dule_tejic 0 Posted August 28, 2011 Ja pitao za NGK DCPR7EN10 svecicu...ona ide na noviji tip motora od 2004 pa na gore a i ne moze da se usrafi u ovaj motor jer je precnik manji tako da cu staviti ove BKR5EZ pa javljam Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 1, 2011 Ponedeljak/utorak stavljam svecice nove, e sad izbor je ili NGK standard, ili NGK V-line, zna li neko koja je razlika i vredi li stavljati V-line koje su neznatno skuplje? Sada cu malo googlati ali cisto ako neko je probao, ili zna, cuo, video... Quote Share this post Link to post Share on other sites
Phikret 0 Posted November 23, 2011 (edited) Može savet koje svećice i kablove za Punto 2 1.2 8v da uzmem? Koji proizvođač i gde ima? Edited November 23, 2011 by neshaoct spojena tema Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted November 23, 2011 svecice po propisu, NGK BKR 5EZa za kablove nek ti kaze neko drugi... Quote Share this post Link to post Share on other sites
oktopod 283 Posted November 23, 2011 Kablove nemoj nikako Facet, par ljudi sa foruma imalo problem da spadaju sa svećica pa i ja lično, ako imaš novaca original su bili manje od 7000 dinara pre godinu dana, ako možeš nađi Bosch, Tesla takođe nisu loši ako nemaš plin. Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted November 23, 2011 koji/kakvi su to "original" kablovi? Kakvu oznaku imaju? Proizvodjac? Model? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted November 23, 2011 Priča o kablovima ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=38664 Quote Share this post Link to post Share on other sites
rokieps 0 Posted March 24, 2012 (edited) Moze li mi neko reci sa koji svecicama za Punta 1.2 sporting je zadovoljan? Trenutno koristim Champion ali nista ne valjaju... Edited March 24, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
simonen 81 Posted March 24, 2012 NGK DCPR8E-N ,fabrički preporučena svećica,kod mene rade perfektno Quote Share this post Link to post Share on other sites
kanjavi 3 Posted March 24, 2012 Evo ja danas promenio svecice uzeo sam NGK BKR5EZ 380 din kom. za sad sve ok! U pitanju je punto2 1.2 8v 2001 god. Quote Share this post Link to post Share on other sites
rokieps 0 Posted April 4, 2012 a champion svecice da li odgovaraju Champion ja trenutno koristim i ocajne su...a cena im je visoka a kvalitet los.. Quote Share this post Link to post Share on other sites
maky985 0 Posted June 11, 2012 pozz svima...ja sam pre 13000km menjao svecice,uzeo sam DENSO i bilo je ok.ali mi se sada desava da malo slabije vuce.e sada moje pitanje na koliko km da ih menjam ili sam mozda vec trebao?kablove nisam jos menjao a mislim da bi bio red i oni da se promene...i da li da opet uzmem denso ili da ipak uzmem NGK?hvala Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted June 11, 2012 Na "plinu" se najpre oseti da su svecice i/ili kablovi vec za zamenu. U principu , neces ze prevariti bilo koje da uzmes s tim da bude odgovarajuca toplotna vrednost. Sve to stoji u katalozima u samim radnjama kod prodavaca. Quote Share this post Link to post Share on other sites
maky985 0 Posted June 11, 2012 onda cu ipak sve da zamenim da ne bude nekih problema...kupicu denso ko i prosli put.hvala Quote Share this post Link to post Share on other sites
Yugiša 0 Posted June 11, 2012 Jel zna neko šta fabrika preporučuje od sveća za Punta HGT 1.8 16v ? Quote Share this post Link to post Share on other sites
Dača01 1 Posted June 12, 2012 Ajde jedno laičko pitanje...I meni su u prodavnici preporučili za puntića NGK BKR 5EZ. E sad, pročotah negde da upravo one mogu da budu problem seckanja, jer je navodno ta temperaturrna vrednost svećice suviše mala, pa pravi problem. Ako ti se ugasi, navodno ne možeš upaliti auto dok se svećice ne ohlade...Da ne napominjem što po tehničkom uputstvu idu NGK DCPR 7E-N-10....U čemu je fora? Quote Share this post Link to post Share on other sites
maky985 0 Posted June 12, 2012 evo samo da kazem danas sam zamenio svecice(denso) i kablove magneti mareli i auto ide ko blesav Quote Share this post Link to post Share on other sites
