zrnke 41 Posted January 27, 2015 Hahahahaha, to DPF sluzi da susi odozdo kada je mokro, da ne korodira Quote Share this post Link to post Share on other sites
007 milanče 0 Posted January 27, 2015 (edited) POzdrav drugari, Našao sam na internetu firmu DPF.rs, zvuče dobro ali..., zanima me vaše iskustvo sa njima. Da li je neko saradjivao sa njima i koliko vredi to što oni odrade. Pomalo sam skeptik a opet ne bi da skidam filter. Pomozite da prelomim (u mozgu) Pozdrav svima Edited January 27, 2015 by 007 milanče Quote Share this post Link to post Share on other sites
golf sdi 2 Posted April 20, 2015 Ima li neko ideju,koju tečnost sipati da bi se u kućnoj radinosti očistio dpf filter.Skinuo sam, potopio u sonu kiselinu 24 sata,potom kerserom isprao, ali bez nekih poboljšanja. Quote Share this post Link to post Share on other sites
mihajlovic11 1 Posted April 20, 2015 Kako si zakljucio da nema poboljsanja ? Quote Share this post Link to post Share on other sites
golf sdi 2 Posted April 20, 2015 (edited) I dalje prijavljuje grešku začepljenosti dpf-a, lonac dpf-a se više zagreva,u nekim trenucima sam podigne obrtaje i tad dimi.Auto je bratov, Grande punto 1,3 mjt 90. Pre čišćenja zapušenost izmerena dijagnostikom, 130%. Edited April 20, 2015 by punto jtd Quote Share this post Link to post Share on other sites
mihajlovic11 1 Posted April 20, 2015 Probaj da mu preko dijagnostike uradis prisilnu regeneraciju. Quote Share this post Link to post Share on other sites
golf sdi 2 Posted April 20, 2015 To sam prvo probao. Quote Share this post Link to post Share on other sites
mihajlovic11 1 Posted April 20, 2015 Jel nece da je pokrene ? Ako je pokrene trebalo bi da ga ocisti,mada zacepljenost 130% i nije tako strasno. Quote Share this post Link to post Share on other sites
golf sdi 2 Posted April 20, 2015 Nece da pokrene,inače ne bi skidali i pokušali čišćenje. Quote Share this post Link to post Share on other sites
mihajlovic11 1 Posted April 20, 2015 Sa kojim uredjajem si pokusavao da pokrenes regeneraciju ?Trebalo bi da odes u neki krsteniji servis koji ima examiner dijagnostiku i sa njom bi trebalo da resis problem. Quote Share this post Link to post Share on other sites
golf sdi 2 Posted April 20, 2015 Auto nije registrovan,treba da se proda (na ime kupca),pa ne mogu van Smedereva,a probali smo običnom dijagnostikom kod majstora koji to često radi.U svakom slučaju hvala, raspitaću se sutra da li ima neko examiner u SD-u Quote Share this post Link to post Share on other sites
Elra 204 Posted June 27, 2015 (edited) Danas mi se na Doblo Cargo 1.6 Multijet upali check enginee lampica i auto izgubi snagu. Preko 3500 o/min nema sanse da ce da ode. Vozio sam ga 20ak min na maksimumu (4 brzina, 3500 o/min) i onda "procepi".Nakon toga odem kod majstora na dijagnostiku, kaze DPF je bio zacepljen 53%, sada je dosao na 19% i to je kao OK.Inace Doblo je presao cca 78000 km i do sada nije bilo problem sa DPF. Majstor je jos gledao pritisak na usisu turbine i kaze da je oko 0.2 milibara veci nego sto bi trebao da bude, te bi i to mogao da bude uzrok zacepljenja. Edited June 27, 2015 by Elra Quote Share this post Link to post Share on other sites
knezilija 0 Posted September 17, 2015 Imam pitanje za upucene.Da li kad se radi uklanjanje DPF-a EGR ostaje u normalnoj funkciji? Da ga motorni racunar vidi i kontrolise.Zeleo bi da skinem DPF a da EGR ostane u normalnoj funkciji kao i do sada .Zvao sam jednog majstora koji to radi iz Zrenjanina i kaze mi da se gasi i jedno i drugo, tj egr ostane u zatvorenom polozaju i to je to, permanentno.Da li moze da se izvede da egr radi ? Quote Share this post Link to post Share on other sites
golf sdi 2 Posted September 17, 2015 Može odvojeno da se fizički i softverski ukloni DPF,a EGR da ostane u funkciji. Quote Share this post Link to post Share on other sites
cileee 1 Posted September 17, 2015 Zna li neko gde mogu da kupim tecnost za regeneraciju FAP-a za Ulysse-a. Ostalo je jos nesto malo i stalbo mi prijavljuje gresku da trebam da dobijem, ajde da je to neka deseta lampica nego glupi francuzi guraju sve u check i stalbo mi sija. Uzeo bih onu za 150k km, a moze i ona za 80k...koja se pre nadje. Zvao AP sport, corak. Zvao Kit, corak 2. Ne znam gde da trazim...nisam zvao za PSA delove. Secam se da je jednom Totti okacio negde na forumu link ka toj tecnosti ali ne mogu da ga nadjem. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted September 18, 2015 Potrazi adblue na pumpi Quote Share this post Link to post Share on other sites
skile86 539 Posted October 12, 2015 Da li moze prilikom regeneracije DPF-a nekim cudom da dodje do variranja ler gasa?Danas mi se to desilo prilikom povratka sa posla prvi put.Dijagnostika prijavljuje da je regeneracija odradjena otprilike u tom periodu...Inace ocistio ga je za sve pare. Obicno se vrtelo od 40-60% zapusenosti, a sad je na 12%. Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted November 7, 2015 jel moze neko nesto vise da mi kaze? jel ok da se ovako cesto regenerise? izgleda da je fabricki dpf na njemu.. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted November 7, 2015 Skroz ok. Quote Share this post Link to post Share on other sites
skile86 539 Posted November 7, 2015 Meni radi i cesce, na nekih 200km u proseku.Doduse 99% je voznja u gradu, pa se verovatno zato i brze prlja. Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted November 7, 2015 znaci mogu da ocekujem uskoro da se regenerise, presao je skoro 350km Quote Share this post Link to post Share on other sites
Markobgd 609 Posted November 7, 2015 (edited) Zašto uopšte vodiš brigu o tome, ako je ispravno sve nemaš ni pojima kad radi regeneraciju niti to treba da te interesuje.Zna da je uradi i dva puta u manjke od 100km a i da je ne uradi po 500km. Zavisi od mnogo faktora. Dok te ne upozorava da moraš da je uradiš sve je ok. Ne brini brigu! Edited November 7, 2015 by Markobgd Quote Share this post Link to post Share on other sites
bojankov 36 Posted November 7, 2015 Ima li grande punto 1.3 dpf? Quote Share this post Link to post Share on other sites
golf sdi 2 Posted November 8, 2015 Zavisi od od od godine proizvodnje,opreme... Recimo moj od 75 ks 2007 god. nema, a pre par meseci sam prodao jednog isto godište ali sa 90 konja i on je imao, i ta glupost me je baš namučila dok ga nisam fizički i softverski uklonio. Quote Share this post Link to post Share on other sites
