dusanesku 5 Posted June 5, 2021 (edited) Jesam citao to, da Bravo je u pitanju. Edited June 6, 2021 by Ivan Ne citiraj prethodni post, sredjen format Quote Share this post Link to post Share on other sites
Elra 204 Posted June 21, 2021 Da li za Bravo 1.4 FIRE odgovara kompresor klime sa Grande Punta, Punta Evo, Stila 1.4? Quote Share this post Link to post Share on other sites
Ivan 17680 Posted June 21, 2021 (edited) @Elra Imas sve detaljno u ePer. Kompresor klime npr. na pre-restyle Bravu 1.4 atmo je sa ovim SN: Otvoris njegovu Compatibility listu i teraj . Isti je isao u gomilu modela, samo treba da pogledas detalje za motorizaciju. Koliko vidim, nema Grandea, ali identican bi trebalo da je isao u: -restyle Stilo 1.4: - Punto Mk2b, takodje 1.4 kao i 1.2 verzije: Videh i 500, verzije TwinAir i 1.2... Ima toga prilicno, najbolje otvori po VIN vozila i listaj sta te zanima . Edited June 21, 2021 by Ivan 1 Elra reacted to this Quote Share this post Link to post Share on other sites
xalexas 84 Posted July 7, 2022 Ovaj Sale iz Žarkova je izgleda u međuvremenu žestoko poskupeo. Traži 400€ za zamenu motora recirkulacije! Eto šta se desi kad nekog reklamiraš. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
darkman14 5901 Posted July 7, 2022 To biva kad se nekom ne radi vise taj posao Quote Share this post Link to post Share on other sites
Ivan 17680 Posted July 7, 2022 2 hours ago, xalexas said: Traži 400€ za zamenu motora recirkulacije! Nas @Mijailović P. radi to za samo 380 EUR . 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
darkman14 5901 Posted July 7, 2022 i pivo 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted July 7, 2022 Uzeću stoju i pivu! 2 Reacher Gilt and Ivan reacted to this Quote Share this post Link to post Share on other sites
darkman14 5901 Posted July 7, 2022 Izgleda da @Ivan vrsi naplatu u tom slucaju 3 Mijailović P., Reacher Gilt and Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted July 7, 2022 (edited) Jbg, savremena organizacija... Neki moraju da rade, a neki moramo da budemo menaDJeri i PR. Pored dila sa Mijailovicem, inace usluzno vrsim i nabavku setova za reparaciju klapni/motorica, takodje uz sitnu nadoknadu . Edited July 8, 2022 by Ivan 1 2 Mijailović P., darkman14 and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Neboja 0 Posted July 10, 2022 On 7/7/2022 at 3:02 PM, Ivan said: Jbg, savremena organizacija... Neki moraju da rade, a neki moramo da budemo menaDJeri i PR. Pored dila sa Mijailovicem, inace usluzno vrsim i nabavku setova za reparaciju klapni/motorica, takodje uz sitnu nadoknadu . Ok, mene zanima gde imaju da se nabave te plastikice za motore/klapne klime za bravo. Moram i ja da menjam to, pa posto imam čoveka koji će mi to završiti, samo treba da nabavim delove... Hvala! Quote Share this post Link to post Share on other sites
aro_kv 2 Posted July 24, 2022 Pozdrav, drugari. Nov sam na forumu. Prolazio sam kroz temu od 30+ stranica, ovu i još nekoliko. Dakle, posedujem Bravo MJet, 2009o godište. Problem, isti kao i kod drugih. Leva greje, desna lepo hladi, plus, leva koja greje nema taj intezitet strujanja vazduha kao desna strana. Pored toga, kada se da kontakt, cuje se u kartikim intezitetima 'zu zu zu...', videh da su još neki članovi imali isti takav problem. Pretpostavljam da je sa te vozačke strane jedan od motorčića otišao ili polomljen. Potreban mi je savet, da li kupiti neki od tih motorčića, upustiti se u to bez pomoći ili otići kod servisera? Iz Kraljeva sam, momak kojeg ste pomenuli gore i 400e mi se čini previše za taj poduhvat. Pa bi dobrodošao neki savet od vas iskusnijih forumaša. Nadam se da nisam prekršio neko forumsko pravlilo, iščitane su teme pre posta. Sva najbolje! Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted July 24, 2022 @aro_kv Kao što sam rekao i ranije, ako ste strpljivi i prosečno spretni sa ključevima, alatom generalno, svakako trebate probati... U ovim uslovima predlažem dobru 'ladovinu i 'ladno osveženje. Osovinice između motorića/aktuatora su najčešći razlog otkaza rada klapni ventilacije. Srećno! Quote Share this post Link to post Share on other sites
aro_kv 2 Posted July 24, 2022 @Mijailović P. Hvala na brzom odgovoru! Jedno pitanje samo, nisam nasao na ovom forumu. Nasao sam tri srafa na toj bocnoj plastici kod gasa, dva su plasticna, jedan je zvezdasti torex ispod volana. Nakon toga sam skinuo kozu oko menjaca, odvrnuo sve srafove sa plastike oko menjaca, ali i dalje ne mogu nista skinem od tih plastike, drze se uglavnom sve negde. Da nema na formumu neki "how to"? Ja koliko sam video nema. Hvala jos jednom! Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted July 24, 2022 Možda pomogne... Quote Share this post Link to post Share on other sites
aro_kv 2 Posted July 24, 2022 @Mijailović P. Vidim sad, ja sam pomislio da se skida samo plastika kod vozaceve desne noge, da bi se doslo do tog motorcica koji "miksuje" i prebacuje sa toplog na hladno i obratno. Definitivno nemam skill-a da skinem kompletnu tablu sam, tako da cu morati da nadjem nekog u Kraljevu i okolini ko zna sa tim stvarima. Hvala jos jednom na brzim odgovorima @Mijailović P.! Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted July 25, 2022 8 hours ago, aro_kv said: Hvala jos jednom na brzim odgovorima No problemo, tu smo da pomognemo. Ih, tak'i smo mi na ovom forumu. Samo nije to ništa. Ima još bržih i kompetentnijih kolega forumaša. Quote Share this post Link to post Share on other sites
Neboja 0 Posted July 25, 2022 Pozdrva svima, vidim da ste se raspisali, a niko da mi odgovori na gore pitanje: a gde se nabavljaju te plastikice za motorcice? Hvala puno! Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted July 25, 2022 (edited) Možda ima kod Bogunovića u prodaji, odakle su i meni nabavili. Sporadično sam sretao na KP. Iskreno ne znam. Više se nisam interesovao. edit: Edited July 25, 2022 by Mijailović P. 1 Neboja reacted to this Quote Share this post Link to post Share on other sites
darkman14 5901 Posted July 25, 2022 Ovi ricambi delovi su najbolji Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted July 25, 2022 @andreja.micovic Ima ih svuda po forumu. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
bucke1 13 Posted July 26, 2022 Imao sam standardni problem vozaceva strana greje,suvozaceva normalno hladi na bravu. Prosle godine mi je covek sredio sve i mislim da nije skupo. Mogu ostaviti kontakt,ako nije protivno pravilima Quote Share this post Link to post Share on other sites
Neboja 0 Posted July 26, 2022 3 minutes ago, bucke1 said: Imao sam standardni problem vozaceva strana greje,suvozaceva normalno hladi na bravu. Prosle godine mi je covek sredio sve i mislim da nije skupo. Mogu ostaviti kontakt,ako nije protivno pravilima Apsolutno! Jos ako je i bg-a, vrh! Quote Share this post Link to post Share on other sites
bucke1 13 Posted July 26, 2022 Servis klima Njegos, Nerodimska 13, Zvezdara 0656975118 P.S. Ono sto je najvaznije,resava problem bez skidanja table 1 Neboja reacted to this Quote Share this post Link to post Share on other sites
