The unburnt fuel becomes carbon particles, which are harmful to the environment, and are released into the atmosphere via the exhaust. In order to avoid this scenario, glow plugs are used to heat up the air and ensure that the correct temperatures are reached, so all the fuel is burnt and harmful emissions are reduced. If a car is driven at high speeds for a long distance, for example on the motorway, the continuous and stable heat flow from the exhaust is sufficient to clean up the DPF. The heat will burn any unburnt remains of the soot particles. But if the car is driven at low speeds, frequently stopping and starting, for example in cities, there is not enough heat for DPF regeneration. In this case, the ECU activates the glow plugs and injects additional fuel into the engine, which ignites and heats up the DPF, so regeneration can take place. Kao što rekoh, nije bilo greške grejača i regeneraciju je uspevao da završi samo ako se vozi na malo višim obrtajima, a u gradu sa stani kreni nikako.
  5. Kod starih dizela grejači su samo za startovanje, a kod novijih (sa dpf) grejači se koriste stalno za podizanje temperature sagorevanja. Novi grejači rade na ~4v i postižu temperaturu za manje od 2 sec.
  6. Rešeno. Zamenio sva 4 grejaca. Sa starima nije bilo greške i imaju normalan otpor ali eto ipak ne rade kako treba. Sada auto lepše radi i čak bolje povlači iz niskih obrtaja.
  7. Nema gresaka, odradi regerenaciju normalno ali ler bude jako nestabilan u toku regeneracije i cuju se kao neke male detonacije. Sve bude normalno kad se gas drc pritisne da poveca ler bukvalno 100 obrtaja. Proveravao sam i grejace jer oni navodno rade u toku gradske regeneracije, cistio egr, map, maf... Svi parametri su u ocekivanim vrednostima, korekcije dizni, pritisak goriva i ostalo... Ako neko ima pametnu ideju, a da nije skini govno od dpf i egr.
  8. Dogovor oko cene zbog skorog isteka registracije...
  9. 3300eur bez letnjih felni...
  10. 3400eur bez letnjih felni...
  11. Fiat Bravo 1.6 Multijet dizel, 2009, 238500km, 120ks, dugogodišnji vlasnik, redovno održavan i servisiran, bez ulaganja, zamajac promenjen pre 20000km, dpf ispravan, zimske gume na original felnama 17, 2 kljuca, Emotion najviši nivo opreme (vidi sliku sa spiskom), par sitnih tragova od parkinga. Letnje gume na Schumacher felnama 17 sa distancima 20mm i srafovima (doplata 200eur) 3500eur 0641254846 NS http://www.polovniautomobili.com/auto-oglasi/21524048/fiat-bravo-16-multijet-emotion
