neshtry 14872 Posted January 27, 2018 On 1/27/2018 at 12:43 PM, dejan_ns said: Sta hoces da kazes tim sa imas PUS motora? Da ces spakovati stranca, ukucati u sopstvenoj reziji taj broj i sve to javno reci na forumu? Nije isključeno. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 27, 2018 On 1/27/2018 at 12:54 PM, Djuk85 said: Jel to vazi za td motore na marei? Ne. Za taj se dobro spremi kad otvaras Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 27, 2018 Mnogo si mi pomogao Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 27, 2018 Hahaha pa takav je, nikakav Konusne kompresione karike pa oce i u klip da rasiri leziste, obrise i hilzne obicno pa se nakupi posao. Mogu da se obrade klipovi pa da se stave obicne karike, radili su ljudi to bez problema. Ja nisam hteo pa sam se nekada davno otvorio samo za garnituru klipova 500eur. Bio budala Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 27, 2018 Jbg steta, sve na autu je ekstra, dobro ocuvano.. Al taj motor..nisam se raspitao pre kupovine.. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 27, 2018 Ne znas dok se ne rasturi, ne mora da znaci Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted January 27, 2018 5 hours ago, snebojsa said: Znaci mislis da bi, najverovatnije, bilo dovoljno zameniti karike, gumice ventila, letece lezajeve, obraditi glavu, plus sve propratno sto ide tipa ulje, filter, dihtunzi, antifriz...? Obicno bude tako... Quote Share this post Link to post Share on other sites
neshtry 14872 Posted January 27, 2018 Ja sada video da mi curka ulje...Parkirao sam na betonu da proverim.U ponedeljak kod majstora dok nije kasno! Blato na sve strane pa se ne vidi. Quote Share this post Link to post Share on other sites
Trofeo 115 Posted January 29, 2018 Na takvim autima Punto,bravo itd koji se vrte oko hiljadarke,se ne isplati raditi generalnu pa cak ni osvezenje.. Odes lepo na otpad upalis proveris dal' duva,izmeris kompresiju itd.. pa cak i proteras auto.Ako je sve ok platis 100e motorce i bog da te vidi... Racunaj jos oko 70-100e Izbacivanje-ubacivanje i za 200evrica samo gas... Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted February 1, 2018 Ja bi ti dao 300e da uradis sve to na mom autu 100e bi ti ostaje za trud Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 1, 2018 @Djuk85 Meni kazes? Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 2, 2018 (edited) Mislim da je motor za brava isto kao i za punta 100e,ali nemoj me drzati za rec. Za punta znam provereno da je 100e. ti kazes dajes 300. 100 motor i 200 ruke? Za te pare ima majstor da te doceka sa mezetinom i pivom Pitaj bilo kog majstora koliko kosta izbacivanje- ubacivanje motora na puntu i slicnim autima.Preko 100e ne bi smelo da ide sem ako je neko magarac ili pun para a majstor prevarant Edited February 2, 2018 by Trofeo Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted February 2, 2018 A kako cete za broj motora? Quote Share this post Link to post Share on other sites
neshtry 14872 Posted February 2, 2018 Kod Peđe i Nenada(Inđija) je od 120€ motor za punta sa papirima,kaže svejedno da li je 8v ili 16v...Jesenas sam ga pitao. A broj motora je jedva vidljiv, uz doradu može PUS.... Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 2, 2018 @Goran Zemun Ma pricamo za ubacivanje,legalnost je vec druga stvar ja tvrdim da sa 200e se resava problem za punto 1.2, covek eto nudi 300 za Mareu... @neshtry Kod Pedje 100e punto 1.2 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted February 2, 2018 Pedja mi je rekao 150e bez kartera,klot motor... Quote Share this post Link to post Share on other sites
Axic 20048 Posted February 2, 2018 Kakva glupost prodavati motor bez kartera.  Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 3, 2018 (edited) @Djuk85 A koji motor je u pitanju? i pricamo o klot motoru Edited February 3, 2018 by Trofeo Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted February 3, 2018 1.9td 100 Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 3, 2018 Korektna cena za dizelku... Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 8, 2018 On 2/2/2018 at 5:01 PM, neshtry said: A broj motora je jedva vidljiv, uz doradu može PUS.... Samo što se svih mogućih ''dorada'' dobro naaaaagledao čika iz MUP-a, plus ima i razne neke tečnosti i lampe da može da vidi dosta stvari koje se golim oko ne vide...tako da je veoma teško to progurati tek tako. A, kada uhvate za to onda isto ide kažnjavanje i ako je rađeno na Ferrariju i ako je na Puntu. Quote Share this post Link to post Share on other sites
neshtry 14872 Posted February 8, 2018 Da je to tacno ne bih ni ja mirao da kucam PUS...Ne bi ni postojao PUS(rece mi covek sto kuca PUS) Quote Share this post Link to post Share on other sites
snebojsa 56 Posted June 2, 2018 Ja samo da javim sta sam uradio. Nista Dok sam razmisljao sta cu, reko aj da probam neko drugo ulje, uzmem najjeftinije, Dynamax 10w40, oko 400din/lit. Sa njim se smanjila potrosnja, drzi se na oko 500gr/1.000km, evo vec par hiljada tako. Bude malko vise ako duze vozim na otvorenom nego po gradu. Dobio sam par saveta da probam sa nekim guscim uljem, sta mislite o toj ideji? Posto vec reaguje na promenu ulja, verovatno bi sa guscim trosio jos manje, ali koliko je to dobro za motor, stavljati ulje koje nije preporuceno od strane fabrike? Ako bih stavljo gusce ulje, neka preporuka? Quote Share this post Link to post Share on other sites
Home 56 Posted June 2, 2018 Ti nemaš motor, sipaj šta hoćeš, dolaziš na isto. 1 1 marko.jovanovic and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
