Zemunac1993 1 Posted October 7, 2015 Druze zeni poziv ne smem da odbijem Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted October 7, 2015 pa makar bio i sudski ,,,,,, Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted November 21, 2015 Maler me tera neki opasan... Prekjuce mi pukne remenica aletrnatora i izleti ka kraku sasije, usput PK isece uzduzno na froncle i jedan od tih komada podleti pod zupcasti... Dalje znamo sta se desilo. Uglavnom premotao ga je 21 zub i ventile je pokrivio definitivno. Danas ili eventualno sutra skidam glavu da vidim ima li sta od njega, da vidim sta je sa klipovima i ostalo. Pedja iz Indjije mi nudi pun blok i glavu za 160e. U opticaju mi je i da jurim mjet 8v 120ks sa strujom. Zna li neko pouzdanu u slucaju te avanture sta sve mora da se menja? mjet nosi EDC16? Quote Share this post Link to post Share on other sites
MS PK 7735 Posted November 21, 2015 Brate, da prestanes da se druzis sa Nemketom pod hitno Quote Share this post Link to post Share on other sites
gorank82 183 Posted November 21, 2015 U bre katastrofa Quote Share this post Link to post Share on other sites
Mahoney 0 Posted November 21, 2015 Jest vas krenulo...da mjet nosi edc16,mada sa edc16 ti nece raditi tabla.Bolje ubaci 115 jtd,pa nek ti neko remapira ecu za njega. Quote Share this post Link to post Share on other sites
joshibeast 74 Posted November 21, 2015 E jbg Zemunac Jel ti davala remenica neke znake da nije ok?Cvrkutanje, škripa itd?Iskreno nije mi jasno kako se zavukao komad pod kaiš?Zar nema onaj poklopac između kaiša?(verovatno sam postavio glupo pitanje) Quote Share this post Link to post Share on other sites
Dezurni 399 Posted November 21, 2015 Ima, ali remenica radilice voli da podvuče pod zupčasti Quote Share this post Link to post Share on other sites
nstyner 171 Posted November 21, 2015 E jbg,nikad čovek mira nema Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted November 22, 2015 Katastrofa Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted November 22, 2015 U voznji zaskripuckalo par puta kao spaner bas takav isti zvuk i bam. Skinuo sam alternator, razupcio sam auto i vratio sve na fazu, okrecem rucno ide bez problema sve, ne glavi nigde. Kasnije idem opet u garazu da probam da ga upalim da vidim sta ce se desiti. Jel zna neko jel me da se pali bez alternarora (kablovi su izolirani)? Quote Share this post Link to post Share on other sites
Dezurni 399 Posted November 22, 2015 Smeš slobodno Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted November 22, 2015 Malo mi sad sve cudno, na bregastoj sam izbrojao tacno 21 zub van faze, na tu razliku sam ocekivao ventile svarene sa celom klipa a on se sad ufaziran okrece bez problema?! Quote Share this post Link to post Share on other sites
asterix 7 Posted November 22, 2015 (edited) Druze to sto ti okreces nema veze,ako su se stigli trebalo bi da si izgubio kompresiju.Treba da proveris svakako. Edited November 22, 2015 by asterix Quote Share this post Link to post Share on other sites
Dezurni 399 Posted November 22, 2015 Ne mora da znači. Kod tih motora klipovi i ventili stoje u ravni. Eventualno probije šoljice. Prorobaj da upališ. Ništa ne možeš da izgubiš. Pogotovo što se okreće normalno. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted November 22, 2015 Ufaziran, upaljen i na paljenju bas lepo zalupa, posle se samo malko cuje tak tak tak... Svakako necu da se zajebavam, motor otvoren i sad od nedelje nosim glavu na ravnanje i hidrotest i na proveru vodjica,ventila, soljica i td. Hteo sam da promenim ceo motor jer imam ponudu za relativno malo para ceo drugi motor da uzmem ali kad sam video blok odma sam odustao jer je u savrsenom stanju! Honovi se vide kao da je juce naslozen u fabrici. Gledam glavu i golim okom uopste ne primecujem gde je udarao, nema tragova ni na celu klipa ni na ventilima. Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 22, 2015 Ne udaraju se oni baš mnogo. Dovoljno je da se poljube i stablo ventila se krivi jer je stisnuto bregastom odozgo i klipom odozdo. Sendvič! Quote Share this post Link to post Share on other sites
Dezurni 399 Posted November 22, 2015 Po mom iskustvu, trebao si prvo šoljice da proveriš. Znaju ventili da naprave mala udubljenja i zbog toga lupka. Bilo bi ti mnogo jednostavnije i jeftinije Quote Share this post Link to post Share on other sites
asterix 7 Posted November 23, 2015 (edited) Vidi da li se mrdaju ako malo zapnes ventile.Mozda ga je iskrivio malo ali taman da se cuje.Sredices ti to i bice pracka. Edited November 23, 2015 by asterix Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted November 23, 2015 Glavudza odnesena na obradu, na brzaka smo bacili oko, metodom benzin u kanal ustanovljeno je da je jedan ventil kriv i da su bar dve soljice dobile stomacic, sutra se cujem kada je decko raskupusa celu pa javlja tacno stanje. Jel istina da su soljice iste kao za juga/stojadina? I zamenjeno je dzubre na alternatoru, ***em mu sve po katastru. Evo malo po povratku iz sopinga. Quote Share this post Link to post Share on other sites
gorank82 183 Posted November 23, 2015 Opa trosilo se Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted November 23, 2015 Pasu plocice. Sve je to isto. Samo da se debljina udene tacna da ne tandrcu ventili I tebe bas poteralo. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted November 23, 2015 Imam 16 soljica u garazi pa mu nosim sutra nek probere. Ono kad pogledam najveci trosak mi ispade remenica i dihtung glave. Ostalo sve sto sam nakupovao bi menjao svakako. I jos nesto me zanima, u original kutiji seta zupcenja dobijem Dayco kais, to ok ili da lomim noge? Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted November 23, 2015 Pa zavisi sta si uzeo od seta?Ja sam uzimao skf spaner i conti kais. Sam birao bio. A reinzove dihtunge i corteco semeringe. Kad si vec rasturio motor uzmi i semeringe zameni. Nisu skupi ja mislim. Quote Share this post Link to post Share on other sites
