jevta BG 111 Posted September 5, 2018 Nije to ta...pitao sam momka,kupio je novu i vozio u audiju S2 kao suvozacevo sediste,zato je dobro ocuvana... Quote Share this post Link to post Share on other sites
jevta BG 111 Posted September 12, 2018 (edited) Pocinje polako skupljanje delova za sledecu godinu... uzet novi termostat,ko je trazio zna koliko je tesko naci... Uzeta je i benzinska pumpa BOSCH 044 externa... Uzete su i dizne 600ccm duplo jace od fabrickih... Polako sam poceo i da pakujem pogon,za pocetak zadnji most... Edited September 12, 2018 by jevta BG Quote Share this post Link to post Share on other sites
siki 219 Posted September 12, 2018 Jevto...............gde si nabavio termostat..pomagaj daj i za mene jedanjavljaj adresu,prodavnicu.. Quote Share this post Link to post Share on other sites
jevta BG 111 Posted September 12, 2018 Nema batice to nigde kod nas...doneseno je iz italije tako da jedino tamo ako imas nekoga...mada i tamo je to tesko naci a i cene su haos... Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted October 2, 2018 Ja imam jedan nov viška ali je za 1.4t a ne za te vaše zverine 2.0 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
jevta BG 111 Posted October 2, 2018 Ma to je igracka,ima i na trafici... 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted October 23, 2018 Trafikant, zaspao projekat dubokim snom? Radiš drugi? Quote Share this post Link to post Share on other sites
jevta BG 111 Posted October 23, 2018 (edited) Hah...nije zaspao radi se ali polako...imam gomilu nekih obaveza pa nestizem ni jednom ni drugom projektu da se posvetim...drugi ne pocinjem dok ovaj ne sklopim... Zavrsen je zadnji most i spusten je auto na tockove,sad treba motor napolje i prednji most da se prepravi,i rezervoar da resim...ima posla a malo vremena... Edited October 23, 2018 by jevta BG 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted October 24, 2018 rezervoar cemo da pravimo ...... ps dobra ti nalepnica na zadnjoj soferci Quote Share this post Link to post Share on other sites
jevta BG 111 Posted October 25, 2018 21 hours ago, DRAGANCE said: ps dobra ti nalepnica na zadnjoj soferci Ma to mi rekli da zalepim...rekli brzi cu da budem i ja im poverovao Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted October 26, 2018 +10 ks Ja bih dve...kad je bal nek je... 1 jevta BG reacted to this Quote Share this post Link to post Share on other sites
jevta BG 111 Posted March 11, 2020 (edited) Aj malo da obnovimo temu uskoro ce puntara na test i sezona polako pocinje. Cilj je ove godine odvozati ono sto bude u Srbiji i bar jedan izlazak u osjek ili bosnu, videcemo. Vreme ne znam koje jurim kao ni konjazu, uzeto je kamara kvalitetnih delova da trpe dobru konjazu ali treba sve to ukopiti. Izvadjen je predhodni motor sa prenjim pogonom u medjuvremenu je slozen drugi... Levi i desni nosac ostaju isti, zadnji je morao da se kroji na samom mostu zbog diffa i kardana. Menjac je bio najveci problem. Od tri menjaca jedan je bio ispravan na dva je differencijal progledao. Prenos je uzet od prisme sa kracim brzinama i upareno sa twinplate kvacilom Bacci Romano jedna od najozbiljnijih i najskupljih stavki na ovom autu. Napravljena je pletena izduvna grana i odradjen je izvod za externi wastegate ventil. Ide drugi i veci turbo. Jos jedna jako bitna i jako skupa stavka je struja. Uzet je Vems tako da ce se izbaciti nekoliko nepotrebnih senzora. Uzeta je wideband sonda. Generalno motor je spakovan i na autu je, zadnji trap je spakovan ostalo je jos par nekih prepravki na istom, kardan treba da se okrati, da se napravi rezervoar u gepeku i odradi prepravka posto je uzeta externa bosch 044 pumpa i da se pokace sve propratne stvari, dizne, turbo, struja itd. Do kraja meseca ce nadam se biti sve gotovo. U planu je rollbar ali ne znam da li cu stici da smontiram sve. Edited March 11, 2020 by neshaoct formatiranje 9 PremieRacing, Martin, MiloshShomy and 6 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted March 11, 2020 Pa 'leb te hebo, gde si do sad... Znam da se radi i da je gužva, ali za nas sa jeftinim ulaznicama moraš da izvedeš neki performans malo češće btw, BRAVO Quote Share this post Link to post Share on other sites
jevta BG 111 Posted March 11, 2020 14 minutes ago, PremieRacing said: Znam da se radi i da je gužva, ali za nas sa jeftinim ulaznicama moraš da izvedeš neki performans malo češće Mozda opalimo i neki track day ove godine ako sve bude kako treba... 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted March 11, 2020 32 minutes ago, jevta BG said: ...kardan treba da se okrati Jel potrebno posle toga balansirati kardan? Setio sam se onih ''ludih Rusa'' iz Garage54 kad su nedavno pravili repliku novog Tesla kamioneta, pa su produžavali kardan od platforme koju su koristili (čini mi se neki UAZ), i nikako nisu mogli da naprave balans (ovde od 03:50) tako produženog kardana kako treba bez obzira koliko su se trudili, pa su angažovali neku lokalnu firmu koja se bavi reparacijom starih i izradom potpuno novih kardana. Ne znam da li to treba raditi samo kada se kardan produžava, ili treba i kad se skraćuje... Quote Share this post Link to post Share on other sites
jevta BG 111 Posted March 11, 2020 1 hour ago, neshaoct said: Jel potrebno posle toga balansirati kardan? Setio sam se onih ''ludih Rusa'' iz Garage54 kad su nedavno pravili repliku novog Tesla kamioneta, pa su produžavali kardan od platforme koju su koristili (čini mi se neki UAZ), i nikako nisu mogli da naprave balans (ovde od 03:50) tako produženog kardana kako treba bez obzira koliko su se trudili, pa su angažovali neku lokalnu firmu koja se bavi reparacijom starih i izradom potpuno novih kardana. Ne znam da li to treba raditi samo kada se kardan produžava, ili treba i kad se skraćuje... Mora. Ide svakako kod profesionalca na skracivanje... Trebalo bi da bude sve ok. Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted March 12, 2020 15 hours ago, jevta BG said: Mozda opalimo i neki track day ove godine ako sve bude kako treba... Ja bi voleo da se organizujemo na ovom forumu kao Alfisti što se organizuju... Zajednički track day. Da nam to bude i zvanično okupljanje. 1 horvat reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted April 14, 2021 Drug, kako PuntoGralle napreduje... Quote Share this post Link to post Share on other sites