Hardvet 2 Posted June 12, 2012 Ajde jedno laičko pitanje...I meni su u prodavnici preporučili za puntića NGK BKR 5EZ. E sad, pročotah negde da upravo one mogu da budu problem seckanja, jer je navodno ta temperaturrna vrednost svećice suviše mala, pa pravi problem. Ako ti se ugasi, navodno ne možeš upaliti auto dok se svećice ne ohlade...Da ne napominjem što po tehničkom uputstvu idu NGK ....U čemu je fora?Meni u tehnickom uputstvu za Z10 2007. stoji ovo sto si napisao,BKR 5EZ.To ni fabricki nije bilo u njemu. Sad su mi trenutno DCPR 7E-N-10, a pre toga su mi u ovlascenom servisu stavili neke sa toplotnom vrednoscu 8 !!!I dan danas mi nije jasno ko me je zajebao, a ko nije... Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 21, 2012 (edited) Standardno ne mogu da pogledam nista sa postimage...Po mom uputstvu u Z10 idu svecice sa toplotnom vrednoscu 5.ALI, auto sa tim svecicama nije ni stigao. Bio je NGK sa vrednoscu 7.Prva zamena u ovlascenom servisu, stavili su NGK sa toplotnom vrednoscu 8!Druga zamena svecica, po NGK katalogu ide vrednost 7, ponovo.Pa sad mi recite ko koga tu...?A, što vrtiš servise? Šta te briga šta oni pričaju? Šta te briga i da sam Isus Hrist siđe sa neba ponovo posle 2012. godina i kaže koje ulje se sipa u menjač... Šta te sve to briga kada imaš knjižicu u kojoj piše koje ulje treba, koliko litara, znaš koje karakteristike to ulje ima. Šta za svećice...nisam razumeo?Jel' ne idu ove NGK ili Bosch koje su napisane:Ne znam da li odlazis u servise gde samo ostavis auto i kazes sta treba da se uradi? Mislim na ovlascene . I nemas nacina da vidis sta je sve uradjeno i sta je sipano ili ugradjeno.Ako odes u toj varijanti, otkud znas ko radi po kojim normativima i sta sipa od motornog, menjackog, kocionog ulja, koje svecice stavlja...?Svako ti moze potvrditi da servisi, i ako svi ovlasceni, imaju razlicite preporuke o odrzavanju vozila, ukljucujuci cak i servisne intervale, kao i sve gorepobrojano. O razlikama u ceni i da ne govorimo.Zato je jako uputno cuti se sa ljudima preko telefona ili licno.Da ne shvatite pogresno, to je samo moje misljenje na osnovu godina i godina odrzavanja auta vecinom u ovlascenim servisima. Edited July 25, 2012 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted July 21, 2012 Još ako u igru uključiš i kataloge proizvođača svećica, ulja i ostalog onda igranka može da počne. Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 21, 2012 (edited) To je to.Katalozi proizvodjaca mogu da se ne slazu sa fabrickim podacima. Pored toga sto se servisna uputstva samo stancuju i nekad u pojedinim detaljima ne odgovaraju situaciji na autu( svecice kod mene), sama fabrika jednostavno promeni preporuceno ulje. Menjacko na pr., bez obzira sta je stiglo sa kolima i da li moze da se mesa.Onda fabrika da razlicite preporuke razlicitim ovlascenim servisima.Na kraju vlasnik sam nema pojma sta mu je u kolima i sta dalje da stavlja. Edited July 21, 2012 by Hardvet Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 24, 2012 ...Po mom uputstvu u Z10 idu svecice sa toplotnom vrednoscu 5.Možeš li da uslikaš taj deo teksta gde piše da idu svećice sa tom i tom toplotnom vrednošću?Okačio sam gomilu vlasničkih uputstava na forum, svako morao da pregledam od prve do poslednje strane da vidim da je sve ok urađeno, skenirano, prebačeno u pdf ili šta je već sa tehničke strane urađeno, i nigde nisam pronašao da tako nešto piše, već piše koji proizvođač i oznaka. Nikakve toplotne vrednosti...Imamo vlasničko uputstvo za Punto Classic na forumu:http://www.fiat-lanc...showtopic=44461- NGK DCPR7E-N-10- Bosch YR7DEU Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 24, 2012 Toplotna vrednost je sadrzana u nazivu svecice.Iz ova tvoja dva primera:DCPR 7YR 7Bez obzira sto su razliciti proizvodjaci, vidis da je ista toplotna vrednost.Kod mene pise BKR5EZ, Fiat ili NGK sa istim oznakama. Toga se secam i imam upisano kod sebe, jos kad je trebalo prvi put menjati svecice na 30k.Ovo vlasnicko uputstvo sa foruma je izgleda ok. Moja verzija je ocigledno malo zastarela i netacna. To mislim po tome sto znam da su stariji 1.2 8v motori iz Puntica stizali upravo sa ovim svecicama propisanim kod mene u uputstvu.S obzirom da imam neki podatak da je glava na tom motoru menjana od 2004, mozda je od tad i preporuka za svecice promenjena, a u pojedinim uputstvima su nastavili da pisu neistine... Quote Share this post Link to post Share on other sites
Branko 23 1 Posted July 24, 2012 bas tako,to je za stare euro 3 motore,za starije glave i navoj je drugaciji,imas ti mnogo nebuloza oko zastave 10,pa ukucas sasiju u fiatovom programu i ono kaze punto 1.9ds iz 99god,jer su te sasije povukli iz otina koje su bile slobodne i dodeljivali kod nas,e sad to kao kristalisu,ali ne mogu sve,sve u svemu kod tebe svecice idu 7,a ulje ono koje ti je nesa napisao,ali opet ponoavljam i ti si rekao istinu,kada jednu kazu ovo ulje drugi kazu ono,ma u sustini bitno je da se kupka ,da nije suvo ! Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 24, 2012 Dobro, sad bar saznah da mi sasija nije iz proslog veka! Moja izbacuje adekvatne podatke kad se proveri. Quote Share this post Link to post Share on other sites
