Matteo11 104 Posted May 6, 2018 Nebik znao gde da postavim pitanje : koliki je max pritisak turba na motorima Multijet2 1.6 , euro 6 ? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 7, 2018 @dekirs - jel znamo na kraju? Quote Share this post Link to post Share on other sites
dekirs 4819 Posted May 7, 2018 Nemam na fonu boost log da okacim, ako nekoga ne mrzi neka nadje coveku Quote Share this post Link to post Share on other sites
Matteo11 104 Posted May 12, 2018 Niko ništa , jel moguće ? Hoću da montiram barometar čisto da imam u vidu pritisak turba , verujem da ću kupiti onaj u Psi mernoj jedinici samo jer mi lepše izgledaju ... Sad imal lepe primerke koji idu do 15 Psi i 25-30 Psi ali pošto nigde nemogu naci podatak koliki pritisak ima moj turbo - onda nebih znao ni koji da kupim ! Na jednom ITA forumu sam iskopao cifru od 1.1 bar , i to je sve što sam uspeo da nađem .... Hajde ako neko zna neka javi , hvala unapred ! Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 12, 2018 Sto te to toliko kopka? Quote Share this post Link to post Share on other sites
Matteo11 104 Posted May 12, 2018 Imao sam ga u svakom mom dizelu , držim da je barometar koristan uređaj ! Quote Share this post Link to post Share on other sites
dekirs 4819 Posted May 12, 2018 (edited) Turbo je GTB1446VZ. Evo ti i moj boost log na cipovanom Bravu. Citiram sa stranog foruma: "For an average power is usually used a GTB1446vz (1.6 Multijet 120 hp )to make normal power 135-145hp at 1.8-2.2 bar(depends of the boost) with minimal lag." Samo ne znam sta ce ti to u 1.6 bravu.. Po meni beskorisno, neces ga voziti na stazi. Edited May 12, 2018 by dekirs Quote Share this post Link to post Share on other sites
igor0511 2882 Posted May 12, 2018 (edited) 3 minutes ago, Matteo11 said: Imao sam ga u svakom mom dizelu , držim da je barometar koristan uređaj ! Bolje kupi Alfu da se ne mucis sa ugradnjom Edited May 12, 2018 by igor0511 Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 12, 2018 Ima on u sebi barometar, sam ce da je iskljuci ako poludi Quote Share this post Link to post Share on other sites
Matteo11 104 Posted July 8, 2018 Danas instaliran , a max pritisak je ovoliki: Quote Share this post Link to post Share on other sites
chicco79 1 Posted July 11, 2018 (edited) Pozz ljudi ako neko zna molim za pomoc vozim stila cupea 1.6 16 v Kad je auta hladan tj kad se nevozi pali ko mina al kad vozim ugasim pa ponovo upalim nece samo vergla pojavi se greska na kompijuteru CAR CODE vergka satima al nece da,upali tek nakon 5/6 sati moze ???? Ako neko zna koja je greska sta zapravo upitanju da li je za el.iili mehanicara kvar Izvini te sto upadam u temu nevezanu al mi gori ako ko zna pomoc ?? Edited July 11, 2018 by chicco79 Quote Share this post Link to post Share on other sites
zalik 15 Posted June 16, 2019 On 12.5.2018 at 11:33 PM, dekirs said: Turbo je GTB1446VZ. Evo ti i moj boost log na cipovanom Bravu. Citiram sa stranog foruma: "For an average power is usually used a GTB1446vz (1.6 Multijet 120 hp )to make normal power 135-145hp at 1.8-2.2 bar(depends of the boost) with minimal lag." Samo ne znam sta ce ti to u 1.6 bravu.. Po meni beskorisno, neces ga voziti na stazi. GTB1446vz sa 1,8 bar pritiska ???? Ko ti je ovaj turbo killer??? Turbo ubica na srpskom? Majko mila tuge Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted June 17, 2019 @zalik - imas mogucnost jednom da pogadjas 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
zalik 15 Posted June 17, 2019 Ne pogadjam ali na stock turbo ovaj pritisak !!! Vozi li decko ovaj jos ovo? Za GTB1549 ovo je skoro max pritisak a ne za ovu manju turbinu Quote Share this post Link to post Share on other sites
McSteel 550 Posted June 17, 2019 Možda meri apsolutni pritisak, a ne nadpritisak u odnosu na atmosferski? Tad bi možda bilo malo nisko, ali bliže normalnim i očekivanim vrednostima... 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted June 17, 2019 Ja bih rekao da je to merenje "u zbiru"... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted June 17, 2019 U zbiru naravno. 1000 + 1800 bara Quote Share this post Link to post Share on other sites
zalik 15 Posted June 21, 2019 2,8 ili 1,8 ubica BAR Quote Share this post Link to post Share on other sites
Matteo11 104 Posted June 23, 2019 BAR - Browning Automatic Rifle ? Quote Share this post Link to post Share on other sites
