dizelash 0 Posted April 21, 2010 Da li neko zna koja je maksimalna dubina zadnih zvucnika(13cm)u grande puntu?Za prednje sam nasao neke informacije ali za zadnje nista. Za prednje sam planirao ove http://caraudiosecurity.com/shop/product/products_id/6694.html a za zadnje http://caraudiosecurity.com/shop/product/products_id/12102.html. Prednji pasu sigurno ali su zadnji malo problematicini.Ako neko ima neki pametniji predlog u vezi zamene fabrickih zvucnika u grande puntu nek kaze...p.s. Elipse na zadnjoj polici i wooferi ne dolaze u obzir... Quote Share this post Link to post Share on other sites
Mans 1 Posted April 21, 2010 Odlican izbor zvucnika,medjutim njima je impedanca na 2 ohms,a i snaga im je prilicno velika stoga je pojacalo za tu varijantu MUST HAVE opcija.Za pozadi ti je naj merodavnije da skines fabriku i premeris,subler,metar,lenjir... Quote Share this post Link to post Share on other sites
dizelash 0 Posted April 22, 2010 ^^^ Jel moze ovo: Magnat / PHANTOM 4000 Amplifier 4-channel modes • 4 / 2 Channels • 4 Ohm Power RMS / MAX 4x65/130W or 2x190/400W • Power 2 Ohm RMS 4x95/200W • Stable at 2 Ohm • Frequency Response 5Hz-50kHz • 0.05% THD (1KHz) • The ratio of noise / signal> 100dB • Input Sensitivity (RCA) 250mV-4V RCA inputs • Resistance • 20k ohm high pass filter 50-500Hz low pass filter • 30-500Hz • Bass Boost (raise bass) 0-12dB/45Hz • subsoniczny Filter 10-60Hz (12dB/oct CH 3 / 4) • Dimensions / S, H, L / 342x60x245m Quote Share this post Link to post Share on other sites
Mans 1 Posted April 22, 2010 Nije najlepse,ali svakako vrsi posao... E sad to sto nije moj omiljeni brend,tj ni u prvih 10 nema veze,bitno je da radi Quote Share this post Link to post Share on other sites
Mateo 1 Posted May 25, 2011 (edited) Razmisaljo sam da zamenim zvucnike u prednjim vratima nekim boljim after market.Moje pitanje glasi ,sa kojim zvucnicima bih dobio bolji kvalitet zvuka u odnosu na fabricko ozvucenje...trenutno se u prednjim vratima nalaze 2 visokotonca od 30 w ,i 2 srednjotonca od 40 w 160 mmFinansije su limitirane na 80 evra Edited May 25, 2011 by Mateo Quote Share this post Link to post Share on other sites
genca 2 Posted May 25, 2011 Ja tu ne bi nis dirao! Quote Share this post Link to post Share on other sites
podvarak 1 Posted May 25, 2011 Ako ne planiras zamenu plejera i ubacivanje pojacala, onda idi na sisteme sa sto vecom osetljivoscu, da bi fabricki plejer mogao da ih pomeri uopste. Moja preporuka je Hertz DSK 165 (~7k din). Odlicno sviraju na maloj snazi a mogu komotno i na pojacalo ako se predomislis kasnije. Ako si u mogucnosti, ubaci prsten od medijapana izmedju njih i vrata. Mnogo lepse zvuce kad su usrafljeni u medijapan nego u plastiku/metal, pogotovo nizi tonovi. Quote Share this post Link to post Share on other sites
Mateo 1 Posted May 25, 2011 (edited) Podvarak super sto si se ti javio hteo sam bas malo oko te muzike da te pitam na rostilju al zaboravih...kako kod...pleyer bi ostavio ovaj fabricki medjutim prva stvar koja me buni je ta da u specifikacijama pise da on podrzava 4 x 30 wati a dva reda dalje pise da su srednjotonci od 40w...zapravo cilj mi je da zvuk dobije na kvalitetu...da li treba da menjam i ove visokotonce kad menjam glavne ili njih mogu ostaviti to me isto zanima....http://www.fiatforum.com/grande-punto-guides/113959-changing-front-speakers-walkthrough-pics.html Edited May 25, 2011 by Mateo Quote Share this post Link to post Share on other sites
