EDO_SA 0 Posted January 8, 2016 Napokon zavrseni farovi Montirali i savrseno sve radi Takodje, isto dan kad su kratka svjetla upaljena Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 8, 2016 Odlicno ali sad trazi dalje promene. Po meni, ne sme ovakav da ostane, nesto mu fali. Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 8, 2016 cekamo kraj januara gdje ide farbanje cijelog auta kao i ispravljanje svih udubljenja i ogrebotina nakon toga cemo da vidimo sta dalje raditi Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 8, 2016 Farovi su i polirani zaboravio sam to da objavim Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted January 8, 2016 Ufff! Ala su mu legli!Odlicno! Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 8, 2016 Hvala ti Moram ovaj prednji branik da zamjenim jer je stavljen zamjenski nazalost pa se ne uklapa kako treba uglavnom do ljeta ce ako Bog da biti sve sredjeno maximalno Quote Share this post Link to post Share on other sites
Drazen.OS 31 Posted January 8, 2016 Farovi su odlični. Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted January 9, 2016 Koliko je to zadovoljstvo na kraju svega koštalo?Verovatno puno ali vredi svaku paru!!! Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 9, 2016 oko 200 eura sve vrijedilo je iskreno ja sam prezadovoljan Quote Share this post Link to post Share on other sites
ivansd 13 Posted January 9, 2016 odlicno je ispalo!! Quote Share this post Link to post Share on other sites
DinoG 7 Posted January 10, 2016 Edo sve znas ;)Zbilja su super legli Sad samo ostaje poslati moje na slican tretman hahah Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 10, 2016 Cekamo tvoje da ih takodje zavrsimo Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 12, 2016 Danas smo bili u posjeti drugaru u Brckom Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 12, 2016 Kakva je ovo gedora ... Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 12, 2016 To je Dino koji se takmici sirom balkana i uzima nagrade sa tim puntom stim da je sad na zimskom setu inace izgleda ovako Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 12, 2016 Za sta uzima nagrade? za kineska dnevna svetla ... kakva li je ta tuning styling scena gde ovo uzima nagrade Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 12, 2016 Nisu kineska fabricki su farovi i on ih je sam pravio elektronicar po struci ma uglavnom uzima vecinu nagrada za DB Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 12, 2016 ubacio kineske diode i izmislio toplu vodu? DB je vec druga prica Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 12, 2016 nije los punto,al ima mnoogo boljih,neskladan mi je nekako,a i ti farovi mi se ne svidjaju,kako je unutra odradjeno u njima, Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted January 12, 2016 Pa ne natjece se u stylingu. Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 12, 2016 Zvezdo natjece se bio je u Sremskoj Mitrovici i u Subotici takodje Quote Share this post Link to post Share on other sites
EDO_SA 0 Posted January 13, 2016 Danas smo izvukli kompletnu instalaciju iz lijevog tocka od abs-a esp-a i svega sto ide preko tog kabla.... bio je u prekidu na jednom mjestu zbog cega mi je prijavljivalo gresku na tabli.... uglavnom kad smo to rijesili, desio se jos jedan problem koji ne mogu da otkrijem do cega je... tj trenutna potrosnja mi ludi, iako sam je resetovao i dalje prikazuje da pri kocenju motorom trosim 50 litara na 100 kilometara.... do cega bi moglo da bude jer mi trenutno ne radi ni auto zakljucavanje..... Da li se ikome ovo do sada desavalo ? Quote Share this post Link to post Share on other sites
Ivan 17680 Posted January 13, 2016 Je li dobro osusen kada je bio poplavljen ? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted January 13, 2016 Trenutna potrošnja ne služi ničemu osim da zbunjuje ljude. Niko ne treba da je gleda nikada. Od značaja po pitanju potrošnje je jedino prosečna, ali ni ona ne vredi ničemu da se gleda na board kompu ako je uzorak 20, 30, 50, ili 100 kilometara, tj. treba malo više kilometara kao uzorak.Ako još neki podatak tabla krene da brljavi, onda ti je jasno da počinje da otkazuje. I, najvažnije...postoji deo foruma koji se zove ''tehnička pitanja'', pa se tamo pitaju ovakve stvari, a ne u temi gde se auto predstavlja. Quote Share this post Link to post Share on other sites
