silenci 2337 Posted August 22, 2015 jeste bilo je reci,hteo sam da svratim do crnog jezera na durmitoru,al nije mi se dalo,uhvatio me pljusak bas samo na durmitoru,posle 15ak km,nista sve suvo,smorio sam se,a bas sam imao zelju da vidim to jezero.A jos i da dodam na granicnom prelazu Jabuka,nema puno guzvi,mozda najvise 10 minuta zadrzavanja na obe granice Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted August 23, 2015 (edited) Evo jedna fotka iz Žabljaka! Edited August 23, 2015 by Mijailović P. Quote Share this post Link to post Share on other sites
majstormica 25 Posted September 1, 2015 Jel ima zastoja kroz kanjon i u kom periodu, ako neko zna? Večeras bi trebalo da putujem. Quote Share this post Link to post Share on other sites
bojankov 36 Posted September 1, 2015 Ako nisi krenuo javi pa cu zvati AMS da pitam...sad vidjoh poruku Quote Share this post Link to post Share on other sites
majstormica 25 Posted September 1, 2015 Krećem oko 22h. Quote Share this post Link to post Share on other sites
bojankov 36 Posted September 1, 2015 (edited) @majstormica Imas kod slijepac mosta jednosmjerna uz semaforsku signalizaciju...ostalo bez zastojaTo je prije kanjona... Edited September 1, 2015 by bojankov Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 1, 2015 Tu ti zadržavanje nije duže od par minuta tako da srećan put. Quote Share this post Link to post Share on other sites
bojankov 36 Posted September 1, 2015 Da. Cim je semafor par minuta najvise...da srecan put...pa se javni u PG ako ces dolaziti :-) Quote Share this post Link to post Share on other sites
majstormica 25 Posted September 1, 2015 (edited) Hvala Mislio sam da je zadržavanje po sat dva pa da idem na zabljak.E pa odoh ja Edited September 1, 2015 by majstormica Quote Share this post Link to post Share on other sites
Marko Topola 50 Posted September 1, 2015 Srecan put! Quote Share this post Link to post Share on other sites
dach@ 4904 Posted June 25, 2017 Ako moze mala pomoc putujem u C.G. u Tivat nisam isao dole 20 god.pa cisto za pravac da li ici na kanjon morace ili preko Zabljaka... Quote Share this post Link to post Share on other sites
silenci 2337 Posted June 25, 2017 ma cepaj preko Zabljaka,tj preko Durmitora,ima da uzivas dok vozis Quote Share this post Link to post Share on other sites
Ticma 537 Posted June 25, 2017 Zabljak, Niksic pa dalje... Quote Share this post Link to post Share on other sites
bojankov 36 Posted June 25, 2017 Kanjon nije tako strasan kao sto se cini. Ja skoro svaki vikend tuda prolazim...samo pazljivo i preticati samo na isprekidanoj liniji ;-) Quote Share this post Link to post Share on other sites
voodoons 349 Posted June 25, 2017 I onda natrci budala koja pretice preko pune i džaba tebi sto ne pretices... Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 25, 2017 (edited) +1 za Zabljak, bar je meni interesantniji i laksi put. Kilometrazom dodje otprilike na isto, a preko Brodareva (i dalje) trenutno postoji par zastoja zbog sanacija. 3 hours ago, bojankov said: Kanjon nije tako strasan kao sto se cini. Apsolutno se slazem. Apropo puta kroz kanjon Morace, za vise od 2 decenije staza prosao sam ceo region X puta i cela prica je, bar iz mog iskustva, nepotrebno naduvana. Ni blizu kako uglavnom po medijima pokusavaju da je predstave - kao i na drugim takvim mestima, malo vise vozacke tehnike i paznje, normalno vozis, normalno pretices i nema nikakvih problema. Slicna prica je i kod nas sa Ibarskom magistralom (ukljucujuci i Dolinu jorgovana), preopterecenje, ima lose infrastrukture i signalizacije, neopreznih vozaca, ali - prenaduvano. Edited June 25, 2017 by Ivan Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 25, 2017 Ne znam za Zabljak ali kanjon jednostavno obozavam, jos u zoru..milina Quote Share this post Link to post Share on other sites
bojankov 36 Posted June 25, 2017 https://youtu.be/NZqUEeZKDJg Vi gledajte a ja odoh sad kroz kanjon :-) Quote Share this post Link to post Share on other sites
Ticma 537 Posted June 25, 2017 Ja volim preko zabljaka posto u 3 ujutru je ceo put tvoj, sretnes 5 automobila celom deonicom u sezoni Quote Share this post Link to post Share on other sites
bojankov 36 Posted June 25, 2017 A ja bas volim kroz kanjon jer preteknes 100 auta u sezoni :-) evo me stigoh u PG kroz kanjoj pod velikim pljuskom :-) Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 25, 2017 Pa lako ti kad si isao nizbrdo Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted June 27, 2017 Emisija SAT: Patrola do Budve kroz kanjon Morače 2017. Quote Share this post Link to post Share on other sites
dach@ 4904 Posted July 2, 2017 Bio do C.G. prvo preko Zabljaka a vratio se kanjonom Morace,meni licno lepse preko Zabljaka malo samo one serpentine dok se nepopne posle super saobracaja skoro da i nema sto se tice kanjona Morace ok je ali ima vise saobracaja pa i kolona tako da je i sporije a ima i radova na par mesta,oba puta dnevne voznje,kanjonom izmedju dve granice ima dosta kamenja i kamencuga verovatno nicije pa slabije ciste Quote Share this post Link to post Share on other sites
