toma ks 19 Posted August 20, 2019 Uzmi Brembo slobodno hahahha Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 U Euroautu sam i video za Brembo. Sent from my SM-G950F using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
toma ks 19 Posted August 20, 2019 Pa zato i kazem radim u euroautu zaboravio si 1 Flex reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted August 20, 2019 Ate uzmi Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Nesto ne nalazim ATE (nemaju ni Gazela, ni Euroauto). Gde da pogledam? Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17670 Posted August 20, 2019 (edited) ATE imas u Mass Company (ako imas FLCS clansku karticu ostvarujes i popust od 10%). Isto vazi i za Galfer, "Slajer d.o.o" (koji bi btw bio i moj izbor). Edited August 20, 2019 by Ivan 2 Flex and neshtry reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Sad sam proverio cenu, 6250 diskovi + 3480 za plocice. Ako vredi dati skoro duplo vise od Brembo varijante u Euroautu onda da uzmem njih? Sent from my SM-G950F using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted August 20, 2019 Secam se da je Galfer komplet za Stilo pozadi bio 65-70 EUR sa popustom, u "Standard" varijanti (ne one skuplje). Na tebi je da odaberes , a sta god da uzmes, obavezno proveri stanje klesta pozadi, znaju da budu problematicna na Stilu. I ako vec nisi, zameni kocionu tecnost, to je smesan trosak ako sebi ostavljas auto... Imas i u ovoj temi bas detaljno oko izbora, pa sacni ako te zanima: Quote Share this post Link to post Share on other sites
darkman14 5900 Posted August 20, 2019 14 minutes ago, Ivan said: Galfer komplet za Stilo pozadi bio 65-70 EUR sa popustom Mislim da je mene tako izaslo za Deltu, a to je to isto Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Evo sta su mi odgovorili : Ivane, hvala na savetu. Zamenio sam tecnost prosle godine cim sam ga uzeo. Klesta su pretpostavljam ok jer bi mi Goran rekao da nisu(skoro sam bio kod njega). Samo da vidim kod kog od ovih sustera iz Krusevca da odem da zameni. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17670 Posted August 20, 2019 Znaci, malo skuplje nego ranije (preracunato u EUR), sa popustom bi to bilo 75 EUR. Ali dobijas "High Performance" plocice, a ne "Standard". Uporedi i ostalu ponudu, pa proceni. Klesta mogu da rade OK, ali pogotovo kod zamene diskova+plocica treba obratiti paznju posle zamene. Jer je onda klip mnogo sabijeniji nego kod istrosenih diskova+plocica, pa ako klip zariba (u delu koji je bio napolju) sapa zna da ne otpusta kako treba. Cisto povedi racuna kad sve to odradis, da li klesta i trunku blokiraju, da ne spalis novu robu . Mislim da sam zadnja klesta 2 puta reparirao za 10-ak godina, nije to bas najsrecnije reseno, sa prednjim ni najmanji problemcic (generalno je tako sa Stilom). Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Znaci nema greske sa ponudjenim. Pa onda cu to, necemo da stedimo na kocenju. Kako najlakse da proverim da li je sve ok posle zamene? Jer mislim da je skoro Goran resavao problem sa zadnjim levim tockom (naravno ovde niko to nije pomenuo) jer nije otpustalo valjda skroz. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Umalo da zaboravim. Desava mi se (samo dok je hladan auto) dok lagano ubrzavam (negde oko 1500 obrtaja) da stucne par puta (kao da guta knedle) pa nastavi da ide normalno. U kom pravcu gledati? Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
danijel55 700 Posted August 20, 2019 Za ate mislim da nema greske.Meni su na bmw-u bile ate,prednje plocice su imale za jos 2000km,kocio odlicno,nikad skripnule nisu.Isto sam se ponovio istim.Meni su diskovi,plocice i paknovi za zadnje tockove izasli 14500din.Ate imao sam popust 10%. EGR jer blokiran?Map i protokomer bih ocistio i blokirao egr ako već nisi.Pa bih tek onda dalje trazio. Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Blokirao je Goran egr skoro, ostalo nije dirano. Ocisticu map za pocetak. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Axic 20048 Posted August 20, 2019 10 hours ago, Flex said: Malo se oprali posle kise. Ovih dana menjamo zadnje plocice i diskove, ostalo bez problema. Da uzimam Brembo? Jel ga spremaš za neki offroad? nešto mi deluje baš podignut ako te već nisam pitao zašto je ovako "visok". Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Cini ti se, nije nesto visok. Da je nizi ne bih nigde mogao da prodjem a da ne izlomim pleh. Sent from my SM-G950F using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted August 20, 2019 Mnogo je crna felna pa umanjuje tocak vizuelno. Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
danijel55 700 Posted August 20, 2019 Al nekako mi kvari sliku ova sara,da je linijska bilo bi sve 5 Quote Share this post Link to post Share on other sites
Axic 20048 Posted August 20, 2019 Napred se baš primećuje razlika od gume do krila, mislim da bi za 5cm niže bilo idealno. Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 20, 2019 Bilo bi lepse svakako ali ne bih mogao da udjem u dvoriste onda nikako a i ostavio bih pleh negde po ovim putevima. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Axic 20048 Posted August 20, 2019 Parkiraj ispred dvorista Quote Share this post Link to post Share on other sites
MS PK 7734 Posted August 21, 2019 Malo se oprali posle kise. Ovih dana menjamo zadnje plocice i diskove, ostalo bez problema. Da uzimam Brembo? Sent from my SM-G950F using TapatalkMa prosetaj cas do Bg, sta ima da razmisljas uopste Послато са SM-J330F помоћу ТапатокаUmalo da zaboravim. Desava mi se (samo dok je hladan auto) dok lagano ubrzavam (negde oko 1500 obrtaja) da stucne par puta (kao da guta knedle) pa nastavi da ide normalno. U kom pravcu gledati? Sent from my SM-G950F using TapatalkU pravcu dizne mozda Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted August 21, 2019 Bas sam se pitao sto vec nisi ovako nesto napisao. Ajde mozes i ti sa mnom, da sredis taj safe mode sto ne izlazis iz njega. Zamenio sam dizne skoro (kad sam jurio oko vibracija), mada biiip li ga. Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7734 Posted August 21, 2019 Hteo sam juce al reko necu ali danas nisam mogao da odolim ipak Pa brate to sto si menjao dizne...jesu li gledane pre toga ood bosiste? Nisu? Nisam ja u safe mod, puni do kraja uvek, pogotovo sada, izbaci gresku samo nekad na 3000rpm i ide dalje. U safe je upao lupam 3 puta za ove par godine Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
