Lj_ubica 78 Posted December 27, 2017 Tako nekako... Sredjujem i ja stalno, a sto vise racuna vodim to gore... Ko Marfijev zakon neki... Bruka... Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted December 27, 2017 Pa to, volim da je sve kako valja Znam ljude i ulje menjaju kad se sete samo i nekad nemaju problema Quote Share this post Link to post Share on other sites
Martin 799 Posted December 27, 2017 Ovo ti je i prilika da odradiš zvučnu izolaciju odozdo. Quote Share this post Link to post Share on other sites
bole-stilo.jtd 374 Posted December 28, 2017 samo polako , sve moze da se sredi ali sve zavisi i od budjelara ........... nek smo mi ok , kola ce se srediti ............. Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted December 29, 2017 (edited) Naravno, dosta stvari sto se kola tice zavisi od budjelara... Al jbg... Polako samo... Od izloacije nista... Da ja prvo zakrpim ove ventilacione otvore... Kaze majstor, blata nema, lupana nije... Kako je ovo satrulilo nije mi jasno... Edited May 5, 2019 by neshaoct sredio slike Quote Share this post Link to post Share on other sites
gorank82 183 Posted December 29, 2017 Ima li napretka ? Kazu da Fiat ne truli :-) Quote Share this post Link to post Share on other sites
bole-stilo.jtd 374 Posted December 29, 2017 (edited) moja fiat brava 1999 god. 1,6 benzin je isto ovako pocela na sve strane (ali mnoooogo manje) da pokazuje znake i to odjednom pre 5-6 god. , zato je i otisla , a evo stilo 2002 nema nista na njemu ali nista , ni tackicu od dole rdje , sve fabrika , nista mazano niti dirano ............ e sad zasto i kako ne znam. spolja je bila ekstraaa (slika dole) - vozena 8 ili 9 god. kod mene ............ ali kad je pocela oko solja napred da pokazuje - bilo je caorina ............. Edited December 29, 2017 by bole-stilo.jtd Quote Share this post Link to post Share on other sites
Martin 799 Posted December 29, 2017 (edited) Evo jedan nutscape od mene Kada okrpite limariju, ide zaštitni sloj, koji je debljine po nekoliko mm (recimo oko 4-5 mm). Potrebno je tu zaštitu (bitumen ili kako li se već zove) navući spolja i iznutra. I onda se dobija veća zvučna izolacija. Fabrički je to urađeno samo spolja. Pocinkovan lim a zašto truli - zato što svaki lim truli - neki brže a neki sporije i toeto. Obavezno obrati pažnju na stanje kočionih cevi koje se nalaze na zadnjem mostu, jer se one nalaze između mosta i patosa, uštekane su, so vrlo lako dolazi do njih, a teško se ispiraju i vrlo lako istrule!!!! Edited December 29, 2017 by Martin Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted December 29, 2017 (edited) Truli i Fiat i svaki lim... Da ha hebem... Pocelo je krpljenje... Deluje pismeno... Bice to valjda dobro... Edited May 5, 2019 by neshaoct sredio slike 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted December 30, 2017 (edited) Ne mogu ja bez fiata... Dobio u firmi dok moj ne sredim. Palo generalno pranje, posto su ga jahali svi redom... 1.9jtd Edited May 5, 2019 by neshaoct sredio sliku 2 gorank82 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted December 30, 2017 Menjas se sa firmom Quote Share this post Link to post Share on other sites
darkman14 5901 Posted December 30, 2017 Kako je vama toliko istrulio auto? Kad pogledam ove slike, kod mene je odlično stanje. Ne znam da li zavisi do fabrike/serije ili šta već. Ja imam neku kao tačkicu na krilu gde je kamenčić zveknuo, a ovo pozadi u koševima i krilima je sve ok. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted December 30, 2017 Možda nisi virio dovoljno i gde treba Quote Share this post Link to post Share on other sites
gorank82 183 Posted December 30, 2017 Najviše zavisi gde je proveo radni vek najviše trule u Nemačkoj i Austriji mada i tamo ima sačuvanih... Quote Share this post Link to post Share on other sites
neshtry 14875 Posted December 30, 2017 Istine,moj je iz Nemačke,sav je izudaran od silne rizle.Odmah po registraciji sam sve odradio...bilo posla! Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted December 30, 2017 On 12/30/2017 at 3:01 PM, Markobgd said: Možda nisi virio dovoljno i gde treba Najbolji opis... I ja sam ziveo u zabludi do pre neki dan... Quote Share this post Link to post Share on other sites
Martin 799 Posted December 30, 2017 https://www.drive2.com/experience/fiat/g492/?to=131200789440256810 Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted January 3, 2018 (edited) Malo pauze pa se nastavlja... Edited May 5, 2019 by neshaoct sredio slike 2 neshtry and gorank82 reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted January 3, 2018 Kakvo je stanje ispod mosta? Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted January 3, 2018 Pravo da ti kazem ne znam. Nikako da odem do njega... Sutra sam planirao.. Pa cu videti 1 gorank82 reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted January 3, 2018 Ne, ne, ne - mislio sam na zadnji most, zadnja osovina, pa stanje patosa. Nikako onaj ispod kojeg teče reka. Kad ga već krpiš, okrpi sve - a na tom mestu sigurno ima nekih štekova. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 3, 2018 Ako postoje stekovi, tu su sa razlogom! Quote Share this post Link to post Share on other sites
marko.jovanovic 925 Posted January 3, 2018 (edited) Hm, koliku ti garanciju daje majstor? Ne sviđa mi se to krpljenje do pola sajtne. Ja sam zamenio kompletne sajtne. od točka do točka, i mislim da nisam pogrešio, ovaj moj majstor nije hteo da krpi. Doduše, nije bilo baš ni mesta gde da vari, pošto je sva bila trula. Edited January 3, 2018 by marko.jovanovic Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 3, 2018 Pa kad dodje do "zdravog" dela isto je ko i celu da menja Quote Share this post Link to post Share on other sites
