silenci 2337 Posted January 25, 2019 konacno danas resen problem sa volanom ,kad se mota u bilo koju stranu ,ispod volana stalno se culo lupanje,neki su pricali kardan,neki letva volana,a decko resio problem za 15 minuta,svaka mu cast i svaka preporuka,a zahvaljujem Koletu,koji mi je rekao za problem i koji me je odveo kod majstora,hvala puno,a odusevio sam se kad sam poceo da motam volan i nije se nista culo ni lupalo a vise sam potrosio goriva do Pazove,nego sto je majstor uzeo za ruke, a problem resen za sva vremena 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 25, 2019 A sta je bio problem? Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 25, 2019 problem je bio lupanje u volanu,sad dal je letva volana dobila lufta il krst kardana,ne znam,al znam da je resen problem i to na dve muse Quote Share this post Link to post Share on other sites
cika_kole 825 Posted January 25, 2019 caura na letvi...razloka se vremenom i pocne da lupka... 2 Djuk85 and silenci reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 25, 2019 da caura na letvi,al necemo da otkrivamo sve detalje Quote Share this post Link to post Share on other sites
simonen 81 Posted January 25, 2019 A koja je onda svrha pominjanja problema ,ako se krije resenje???? 3 alfini0507, knezevic76 and Axic reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 26, 2019 I zasto ne bi rekao detalje? Zar nije poenta foruma pomoci? Verovatno ce neko i u buducnosti imati slican problem. 2 neshaoct and Axic reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 26, 2019 Nece, ko jos vozi Musu 1 2 cika_kole, silenci and bglion reacted to this Quote Share this post Link to post Share on other sites
cika_kole 825 Posted January 26, 2019 polako, polako, reci ce covek sta ste napeli... kao da vam svima lupa sad volan... ima caura izmedju gasa i kocnice na toj letvi, razloka se, lupa... treba da se probuse dve rupe, ureze navoj, zavrnu dva srafa i caura se priljubi uz letvu i vise nema lupkanja... ne moze da steti voznji, a nema veze sa krstom...ili da se skida sve i pravi nova caura, sto je veliki posao naspram ove dve rupe, urezivanja navoja i uvrtanja srafova... 3 neshaoct, simonen and silenci reacted to this Quote Share this post Link to post Share on other sites
Axic 20048 Posted January 26, 2019 @cika_kole da ne ofujemo temu čoveku (mada će moderatori prebaciti) ali ako ti nije problem značilo bi ostalima ako možeš to slikovito da objasniš. Nemam problema za sad ali bi verujem svima značilo da neko ko zna prenese i objasni kako to da uradimo ako zapne. @neshaoct mozes prebaciti u nekoj temi vezano za letvu volana ili slično ali da sačekamo odgovor kolege i onda sve đuture tamo negde isprebacuj. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
cika_kole 825 Posted January 26, 2019 @Axic ne znam bas kako bih objasnio slikovito jbg...nisam nikada zavirio dole...kada sam kupio klincu musu, jos kod coveka gde sam je kupio sam znao da lupka volan, ali ne i tacno sta lupka... drugar koji mi odrzavao auto je rekao, resicemo...kada sam radio veliko/mali servis tada je odmah pogledao sta lupka. to je neka caura, e sada kaze da se ta caura moze kirnerovati, ali mora da se skida volal i sve ostalo..sto te posle dovodi do elektronicara i placanja za optiku...da ne bi to radili, a isti je efekat on je kroz tu cauru probusio rupu, urezao navoj i zategao sa dva srafa. musa mi nije tu, klinac je vec par dana u novom sadu kod "male" (valjda cini pos'o, da budem deda ) mozda bi @silenci mogao sutra da slika to dole i izbaci ovde da ne bi cekali mog pastuva... 3 1 neshaoct, Axic, Smireni and 1 other reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 27, 2019 eto Kole je objasnio sve sta je odradjeno i na koji nacin,a sutra cu da slikam,juce i danas,samo jedi,jedi,pij ,pij,auto i ne mogu da isteram iz garaze od snega koliko ga ima, a mrzi me da lopatam Ja isto nisam se zavlacio ispod volana da vidim gde je ta caura,al sutra cu se zavuci 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 27, 2019 Pazi nemo se zaglavis posle tolikog jedi, jedi, jefi, pij.. 1 silenci reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 27, 2019 a necemo mala,juce se ceo dan skijali i sankali,pa su se trosile kalorije,a pili vino da se ugrejemo Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 28, 2019 evo slika,znaci razbusena letva,urezan navoj i navijen šraf 2 neshaoct and Axic reacted to this Quote Share this post Link to post Share on other sites
milos66 39 Posted January 28, 2019 Jao i meni lupka u volanu ja isto mislio da je letva.... Moracu to da pogledam ako ne jel ima neko u bg da to resi Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 28, 2019 (edited) pa najbolje odes do stare pazove da ti covek uradi,kad je vec uigran jel kad motas u bilo koju stranu,pa ispod volana se cuje Edited January 28, 2019 by silenci Quote Share this post Link to post Share on other sites
milos66 39 Posted January 28, 2019 0652008304 ako ti nije problem na viber mi sibni br od coveka narucio sam prskalice danas Quote Share this post Link to post Share on other sites
simonen 81 Posted January 28, 2019 U vreme kada sam radio u Fordovom servisu,ovo je takodje bio problem kod Fiesti i Fokusa.Ford je imao posebnu mast u spreju koja je sluzila bas za eliminisanje lupanja prilikom motanja. Razvuce se kardan,nasprica sprej da odstoji par minuta i onda se sklapa. Nisu dozvoljavali nikakva druga resenja,jer teleskop sluzi da u slucaju udesa volan ne podje odmah prema grudima vozaca,vec da ima mesta da upije deformaciju prilikom ceonog udarca. Tako da ovo jeste resenje ali uvek postoji neko ali... 3 bglion, silenci and Axic reacted to this Quote Share this post Link to post Share on other sites
cika_kole 825 Posted January 28, 2019 (edited) racunao je covek na to. sraf je od krtog materijala, pri udarcu se raspada...tako da tu nemora da se misli puno... tako sam ja resio volan od klinca mog na musi, a logicno je da zlo necu pozeleti nikome, a kamoli rodjenom detetu... Edited January 28, 2019 by cika_kole Quote Share this post Link to post Share on other sites
milos66 39 Posted January 28, 2019 Sibni mi br u poruci imam isti problem? Koja je cena popravke Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 28, 2019 to jest,al kod Koleta na musi od maja kad je uradjeno,nema problema,tj njegov sin,vozi bez problema,a eto izgleda da je to neka mana na Idei i Musi,evo i kolega Milos ima problem na Idei Quote Share this post Link to post Share on other sites
colinio 1 Posted July 10, 2019 Pozz.. Imam isti problem sa lupkanjem volana.. U pitanju je Lanca Musa... Ako može kontakt čoveka iz Stare Pazove Quote Share this post Link to post Share on other sites
silenci 2337 Posted July 12, 2019 javi se drugu clanu foruma cika Kole Quote Share this post Link to post Share on other sites
cika_kole 825 Posted July 12, 2019 zavrseno je to...zvao covek majstora... 1 silenci reacted to this Quote Share this post Link to post Share on other sites