Mans 1 Posted May 26, 2011 Bilo koji aftermarket zvucnik da stavis bice greota terati ga sa fabrickog playera...aftermarket playeri cesto umeju da se vode kao 4x50w sto je zapravo 4x 22,5-23w A bilo koji aftermarket je natno jaci od fabrike.Pravi kvalitet se postize sitnim koracima izolacije bas kao sto je podvarak napisao,ali tih kvalitet i nije neki kvalitet...Zvucnik koji ti je Podvarak preporucio je skorz na mestu,samo tako nesto nakaciti na pojacalo... i eto razloga da nigde ne ides peske Quote Share this post Link to post Share on other sites
krsman 0 Posted May 28, 2011 Pozdrav ljudi, prvo da vas sve pozdravim, ovo je moj prvi post na ovom forumu iako ga citam neko vreme. Ovde sam pronasao dosta korisnih informacija dok sam bio u fazi kupovine auta, a kako sam od juce i vlasnik Grande Punta 1.9 multijet emotion, imam razlog vise da vam se prikljucim. Jasno mi je da niko ne voli ponavljanje tema, tako da se nadam da se ne ponavljam, iscitao sam vecinu topic-a vezanih za grande punto u ovoj sekciji ali nisam pronasao ono sto me interesuje.Da predjem na stvar. Posto mi se dopada kako izgleda konzola sa fabrickim playerom, pokusavam da izbegnem vadjenje istog i da stavljam neki od aftermarket playera, takodje sam zadovoljan jacinom zvuka ostalih zvucnika u autu, stim sto bih voleo da dodam jos basa. Posto kapiram da fabricki cd fm player nije dovljno jak da gura neke lude zvucnike, zanima me sta bih ja mogao da dodam na stock system, tj sta mi vi preporucujete.Nije mi potrebno ispadanje zuba, vec samo malo kvalitetniji bas. Ili eventualno ako predlazete ugradnju nekog pojacala na stock player ako je to uopste moguce.Hvala i puno pozdrava. Quote Share this post Link to post Share on other sites
Mateo 1 Posted April 8, 2012 (edited) Drustvo treba mi pomoc.zamenio bih fabricke zvucnike nekim boljim...e sad fabricki su dosta dobri al zelim da to bude onako jos malo bolje ne bih ubacivao vufer i pojacalo nego bi samo zamenio prednje 16-ice i visokotonce....ako bi neko mogao da mi kaze sta da jurim od proizvodjaca i jos bolje neki konktetan model....drugar je imao novom bravu JBL i mnogo su se dobro culi...kakv je magnat po vama...??Ps dal cu moci na fabricki cd da nakcim tako neke malo jace zvucnike uopste ??Budzet 100 evra + - 10 Edited April 8, 2012 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
Manfred 0 Posted April 8, 2012 Cuvaj tih 100 evra, poskupljuje gorivo opet Quote Share this post Link to post Share on other sites
NesBG 0 Posted September 3, 2012 (edited) Kolege forumaši,da li neko zna kako da zamenim zvučnike u prednjim vratima Grande Punta, posto ne bih hteo da eksperimentišem pa da oštetim tapacirung. Edited September 3, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Zvezdo 549 Posted September 3, 2012 (edited) Pozzz! Evo ovde je sve objasnjeno u slikama.http://fiatisti.hr/f...1.msg518124#newE da cini mi se da su "vide"??!!!?? vijci i da ödvidati valjda znaci odvrnuti! Pitao sam Slavonce za te nove najnovije reci - izraze i nemaju pojma- nisu culi! Edited September 3, 2012 by Zvezdo Quote Share this post Link to post Share on other sites
Dr. Tuborg 35 Posted September 3, 2012 Vide su srafovi a kacavida je srafciger. Tako je bar po Dubrovackom slengu. Quote Share this post Link to post Share on other sites
