bane11 1 Posted September 19, 2019 Pozdrav, imam problem sa Stilom 1.9 mjet 16 v 140ks, problem je sto auto secne dok ubrzava...dizne uradjene sve komplet, auto sve normalno pali radi ide, bez problema, nema nikakva greska...jel imao neko slican problem i kako ga je resio? 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Ivan 17679 Posted September 20, 2019 EGR off ? Quote Share this post Link to post Share on other sites
MS PK 7735 Posted September 20, 2019 Konektori ok? Quote Share this post Link to post Share on other sites
bane11 1 Posted September 20, 2019 Eger otvoren sve kao fabricki, konatki skoro sredjivani i okej su bili Quote Share this post Link to post Share on other sites
Flex 1778 Posted September 20, 2019 Egr ciscen? Dijagnostika kacena? Protokomer? Map? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 21, 2019 @bane11 Isključio bih protokomer pa probao tako. Imao sam na istom autu problem da jedno veče nikako nije išao do 3.000 obrtaja...do tog broja obrtaja se muči, povuče na blic kako treba pa umre pa opet povuče...i onda od 3.000 rpm povuče kako treba. Iskopčan protokomer i ide odlično. EGR bi svakako zatvorio...nema svrhe od njega, samo ti prlja usis... Quote Share this post Link to post Share on other sites
bane11 1 Posted September 22, 2019 Danas upalio chech engine, slabo prima gas, jedva ide, trza u voznji Quote Share this post Link to post Share on other sites
petarcirjanic 70 Posted September 22, 2019 Kačenje na dijagnostiku I da se očitaju parametri. Quote Share this post Link to post Share on other sites
