borat 4 Posted March 26, 2013 htedoh da promenim filter vazduha kad pogledam glava jednog srafa skroz pojedena,bukvalno samo mali krug u velikom ima li tu nekog spasa. Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted March 26, 2013 Ima ! Busilica, burgija i kontra smer okretanja ! :) Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 26, 2013 Ili...Ako je to sve cvrsto okolo, nemoj da razbijes plastiku... Napravi rez cekicem i ravnim srafcigerom, da udje jedno milimetar, milimetar i po...ovako...zabodi srafciger, iskosi ga malo i kuckaj polako cekicem...Znam da se na ovaj nacin cesto zavrcu i odvrcu filteri goriva Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted March 26, 2013 ... ili brusilica pa da zareze kanalic u koji ce gurnuti jaci srafciger i opala ... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 26, 2013 (edited) ili... Nema vece srece kad te nesto ovako spotakne, a ti ga resis na neki "svoj" nacin...prozboris koju rec sa zlotvorom, opsujes, i budes ponosan na sebe Edited March 26, 2013 by milutin-NS Quote Share this post Link to post Share on other sites
Bukvic 0 Posted March 26, 2013 Može da se zavari matica na tu propalu glavu i odviješ kao čovek ključem. Može da se zavari co2 aparatom, neće da istopi ništa uz malo vode i smisla za rad. Quote Share this post Link to post Share on other sites
tox 42 Posted March 26, 2013 Ekstra odgovori,inace sam koristio kad treba sve ove metode po potrebi ali me bas zanima da li ove fore samo skoro svaki balkanac zna ili to inace ljudi znaju i koriste...Ipak mislim da se mi rodimo sa tim nekim "predizpozicijama" za snalazenje. Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted March 26, 2013 ... a odakle coveku sada i aparat za varenje pored sve ove navedene opreme ? Quote Share this post Link to post Share on other sites
Bukvic 0 Posted March 26, 2013 Ode tamo gde radi auspuh, tamo imaju sigurno. Majstore, nisi jedini majstor nemoj da se odmah ljutiš ima ovde još majstora koji po nešto znaju. Ja sam naveo jednu proverenu ideju i to realnu i ako neuspe nijedna koju ste predložili ima i ovu koju će mu neko napravit. E sad možda ima nekog prijatelja ili rođaka koji još ima aparat, a mi to svako neznamo i netreba da znamo, bitne su ideje kako može. U ostalom ova tema može još nekome poslužiti Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted March 26, 2013 Majstor nisam, ali hvala na komplimentu ! Naravno, slazem se u potpunosti samo se nismo razumeli ! Quote Share this post Link to post Share on other sites
Dr. Tuborg 37 Posted March 27, 2013 Ja sam jednom imao takvu situaciju i sraf sam odvrnuo super lepkom. Nije skroz oblajznuo nego je imao malcice citavih kanalica gde ulazi srafciger ali nedovoljno da uhvati srafciger i odvrne. Onda sam uzeo loctite power gel i iscedio u sraf pa uzeo stari srafciger i gurnuo u lepak. Sacekao 5 minuta da se dobro stegne srafciger za sraf i tako odvrnuo. Mislio sam da nece da se skine ostatak lepka sa srafcigera ali sam i to uspeo. Mada je najbolje da odes do nekoga da ti pecne aparatom za varenje maticu za sraf i eto. Quote Share this post Link to post Share on other sites
Gusar 4 Posted March 27, 2013 za adekvatan pristup je porebna informacija o koraku navoja na srafu? Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted March 27, 2013 Ajde gusaru ne komplikuj! Quote Share this post Link to post Share on other sites
Gusar 4 Posted March 27, 2013 (edited) pa ako je krupan navoj moze super lepkom a ako je sitan masinski navoj u siluminu moze samo da ga razbusi... Edited March 27, 2013 by Gusar Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted March 27, 2013 Sta li je sad smislio ovaj stari prepredeni sabljom masuci Gusar ?! Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 27, 2013 Nekog će da boli. Još ako se razmaše eto belaja. Vidiš strah u papiginim očima. Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted March 27, 2013 (edited) Samo se namece ! Edited March 27, 2013 by Mijailović P. Quote Share this post Link to post Share on other sites
sindrom 18 Posted March 27, 2013 za adekvatan pristup je porebna informacija o koraku navoja na srafu?...i jos da li je levi ili desni, masinski ili konusni... Quote Share this post Link to post Share on other sites
Dragan G 0 Posted March 27, 2013 (edited) Zazbusi mu "kapu" tako da uzmes burgiju te sirine kao kapa srafa i kad mu skines kapu mocices da skines poklopac i odvijes ga smrt klestima. Edited March 27, 2013 by Dragan G Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 27, 2013 Kolko duuuugo skida. Dok zameni filter ulje ima da omatori. Quote Share this post Link to post Share on other sites
Dr cosworth 5 Posted March 27, 2013 pa ako je krupan navoj moze super lepkom a ako je sitan masinski navoj u siluminu moze samo da ga razbusi...A da proba da ga navrti u 12000rpm mozda se odvrne sam Quote Share this post Link to post Share on other sites
TachkaTattoo 0 Posted March 4, 2014 Pozz svima.. Hteo sam da promenim plocice...E sad, kad sam krenuo da odvrcem ona 2 torex srafa sto drze klesta kociona, jedan je skroz oblajznuo. Ima neko neki predlog sta da mu radim? Hvala unapred Quote Share this post Link to post Share on other sites
