nemke 92 Posted November 20, 2013 hvala. jedva primetno kad je hladan a kad se ugreje cuje se najvise izmedju 2-4000 obrtaja... nisam gledao dizne..nisam ga stavljao na dijagnostiku...kasno je sad da ga teram kod nekog..jer je auto vec kod njega a i jos nije registrovan... aj recicu mu za vodenu pumpu? ne baca nikakav dim... samo dok je hladan izbacuje normalno beli dim.. Quote Share this post Link to post Share on other sites
cane 205 Posted November 20, 2013 Meni zvuci kao neki hidropodizac Quote Share this post Link to post Share on other sites
nemke 92 Posted November 20, 2013 ja iskreno sumljam na hidro podizac... sad u sredu ga otvara pa cemo videti sta je u pitanju.... Quote Share this post Link to post Share on other sites
nemke 92 Posted November 23, 2013 ustanovljen kvar... u pitanju su bila tri ventila koja su bila rastelovana... auto je sad u top stanju... jos registracija Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted November 23, 2013 E super je ispalo tj nije ispala neka komlikacija. Registruj i pun gas :-) Quote Share this post Link to post Share on other sites
cane 205 Posted November 23, 2013 Bravotigabate! Quote Share this post Link to post Share on other sites
MS PK 7735 Posted November 23, 2013 Super! Imao si srece. Quote Share this post Link to post Share on other sites
SikterBre 31 Posted November 23, 2013 Odlično si prošao, dobro je da je sve rešeno Quote Share this post Link to post Share on other sites
nemke 92 Posted November 24, 2013 sad puntic radi kao sat a i ide... Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted November 24, 2013 Super. Registruj ga, pa pisi utiske, kakav je, planiras li da estetski sredjujes i sl. Sa srecom. Quote Share this post Link to post Share on other sites
nemke 92 Posted November 24, 2013 iskreno nesto sam razmisljao o chipu i blow off-u ali koliko je to stetno za motor? nisam pametan... mnogo mi se svidja zvuk blow off-a sto se tice spoljasnjeg izgleda mozda bi ga spustio malo samo... unutra ne bi nista dirao osim table, mislim diodice bi zamenio u belu boju... utisak koji sam sad na prvu loptu stekao u odnosu na moju lanciu y tvrdji,brzi ali ne toliko udoban kao lancia... imam jedan problem sa potrosnjom, na bordu mi pise 5-8km na 1l ... a nisam ga cepao..normalne potrosnje... jel moze da bude problem u bordu.. ali kad ga registujem izacicu na autoput vozicu 100km/h i da vidim koliko trosi na otvorenom.. ja se nadam da mi nece preci 5,6l dizelapozdrav Quote Share this post Link to post Share on other sites
Владимир 15 Posted November 24, 2013 Skoro svaki turbo motor ima neku vrstu fabrickog blow off ventila, koji kad pustis gas rastereti usisnu granu. Tako da to ne steti motoru.. E sad ako hoces da se cuje onaj zvuk onda mora turbina da se podigne na veci pritisak to jest chip i da kupis blowoff..Jedno pitanje,gde si kupio Brembo diskove i koja je cena? Quote Share this post Link to post Share on other sites
nemke 92 Posted November 24, 2013 Ovde sam na forumu citao da chip moze da steti... da li mozda znas gde moze da se uzme blow off i ko to ugradjuje? Inace diskove sam platio 4800din u Ricambiu u Ugrinovackoj u Zemunu Quote Share this post Link to post Share on other sites
cane 205 Posted November 24, 2013 moze da steti ako budes radiio kod nekih kvazi tjunera. Sa firmama koje su na dobrom glasu nemas razloga za brigu. Ali pre toga isproveravaj sve lepo.. pvp, dizne, turbo, creva, kvacilo.. uostalom imas na forumu o tome na 100 strana Sent from my SmartTabII10 using Tapatalk Quote Share this post Link to post Share on other sites
nemke 92 Posted November 24, 2013 koji je dobar tjuner? nasao mi drugar nekog lika sto chipuje za 30e i ima neki u zemunu za 50e ... Quote Share this post Link to post Share on other sites
cane 205 Posted November 24, 2013 E to su kvazi tjuneri To sto oni rade uz malo truda mozes i sam.. ali ovo je tema za predstavljanje tvog auta, a o ovome pisi u temi za chiptuning, da nepravimo svastaru od ove teme.. P.S. pozdrav za nesu Sent from my GT-I9300 using Tapatalk Quote Share this post Link to post Share on other sites
Владимир 15 Posted November 25, 2013 Vidi na NStuning centar, tu na sajtu pronadji blow off ventile i imas cene. Quote Share this post Link to post Share on other sites
nemke 92 Posted November 25, 2013 hvala vlado. Quote Share this post Link to post Share on other sites
nemke 92 Posted December 1, 2013 Drugari pomagajte treba mi hitno jedna michelin alpin3 185/60/14 pa ako neko ima ili zna gde ima neka javi. hvala puno Quote Share this post Link to post Share on other sites
cane 205 Posted December 1, 2013 cuo sam za nekog lika u Sremcici kazu da ima najvecu ponudu polovnih guma u Srbiji, ako sam dobro razumeo nalazi se ne poslednjoj stanici 511-ice, ali nemam nikakav kontakt, probaj da izguglas broj pa proverievo nasao ovo, moguce da je to taj http://www.gumeifelne.com/gume/kontakt.html Quote Share this post Link to post Share on other sites
nemke 92 Posted December 1, 2013 hvala cane... imam neke gume postavio sam oglase.. pa ako nekog zanima nek se javi.. povoljno ih dajem jer bi uzeo najradije ovu miselin novu.. ili bi menjao... dajel 6 zimskih guma za jednu Quote Share this post Link to post Share on other sites
nemke 92 Posted December 15, 2013 (edited) cao drugari nije me bilo par dana.. ali ima novina punto je registrovan (tablice imaju moje inicijale ) i vozi se svaki dan... kupljene dve nove michelin alpin3 185/60/14 e sad malo me buni potrosnja... na 100km (voznje kao baba do 2000ob i jedno cepanje po autoputu do 180km/h) potrosio mi je 10l dizela... mereno je tako sto sam ga sipao do cepa i opet sam ga cepirao.... a na bordu mi je pisalo od 4-5km/l inace posle par dana pokazuje mi na kompu od 13,5 do 14.5km/l sto mu negde dodje oko 7l ? da li je to normalna potrosnja (gradska)?? i jedan iritantan detalj iz mojih kola... Edited December 15, 2013 by nemke Quote Share this post Link to post Share on other sites
DinoG 7 Posted December 15, 2013 S obzirom da su jako niske temperature i ako ga voziš na kratke relacije gdje se motor ni ne zagrije onda je potrošnja opravdana. Zimi može skočiti potrošnja i po litru i po u odnosu na onu od ljeti Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted December 15, 2013 Prelep puntic,i ja od skoro posedujem slican,vidim da imas problema sa muzikom,to je i kod mene bio slucaj pa je prethodni vlasnik to pocupao i ubacio obican fabricki Blaupunktov cd player.Inace moze da se sredi taj displej ali ne znam koliko ti se to isplati.Meni potrosnja u gradu seta od 12km/l do 14km/l a na otvorenom kad se zagrejao drzi 20-22km/l. Quote Share this post Link to post Share on other sites
nemke 92 Posted December 19, 2013 cd plejer cu najverovatnije menjati...i izvadicu cd ch i stavicu fiokicu fabricku... Quote Share this post Link to post Share on other sites
