Irena HGT 2139 Posted August 13, 2016 Danas stavljeni novi zadnji diskovi i plocice, dihtung dekla ventila.. I zamenjena ona celjust sto nije valjala Toliko za danas, od ponedeljka se petljam sa alternatorom i anlaserom Quote Share this post Link to post Share on other sites
Dezurni 399 Posted August 13, 2016 Da li si menjala sajle ručne? Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted August 13, 2016 Ne, nisam stigla.. To cu sledece nedelje uz prednje diskove i plocice, svakako ce da mi stoji auto bez alternatora pa cu mu menjati i ulja, da pogledam dobro na sta lici auspuh i neke sitnice sto se tice limarije i ostalih detalja... Ako sve bude islo po planu, od sredine septembra moze i na neki skup kad bude bas sve kako treba. Quote Share this post Link to post Share on other sites
Dezurni 399 Posted August 13, 2016 Obavezno zameni sajle. Znaju da naprave problem čeljustima. A ti si već zamenila jednu. Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted August 13, 2016 Naravno... To sam videla kad sam gledala onu celjust koja je procurela, sajla je otisla skroz, ni ne vraca kako treba.. A diskovi i plocice, uzas, trulo i neravnomerno troseno.. Ma strasno. Quote Share this post Link to post Share on other sites
joshibeast 74 Posted August 13, 2016 Ja sam malo zbunjen. Jel ovaj HGT voze Irena ili Viktor? U svakom slučaju nek vas dobro služi i da se nauživate Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted August 13, 2016 Hvala HGT je samo moj Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted August 13, 2016 Viktor coupea, konacno nastelovanog Quote Share this post Link to post Share on other sites
MS PK 7735 Posted August 13, 2016 Znam, bas se hvali po forumu Quote Share this post Link to post Share on other sites
silenci 2337 Posted August 31, 2016 ja ovog punta vidjam po surcinu ako se ne varam, znam da je bivsi vlasnik iz surcina, al sve u svemu odlicno izgleda Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted September 1, 2016 Extra! Daj sliku enterijera, koja su to sedišta (ili samo jedno sedište) I pošto smo svi prijatelji na forumu, napiši koliko je šta koštalo do sada, nema razloga da krijemo troškove. Cene daj redovne, cene delova i koliko bi ruke koštale da se to uradi, pošto predpostavljam da dosta toga V radi. Quote Share this post Link to post Share on other sites
cvike19 53 Posted September 1, 2016 sta si skrt sa slikama ? Quote Share this post Link to post Share on other sites
bane17 24 Posted September 1, 2016 On 8/31/2016 at 8:40 PM, silenci said: ja ovog punta vidjam po surcinu ako se nevaram,znam da je bivsi vlasnik iz surcina,al sve u svemu odlicno izgleda sedista su obicna kao sa sportinga, samo su nasloni za glavu zamenjeni Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted October 8, 2016 Uf nikako ne stižem da se javim... Radi se stalno nešto oko auta... Zamenila sajlu ručne (Akron), prednje levo kočiono crevo (Ate) koje je puklo u vožnji i kočiono ulje, Valeo dot 4+.. I dalje nailazim na svašta. Sredila auspuh, stavila novu pletenicu jer od nje nije ostalo praktično ništa koliko ju je prethodni vlasnik kidao na putu. Prednji vezni lim je sređen i ofarban, branik koji je bio loše gitovan i farban je takođe šmirglan, gitovan i ofarban... Rešen problem sa variranjem obrtaja, problem je bio u žicama maf senzora i jedna dizna se raspala pa sam stavila novu. Nov Pro Atomic akumulator od 56 ah. Narućila kompletan enterijer od Sportinga da zamenim prednja sedišta koja su bila u očajnom stanju, izlomljena iznutra, loše varena i uopšte u krajnje lošem stanju... Promenila sam i motorno ulje, Total Quartz 7000 10w40 i filter ulja. Nabavila sam i dobar varijator, to čeka do velikog servisa. Oko limarije ima posla, krilo koje je bilo izudarano sam novo nabavila - treba samo da se ofarba... tako da za sad stoji. Takođe su sređeni i xenoni, morimoto projektori, polirani farovi... Za sad čekam prednje diskove i pločice i svećice da stignu... Biće i slika u narednih par dana Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted October 8, 2016 Dok sve sredis koliko li ce kostati na kraju? Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted October 8, 2016 Ne smem ni da stavim na papir sve stavke Ali planiram da ga zadržim, da ga sredim skroz, pa koliko bude, šta da se radi... Quote Share this post Link to post Share on other sites
PuntoAbart 2 Posted October 8, 2016 Svaka čast kada bi moja žena ovako vodila računa o kolima. Šta da se kaže osim jedno veliko poštovanje . Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted October 8, 2016 Zaista pohvalno, ne za zenu, za muskarca. Mnogi na forumu nisu tako pazljivi sa autom. Samo napred i da te sluzi kako si zamislila. Quote Share this post Link to post Share on other sites
silenci 2337 Posted October 8, 2016 svaka ti cast,sredila si HGT da bude u top stanju,dal je prethodni vlasnik skroz zapustio auto.Samo napred,Bravisimo Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted October 8, 2016 Pa hvala svima. Biće nešto od tog auta... Volim da radim oko njega, odvojim vremena zavisno od slobodnog vremena koliko ga imam zbog posla... Ali sve što mu radim, volim da radim sama. Quote Share this post Link to post Share on other sites
silenci 2337 Posted October 8, 2016 danas sam vas video,cekao sam da se ukljucim na put ka surcinu kod Holivuda,kad sam spazio maskirnu haubu belog HGT,odlicno iggleda Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted October 8, 2016 Hvala Maskirno ne moze da prodje neopazeno. Quote Share this post Link to post Share on other sites
