Lufti 690 Posted August 9, 2016 Hvala puno svima na pomoci!!!!! Quote Share this post Link to post Share on other sites
Lufti 690 Posted August 9, 2016 Gospodin koji se oglasava na kupujem-prodajem i koji izradjuje stampane ploce, je odustao od pravljenja ploce za gp-a, kaze suvise komplikovano...Zvao sam jos dvojicu, sutra ocekujem odgovor... Ukoliko znate nekog ko zna da napravi stampanu plocu, prosledite mi broj... Hvala unapred! Quote Share this post Link to post Share on other sites
Lufti 690 Posted August 17, 2016 Resen problem!!!! Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted August 17, 2016 Odlično izgleda! Šta si na kraju napravio? Otpornik jel morao ili radi i bez njega? Quote Share this post Link to post Share on other sites
Lufti 690 Posted August 18, 2016 Stavljeni su smd otpornici, za sada sve svetli, videcemo samo dokle... Quote Share this post Link to post Share on other sites
darkman14 5902 Posted August 22, 2016 Svaka čast, super izgleda. Lepo si odradio! Quote Share this post Link to post Share on other sites
Jovann990 0 Posted October 8, 2018 (edited) Pozdrav! Potrebna mi je pomoc u vezi zamene sijalice na centralnoj konzoli na Fiat Grande Puntu 2014... Crkla je jedna od sijalica koja osvetljava desnu stranu komanda za grejanje... U pitanju je ovakva konzola... Edited October 8, 2018 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Pluto 448 Posted October 8, 2018 Najbolje da se obratiš Ivan Led Masters na facebook-u. On je profi za takve probleme. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted October 8, 2018 Nema potrebe kad ima u ovoj temi pojašnjeno u čemu je problem. @Jovann990 Pogledaj sada, nakon spajanja, sve ranije napisano u temi na kojoj smo. Quote Share this post Link to post Share on other sites
rage_man 130 Posted May 19, 2019 Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted May 29, 2019 @Lufti kolega zamolio bih ako imaš vremena da napišeš ukratko kako si rešio osvetljenje klime,radia.....i ostalog pošto sam video u tvojoj temi da si kompletnu rasvetu zamenio. Ukoliko imaš slike bilo bi super. Hvala najlepše. Quote Share this post Link to post Share on other sites
rage_man 130 Posted May 29, 2019 Vezano za temu, primetih da mi srednji deo konzole gde su prekidaci slabije svetli, uz pomoc videa sa yt rasturim sve ne bi li zamenio sijalice, otvorim i imam sta da vidim, neki rapalj umesto sijalica premostio na jedan kabal i zalemio komad led trake koja ide horizontalno kroz prekidace.Prso sam ko dinja, kako bre moze neko da bude takva sirovina? Naravno plasticnih caurica od sijalica nema, pa reko da pitam da nema mozda neko visak 2 ili 3, ne znam koliko bese tacno ide, i drugo pitanje, sme li se iz tog jednog kabla premostiti komadima zice ka drugoj sijalici, sve ovo u slucaju da nadjem te plasticne caure u koje idu one male ubodne sijalice?Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
Lufti 690 Posted May 29, 2019 Evo kako elegantno moze da se resi osvetljenje komandi ventilacije ako je u pitanju manuelna klima:Sent from my SM-A510F using TapatalkMislim da postoji na ali-ju da se kupi ovaj panel. Kod mene je to drugacije reseno, oko cele ivice sa unutrasnje stranr je zalepljena led traka koja osvetljava citavu unutrasnjost kutije + su razvedene zice i tri diode posebno za osvetljenje komandi klime, recilkulacije vazduha i grejaca zadnjeg stakla. Napajanje je dovedeno sa postojecih ubodnih sijalica koje su izvadjene. Sto se tice automatske klime, tu je situacija mnogo laksa, samo se zamene smd diode 2835 koje su kod grandea svuda, i u radiju, cajgeru, ostalim komandama u kabini sa izuzetkom komandi na volanu ( tu idu one najmanje, ne znam tacno dimenzije ali ih ima u mikro princu na slaviji) i podizacima prozora gde idu one sa nozicama, kao lampica.Sent from my SM-A510F using Tapatalk 1 Miki.Zvrk reacted to this Quote Share this post Link to post Share on other sites
Lufti 690 Posted May 29, 2019 Slike nemam ali nema neke velike mudrosti. Sve se pazljivo povadi i otvore se plastike i zamene diode. Za ceo auto nekih 4, 5 sati posla. Tu sam ako treba da se nesto pojasni. E da, menjao sam osvetljenje i na evu. Tu su u radio stavili te najmanje smd, pa je tesko pogoditi istu nijansu boje, bar u slucaju bele koju sam ja stavio. U ostatku je sve isto kao u grandeu s tim sto su u prekidacima podizaca prozora takodje smd, 2835.Sent from my SM-A510F using Tapatalk 1 Miki.Zvrk reacted to this Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted May 30, 2019 @Lufti A jel ti potrebno dodati smd otporni na led traku? Quote Share this post Link to post Share on other sites
Lufti 690 Posted May 30, 2019 Ja nisam dodavao otpornik jer je na traci bilo oko 20 dioda...Sent from my SM-A510F using Tapatalk 1 Miki.Zvrk reacted to this Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted May 31, 2019 (edited) zasno nije belo? Bela led traka a koliko vidim be moguća promenim onakvo narandzasto Edited May 31, 2019 by Miki.Zvrk Quote Share this post Link to post Share on other sites
Lufti 690 Posted May 31, 2019 Moras da skines narandzastu foliju, ja sam je pazljivo izgrebao a mislim da ima na yt-u i clip gde to skidaju pomocu stapica za uvo i nekog razredjivaca, ili je mozda benzin u pitanju. Uglavnom, to moze da se resi ali pazljivo i polako... 1 Miki.Zvrk reacted to this Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted May 31, 2019 Evo sad sam malo pogledao, krenuo da skidam i video. Samo još jedno pitanje :-D Ugasim auto a led dioda trepte. Znači treba da dodam neki odpornik? Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted June 6, 2019 Pre svega želeo bih da se zahvalim kolegi Lufti-ju i kolegi Novo Sadjaninu na izdvojeno vremenu a i strpljenju.Sama akcija je trajala oko 12h konstantnog rada i razmišljanja.Imali smo par stvari koji su za nepoverovati (ni jedna žabica nije pukla,jedva izvadili air bag) ali uprkos svemu uspeli smo da završimo 90% :-D@lufti je jedno 4h ako ne i više uz pomoć alkohola,acetona,šrafcigera,igle i ostalih pomagala grebuckao plastike na ventilaciji kako bi sijalo belo i izvanredno je uradio!Ja sam prezadovoljan ispalo je sve kao što sam zamišljao. Tako da sad imamo više iskustva pa možemo pomoći sledećem ko bude zeleo da radi.Послато са SM-G965F помоћу Тапатока 1 rage_man reacted to this Quote Share this post Link to post Share on other sites