NesBG 0 Posted September 10, 2012 Ovog vikenda sam skinuo tapacirunge i iznenadio sam se oblikom zvucnika jel su na popnitne i rupe za kacenje su vece od rupa na kupljenom zvučnicima.Ako neko ima neko rešenje vrlo je dobrodoslo. Quote Share this post Link to post Share on other sites
NesBG 0 Posted May 23, 2013 Drugari i kolege forumaši potrebna mi je vasa pomoc. U svog grande punta sam umesto fabričkih zvučnika u vratima ugradio aftermarket zvučnike. Ugradio sam ih tako sto sam i zalepio na postojeće plastične adaptere u vratima. Znaci vise se nedrze na popnitnama. Problem je u tome sto se oni stalno odlepljuju i gube kontakt. Da li je neko ugredjivao zvučnike na popnitne i da li neko ima neki predlog koje zvučnike bih mogao da kupim i kako kvalitetno da ih postavim na vrata. Hvala vam. Quote Share this post Link to post Share on other sites
igorikus 0 Posted January 29, 2014 (edited) Pozdrav svima. Treba mi pomoc. Konkretno,na GP levi zvucnik mi ne radi napred dok ostali rade. Skinuo sam tapacirung i zamenio zvucnike sa leve na desnu stranu kako bi video da li su zvucnici otisli i rade na drugoj strani,a na levim vratima nece. Desava mi se i da na desnoj strani ponekad se cuje mutan zvuk kao kroz vodu pa se posle kratkog vremena ponovo izostri sam od sebe. Zna li neko sta bi to moglo da bude ili nekog majstora ko bi mogao da otkloni kvar Mozda je otisao levi kanal na cd-u. Inace fabricka je muzika u kolima. Ne znam- Iskreno slabo se razumem u to. Hvala unapred. Pozdrav svima- Edited January 30, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Mijailović P. 1271 Posted January 30, 2014 Vlaga i konektori vrata do stubova prave problem. Treba to lepo pretresti i naprskati kontakt sprejem, za pocetak. Quote Share this post Link to post Share on other sites
igorikus 0 Posted January 30, 2014 Hvala puno na savetu. Probacu to prvo pa cu videti kako ce onda biti. Quote Share this post Link to post Share on other sites
Inco Gnito 1 Posted May 18, 2015 (edited) Pošto mi je namera da ubacujem neke ozbiljnije zvučnike, interesujeme da li neko zna koji "prečnik" zvučnika ide za prednja a koji za zadnja vrata?Da ne skidam plastičnu zaštitu, možda neko već zna. Hvala Edited May 20, 2015 by neshaoct spojeno Quote Share this post Link to post Share on other sites
shajabusa 0 Posted June 12, 2015 (edited) Produvao je zvucnik u zadnjim vratima na grande puntu. Kad sam skinuo tapacirung vidim da zvucnik nije na srafove nego je zanitovan za vrata.Da li ima iko iskustva sa zamenom istih? Edited June 15, 2015 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Skorpion 19 Posted June 12, 2015 Ja menjao prednji tako sto isekao zvucnik a na vrati ostala plastika koja je pricvrstena. Novi stavis u ta plaatika i prcvrstis strafom. Quote Share this post Link to post Share on other sites
Zvezdo 549 Posted June 12, 2015 Razbusis nitnu busilicom zamenis sta trebas i nanovo zanitujes. U nedostatku klesta i pop nitni moze i vijak sa maticom koju bi mozda bilo pametno osigurati od odvrtanja. Quote Share this post Link to post Share on other sites
boba89 0 Posted February 6, 2016 Pozdrav svimaMoze mi neko pomoci kako se skidaju zvucnici kod zadnje klupe? da limora ceo tapacirumg da se skida ili moze samo mrezica oko zvucnika? Quote Share this post Link to post Share on other sites
