MS PK 7734 Posted November 19, 2019 Verovatno kao nova 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted December 1, 2019 (edited) @skile86 Jesi li uspeo sta resiti, ima li prica (srecan) kraj? Edited December 1, 2019 by neshaoct dodao tag Quote Share this post Link to post Share on other sites
skile86 539 Posted December 1, 2019 Hvala na interesovanju. :-) Nisam uspeo jos nista da uradim tj nista ni da pokusam da uradim, posto sam u haosu na poslu. Jbg svi hoce da zavrsavaju svasta pred kraj godine. Slucajno sam natrcao na netu da je Opel radio opoziv za Astru zbog problema koji ja imam i da su ga resili nadogradnjom softvera i reprogramom dizni. (Teska prica ali provericu) Za 2 nedelje cu biti par dana na odmoru, pa cu pokusati tad da to sredim tj bar da vidim sta se desava. :-) Quote Share this post Link to post Share on other sites
totti 13165 Posted December 1, 2019 [mention=6017]skile86[/mention] Jesi li uspeo sta resiti, ima li prica (srecan) kraj? Ma idi... ja reko pitaš za happy ending masažu Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
skile86 539 Posted December 1, 2019 Cccc deda, samo o happy ending masazama razmisljas. Quote Share this post Link to post Share on other sites
skile86 539 Posted December 4, 2019 Dunulo mi da proverim grejace, posto to mogu i sam da uradim, i slucajno sam izvalio da imam grejace sa senzorom pritiska u cilindru. (Oko 120e kosta jedan grejac) Kako je to sve lepo povezano i trebace neki Tesla da izvali gde je problem. Mozda sam ja neupucen tj mozda ovo postoji vec duzi niz godina. "This is a glow plug which is upgraded with a special sensor to measure the pressure in the combustion space of the cylinders of diesel engines. The sensor is mounted around the heating element of the glow plug. Its construction enables extremely precise measurement in real time during combustion of the fuel.The ECU is able to constantly adapt the fuel injection, the charge pressure and the exhaust gas recycling rate." Quote Share this post Link to post Share on other sites
MS PK 7734 Posted December 4, 2019 Da, ti su najjeftiniji Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted December 25, 2019 Dosad si se verovatno navikao Послато са Mi MIX 2 помоћу Тапатока Quote Share this post Link to post Share on other sites
skile86 539 Posted December 25, 2019 Nesto mi je iskrslo pa nisam imao vremena da odem i proverim to. Realno, ako odmah krenem po paljenju, to se ni ne primeti. Javljam sta sam uradio. :-) Quote Share this post Link to post Share on other sites
skile86 539 Posted April 15, 2021 Ode Opelo. Malo mi je zao na kraju, ali idemo dalje. :-) @vagenovac Da ne ostanem duzan, problem je bio u regulatoru pritiska goriva. 4 djomla, Ivan, vagenovac and 1 other reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted April 15, 2021 Tu su evrici da se obrise suza za opelom Drago mi je da si javio sta je bilo, eto sitnica takoreci.Послато са Mi MIX 2 помоћу Тапатока 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted April 15, 2021 Extra, znaci konacno ode Krbulja . Drago mi je da si napokon odradio transakciju. Iskren da budem, nas sve vise zanima sudbina onog drugog, mnogo zanimljivijeg primerka . Quote Share this post Link to post Share on other sites
skile86 539 Posted April 15, 2021 To ce sutra najverovatnije da bude reseno, ali javljam. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted April 15, 2021 E, jbg . 1 skile86 reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted April 15, 2021 Da ne ostanem duzan, problem je bio u regulatoru pritiska goriva. Ajde Sent from my SM-G770F using Tapatalk Quote Share this post Link to post Share on other sites
skile86 539 Posted April 15, 2021 5 minutes ago, Ivan said: E, jbg . Bice opet nesto zanimljivo sigurno. :-) Quote Share this post Link to post Share on other sites
Ivan 17670 Posted April 15, 2021 Pratim izbor sa zadovoljstvom. Znaci dzaba smo polirali i stelovali farove i haubu ... U stvari: 1 skile86 reacted to this Quote Share this post Link to post Share on other sites
