Gagy.GM 59 Posted June 8, 2015 Super je nema sta Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted June 10, 2015 (edited) stvarno je lep , ja tek sad vidim tvog punta , ps: inspiracija a??? :) Edited June 10, 2015 by DRAGANCE Quote Share this post Link to post Share on other sites
jevta BG 111 Posted June 10, 2015 Hahahhaha da znas da jeste... Stajala mi slika na backgraund-u godinu dana... Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted June 10, 2015 meni vec 2-3 meseca Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted June 10, 2015 Dobar nacisto... Oduvek sam se divio dizajnu maglenki na mk1... Jednostavno prelepo... Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted June 10, 2015 ispred svog vremena Quote Share this post Link to post Share on other sites
bane17 24 Posted June 24, 2015 Sad vidjen kako prolece pored ade Quote Share this post Link to post Share on other sites
LazarGP 1 Posted June 24, 2015 Auto je babaroga! )) Quote Share this post Link to post Share on other sites
milan81 24 Posted June 24, 2015 Odlican nema sta,malopre gledam na slovenackom Avto netu,ima 2 komada samo! Quote Share this post Link to post Share on other sites
jevta BG 111 Posted June 24, 2015 a jesam jurnuo pored ade... pogotovo onaj pravac pored tempa uvek spucam... Quote Share this post Link to post Share on other sites
bane17 24 Posted June 25, 2015 Ja sam te video kod beogume Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 8, 2015 malo da osvezim temu...skinuta zadnja torzija ide na peskarenje i farbanje... pozadi ide sve novo osim amortizera koje sam uzeo polovne ali kao nove...dosta jace i malo vece... skinuta grana posto sam resio da pravim granu... ovako nesto ima jos dosta ali pisacu i slikati sve sto budem radio... Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted August 12, 2015 grana je ogroman poduhvat, nadam se da imas dobar plan i sredstva za rad, amortizeri koje planiras da stavis imaju dosta kraci hod same sipke, jesi li siguran da nece stosovati? Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 13, 2015 ja mislim da ce biti sve ok.skinuti su sa gt-a, vozeni godinu dana i bilo sve ok... Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 25, 2015 bio sam malo u grckoj i uslikao par komada...nije mi telefon bio pri ruci da uhvatim jos par ozbiljnih auta sto se tice mog punta rastavljen je na cinioce i radicu na njemu narednih par meseci posto sam odlucio da ga ozbiljno uradimovako izgleda patos na autu starom 20 godina skoro pa savrseno ...ima jedna mala rupa kod vozaca i malo je korodirao kod zadnjeg srafa za sediste sa obe strane, ali nije trulosto se tice turbine prosle godine sam kupio ovog garrett-a ali mislim da je previse velika turbina za mog punta...na njoj pise A/R 80 sto znaci da je skoro pa duplo veca nego fabricka koja je A/R 49... ima veliku turbo rupu pali se tek na 3500 i nemoze da predje 0,6 bari to je sa fabrickim diznama i benz pumpom... kada stavim jace dizne walbro pumpu koji sam kupio i mapu koja je pravlena za to neznatno se poboljsa...neko kaze da je do mape a ja ipak mislim da je do velike turbine... na slikama se najbolje vidi razlika u velicini...nznm sta da radim da li da prodajem ovu turbinu pa da uzmem neku manju ili da sa ovom pravim posao...dobro bi dosao savet nekog iskusnjaka... Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted August 25, 2015 pod je odlican, ja sam bas veceras odradio par flekica kod mene, nista strasno ali bilo je rupica, nazalost kod zadnjeg desnog srafljenja za pojas je bilo prilicno posla,,,, drugar je na golfa mk6 1.6tdi ubacivao hibridnu turbinu i znam da je imao nekih problema sa njom, uradjena je mapa u "revochipu" i sve je bilo ok, savetujem da bas njih kontaktiras, jako su ljubazni i hoce da pomognu Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 26, 2015 drugo je hibrid... da sam pravio hibridnu ne bi imao problema, ne bi je mnogo povecao zato sto je fizicki neizvodljivo...ovako je skoro pa duplo veca a to je za 1.4 motor previse...vec sam se bacio u potragu za drugom tako da ako naleti ova ide na prodaju...auto je i ovako ceo rasklopljen poceo sam da sredjujem mnogo stvari tako da nije hitno... tek treba da pravim granu... Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted August 26, 2015 ne stedi na slikama dok je budes pravio Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 27, 2015 skinuta bregasta posto stavljam sa atmo motora 1.6 punto ili sa tipa 1.4 sutra skidam glavu ide na sredjivanje a kad sam ga vec raskupusao razmisljam da odradim i karike i lezajeve i da bude ful generalka... Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted August 27, 2015 Sa 1.4 je slaba, a i neki 1.6 imaju slabe, gledaj od jacih verzija 1.6 ili 1.1 i 1.3 motori od Zastave Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 27, 2015 znam da pase sa floride 1.4 e sad bilo bi dobro da znam specifikacije od nekih motora...citao sam po forumima pogotovo britanskim da su najvise stavljali od 1.6 sporting modela Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted August 28, 2015 Najaca bregasta ti je iz 1.3 sa 73ks (Fiat 128, Z101 Specijal) i 1.5 sa 85ks (Ritmo), ima 269 stepeni i 9.9mm lift, onda 1.6 sa tih 88+ks varijante (Sporting) ima oko 260 stepeni mislim 9.6mm lift, pa onda iz 1.1 i 1.3 motora (ima nekih Fiata ali da bi bio sigurniji, ako trazis od Zastave onda ima sigurno), te su 244 stepena i 9.2mm lift i onda imas iz 1.4 i nekih 1.1 i 1.3 Fiata koji imaju kao ta iz 1.4, ona ima 222 stepena i 8.8 lift. A nisam siguran da li je tvoja bregasta ista kao iz Una Turba 1.4, on ima mislim 230 stepeni i 8.8 lift. Ta od sportinga je najaca koja se relativno najlakse nadje. Ona prva je kao zlato da se nadje Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 28, 2015 Mislis bas na fiat 128 ili sto je zastava pravila...Ako je zastava onda je imam... Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted August 28, 2015 Fiat 128 Rally i Z101 Specijal Quote Share this post Link to post Share on other sites
