Milutinac 5906 Posted May 25, 2018 Stigle mi neke sijalice za maglenke E sad pitanje... da li ceo ovaj deo ...ide u napred (sto je mnogo laksa varijanta) ili se mora zavlaciti ruka iza, sto mislim da nema sanse bez dizalice i skidanja onog sus-pleha sa strane, ili cak mozda i skidanje tocka + podkrila? Menjao neko slucajno ili mozda zna kako? Quote Share this post Link to post Share on other sites
Dezurni 399 Posted May 25, 2018 Skidaš šuspleh (i baciš) i onda zameniš sijalicu Mislim da ne može da se dohvati sijalica kada se skine ta plastika oko maglenke. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 25, 2018 No.more.weight.reduction.bro. To sto ti kazes deluje logicno, ja samo pitam jer imam utisak da moze sve to da ide i unapred... Quote Share this post Link to post Share on other sites
totti 13165 Posted May 25, 2018 Sent from my SM-G950F using Tapatalk 2 Dezurni and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Ivan 17679 Posted May 25, 2018 Kakav si ti to moderator ... Odes, zamenis sijalicu, islikas, postavis temu u "Uradi sam" i lepo objasnis nama ostalima. Je li tako, @Dezurni ? A ja znam, ali necu da ti kazem . Quote Share this post Link to post Share on other sites
Dezurni 399 Posted May 25, 2018 Kako on to duradi kad mora da spava popodne??? Quote Share this post Link to post Share on other sites
dekirs 4819 Posted May 25, 2018 #pravda za Milutina 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Ivan 17679 Posted May 25, 2018 (edited) Zamena sijalice: Skidanje cele maglenke: Stelovanje maglenke: Edited May 25, 2018 by Ivan 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted May 25, 2018 @Milutinac Mislim da te @Dezurni lozi ovim klipom Samo nije napisao "Mi u Deutchland to ovako radimo..." tj ne menjaju sijalicu vec dodaju 2 1 1 Milutinac and Dezurni reacted to this Quote Share this post Link to post Share on other sites
Dezurni 399 Posted May 25, 2018 Moram malo. Nisam odavno Quote Share this post Link to post Share on other sites
Ivan 17679 Posted May 25, 2018 (edited) Gde je prednja, tu je i zadnja . Jedna slika, 1000 reci... Zamena sijalice: Zamena maglenke: Edited May 25, 2018 by Ivan 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 25, 2018 5 hours ago, Ivan said: Kakav si ti to moderator ... Odes, zamenis sijalicu, islikas, postavis temu u "Uradi sam" i lepo objasnis nama ostalima. Je li tako, @Dezurni ? A ja znam, ali necu da ti kazem . Pa rekoh prvo da pitam da li problemu da pristupim od nazad khm ili tako reci od napred a za posle cemo lako... 4 hours ago, Dezurni said: Kako on to duradi kad mora da spava popodne??? Kakav beauty sleep kad znas da sam bio na sarani to mi sve planove pokvarilo jebemgabas 4 hours ago, Dezurni said: Pa vidim ja da bi taj "poklopac" mogao ici "dole" 4 hours ago, Ivan said: Zamena sijalice: Skidanje cele maglenke: Stelovanje maglenke: E to je to. To je koristan post. Hvala kolega Ivane. 2 hours ago, Ivan said: Gde je prednja, tu je i zadnja . Jedna slika, 1000 reci... Ovo sam vec odradio, na parkingu, lagano. LED je sada nazad, sija jako lepo... Quote Share this post Link to post Share on other sites
shomispc 832 Posted May 25, 2018 Ne mora nista da se skida, meni je bane juhica montirao za dva minuta obe, samo je gurno ruku odozdo i magija Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 25, 2018 Kako kad je apsolutno sve zatvoreno...veliki sus pleh, mali sa strane i podkrilo, nemam gde ruku jednostavno da zavucem. Idem uskoro kod majstor Staneta da radimo svasta nesto pa kad bude u vazduhu lako cemo... Sto se sijalica ovih tice - ocekujte neocekivano Quote Share this post Link to post Share on other sites
shomispc 832 Posted May 27, 2018 brate ne znam, mozda kod mene nema tih bocnih susplehova, a mozda se covek izvestio ubacio mi je neke bear h11 led, mislim da je 30-35e bio par i sijaju za sve pare i evo rade vec godinu dana da ne ureknem Quote Share this post Link to post Share on other sites
