dellas 1556 Posted November 10, 2015 Ne vredi matori Vidi koliko planiras preci sa njom pa razmisli o letecim nije to neka velika investicija 60-80e, a to im je velika mana jer je servisni interval bio 30kkm i svi koji su dosli od preko su naceti. Samo prolupa bez ikakve najave, brze ode i turbo zbog slabijeg podmazivanja, bolje spreciti nego leciti. To je jedina mana ovog motora Quote Share this post Link to post Share on other sites
asterix 7 Posted November 10, 2015 Pa onda i leteci i lezeci.Jel moze sve iz kanala,samo da se skine karter? Quote Share this post Link to post Share on other sites
Dezurni 399 Posted November 10, 2015 Može, naravno Quote Share this post Link to post Share on other sites
totti 13165 Posted November 10, 2015 To može i Marko da odradi Quote Share this post Link to post Share on other sites
Markobgd 609 Posted November 10, 2015 Ih, pa nego kako! Izverziran sam.... Quote Share this post Link to post Share on other sites
MS PK 7734 Posted November 10, 2015 Kako moze i leteci i lezeci iz kanala? Quote Share this post Link to post Share on other sites
asterix 7 Posted November 10, 2015 Pa dignes klipove gore samo i menjas. Quote Share this post Link to post Share on other sites
diskusija 9 Posted November 10, 2015 Nisam baš siguran da mogu i jedni i drugi samo iz kanala. Quote Share this post Link to post Share on other sites
asterix 7 Posted November 10, 2015 E pa ako je Dezurni kazao,ja tu ne bih nista menjao! Quote Share this post Link to post Share on other sites
MS PK 7734 Posted November 10, 2015 Eto sta ti je Reso. A ga predstavis vec radis generalnu radi preventive Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted November 10, 2015 Hahahahahaah Brat moj. Veruj dezurnom. Zna decko sa dizelima. To mu je u krvi. Prosto obozava naftu Quote Share this post Link to post Share on other sites
joshibeast 74 Posted November 10, 2015 Ja kapiram ako ne rade leteći ležajevi, znači da ne lete više.Spustili su se u karter. Quote Share this post Link to post Share on other sites
srdjos 1602 Posted November 10, 2015 (edited) Fino parče metala si nabavio, svaka čast.Da te dugo i bezbrižno služi Nego, pošto nisam u toku, da pitam, (nadam se da ne trolujem temu) ali da li kod Rendžera još traje ta priča oko problema za Delphi pumpe i 1.5 dCI i za ove novije modele 2010+ godišta ili je to rešeno? Edited November 10, 2015 by srdjos Quote Share this post Link to post Share on other sites
asterix 7 Posted November 10, 2015 Reseno.Ovi novi 1.5 nemaju problem. Fino parče metala si nabavio, svaka čast. Hvala kolega.Moram da jednu upadicu napavim.Nije ovde samo metal,ima i plastike ihaaaaa.Krila,gepek,sve plasticno. Eto sta ti je Reso. A ga predstavis vec radis generalnu radi preventive Vidi ga moj brat sto poentira!Ako Mico,nek ide i generalna,ali je MOJ!PRC. Quote Share this post Link to post Share on other sites
srdjos 1602 Posted November 10, 2015 (edited) Reseno.Ovi novi 1.5 nemaju problem.A koji to novi, jel ima neka preciznija informacija.Hvala kolega.Moram da jednu upadicu napavim.Nije ovde samo metal,ima i plastike ihaaaaa.Krila,gepek,sve plasticno.Eeee, znaci lose ces proci kod cigusa Edited November 10, 2015 by srdjos Quote Share this post Link to post Share on other sites
totti 13165 Posted November 10, 2015 Od Clia 3 i Megana 3, pa na ovamo, plus jače verzije 1.5 u Meganu 2. Oni nemaju takve probleme. Quote Share this post Link to post Share on other sites
dellas 1556 Posted November 10, 2015 Tacno tako Totti ali Srbin je cuo da tu ne valjaju dizne i turbine i to mu je dosta Imao sam megana 11.2006 pravih 200k auto utegnut kao pracka nova generacija motora 131ks lepa oprema i jedva ga prodao za mizeriju od para...svi potencijalni kupcu su se plasili nekih stvari koje nemaju veze sa tim motorom, to je motor nam kom su sve mane otklonjenje ali ne treba objasnjavati. Quote Share this post Link to post Share on other sites
igor0511 2882 Posted November 10, 2015 Imenjače lep ti je ovaj auto Da te lepo služi, baš je prava lađa. Verujem da ovde nema onih akrobacija oko ubacivanja dečijeg sedišta kao što si nam pokazivao na skupu A što se Renoa tiče ja čujem samo reči hvale za novije motore. Ali isto tako sam čuo dosta loših stvari za stari 1.5 68ks. Čak i znam par primeraka kojima su stradale pumpe i napravile haos. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted November 10, 2015 Koga zmija ujede taj se posle i guštera boji. Tako i sa Renault-om, ortak je dva ili tri puta radio zmije tj Rešoa i sad će strah prenositi sa kolena na koleno.Ovo je izgleda predstavljanje automobila ? Obelixu čestitke na đuntici. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted November 10, 2015 Obelix otvvara piljaru tu u kraju, pa se ponovio za posao malo Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted November 10, 2015 Pa još i prikolica da prođe atest. Quote Share this post Link to post Share on other sites
asterix 7 Posted November 11, 2015 Hvala na cestitkama drugari. Prikolica je prosla odavno,ali sad imam drugu muku.Nemam kuku.I jos samo neko da ubaci muziku na muku i kuku i....pravo kod Sase popovica. Verujem da ovde nema onih akrobacija oko ubacivanja dečijeg sedišta kao što si nam pokazivao na skupu Nema ime iz vise razloga.Ogroman je prostor iza prednjih sedista a i svrca je porastao,sad ulazi sam. Ko ne promeni auto sa 3 vrata dok ima bebca,taj ne mora da ga menja posle nikada. Quote Share this post Link to post Share on other sites