Ivan 17679 Posted April 13, 2020 Iako iznad ostavljah i detaljna objasnjenja iz eLearn... Natrcah na netu, prilicno korisna slicica za temu, u slucaju skidanja maglenke. Pogled sa zadnje strane , sa izvadjenom H11 sijalicom: 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted April 17, 2020 Nesto sam merkao danas na parkingu, unutrasnjost maglenke je solidno nagorela. Kada sam skinuo plastiku, 2 srafa su sa unutrasnje strane koja se moraju odsrafiti i to je to...e sad da li bi trebao auto malo podici napred (tipa ivicnjak) da bi se srafovima pristupilo ili mora (u) kanal ? Hteo bih mu nekako ocistiti unutrasnjost sa alkoholom, bar malo da se stanje sredi. Sent from my S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17679 Posted April 17, 2020 (edited) 1 hour ago, ISV_01 said: 2 srafa su sa unutrasnje strane koja se moraju odsrafiti i to je to Nije . Imas i treci sraf sa spoljne strane. Tj. pomeri se potkrilo, odsrafe tri srafa sa zadnje strane koji drze maglenku, zarotira H11 sijalica (ili skine konektor). Skida se i ukrasna maska sa prednje strane i izvlaci maglenka ka napred. Ostavio sam gore i proceduru iz eLearn i sliku maglenke sa zadnje strane (bas iz razloga skidanja). Samo treba pogledati . 1 hour ago, ISV_01 said: Hteo bih mu nekako ocistiti unutrasnjost sa alkoholom, bar malo da se stanje sredi. Nista od tog posla, to im je fabricka mana i plastika sociva nagori i pozuti vremenom. Sto stariji auto, veca mogucnost da bude u losijem stanju. Ako trazis iz originala novo, maglenka je ziska. Iz originala polovno, tesko ces naci neku da je OK i da nije vec nagorela, a krecu se 25-30 EUR. Zamensko novo, imas Depo, TYC od 30 EUR pa navise. PS: Ako trazis polovno iz originala - odgovara ti i sa restyle Brava, stare i restyle Delte, kao i samo sa restyle Crome. Identicne su, a ako kolegi ne verujes na rec , lako se proveri Compatibility u ePer. Originalnu maglenku lako prepoznajes i po serijskom broju, a i sto u cosku sociva stoji ugravirano Fiat, Lancia, Alfa Romeo. Edited April 17, 2020 by Ivan 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted April 17, 2020 Uh, znaci samo polovno dobro ili novo da bi imalo efekta....Sent from my S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17679 Posted April 17, 2020 Mozda se neko dopise sa boljim resenjem, to je moje iskustvo. Meni je desna maglenka odlicna, a leva malo krenula da zuti kod sijalice. Verovatno Svajcarac vozio levi krug na stazi . Tako da sam vec gledao ponudu OEM polovnih. I sta god da su mi na slikama poslali najbolje sto imaju, primetno je gore od te moje . Na sve to, Bravaca/Delti za delove i nema bas, u smislu da mozes da proberes kao ranije za Stila. Zato ti i "ispucavam" i cene i ponudu. Za sada mi stoji tako, ali vrlo moguce da cu kada mi bude vise bolo oci skoknuti da kupim novu maglenku i zamenim, a ovu bacim u oglase. 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted April 17, 2020 Tako i ja mislim da ce biti..nisu bas zagorele cele kod mene, vidjao sam dosta gore. Ima dosta do sijalice i UV zastite kod njih, neke sigurno 'imaju' zastitu a neke stvarno imaju. Ja turio LED 2300K sada, manje se greju a voltaza ista 55w bez ikakvih drangulija, samo plug n play...do sledeceg tehnickog, u Areni umeju da drndaju zbog ne-oem stvari. Ipak bode oci sto je centar fino zaprljan.Sent from my S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted April 20, 2020 (edited) Ja iskopao ovo... Edited April 21, 2020 by Ivan Slika prebacena na FLCS server Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted April 21, 2020 Još malo pa izgleda kao plafonski paneli Quote Share this post Link to post Share on other sites
Ivan 17679 Posted April 21, 2020 (edited) @alfini0507 Ako mislis na skidanje - jesu same maglenke iste (Bravo/Delta/restyle Croma), ali je pristup na Cromi i Bravu totalno drugaciji. Bravo ima usku masku oko maglenke, dok ovde na Cromi vidim da mozes i ruku da zavuces odozgo , zamenis sijalicu i sl... Tako da je postupak za demontazu kao iznad neminovan na Bravu (pristup sa zadnje strane maglenke). PS: I ovome je maglenka spaljena, na ivici za zamenu . Edited April 21, 2020 by Ivan Quote Share this post Link to post Share on other sites
