Ivica85 0 Posted December 25, 2014 Ljudi resen problem.Auto celu noc stajao sa skinutom klemom da ne bi ispraznio akumulator i jutros kad sam je vratio sve radi normalno???Ipak prosetao do elektricara kaze covek da se najverovatnije resetovao bsi ali posto radi ne diramo nista za sada,videcemo koliko ce da potraje.Hvala svima na trudu ... Quote Share this post Link to post Share on other sites
Dovla 9 Posted December 25, 2014 BSI?! Javiće se to ponovo sigurno. Možda je klema bila problem, ako ih nisi očistio uradi to. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 25, 2014 Bas tako bravo nema bsi(body). Quote Share this post Link to post Share on other sites
Dovla 9 Posted December 25, 2014 Čak i da ima... šta se to tačno resetuje na BSI kada se skine napajanje?! Quote Share this post Link to post Share on other sites
Dovla 9 Posted December 25, 2014 Pa da... zato mu je i zapeo migavac... zabo sat i ne može da broji miganje već samo svetli... Eto! Rešena misterija! 1 IgorBG reacted to this Quote Share this post Link to post Share on other sites
Ivica85 0 Posted December 25, 2014 Ha i ja se raspravljao sa elektricarem da nema bsi ali on uporno tvrdi da ga ima pa ja popustio mozda nisam dobro zagledao a problem se javio posle 4 sata cim sam otkljucao auto preko daljinca ponovo ostao migavac da svetli,medjutim kad sam ga ponovo zakljucao i otkljucao iskljucio se.Ja ubedjen da je do alarma ali videcu ovih dana da ga rasturim. Quote Share this post Link to post Share on other sites
Nbg 0 Posted August 20, 2016 (edited) Zdravo svima, U pitanju je fiat brava 2002 god. Migavci mi rade samo kad su ukljucena sva cetiri svetla, a ona ne rade. Dakle ne rade sva cetiri. U cemu bi mogao biti problem? Edited August 23, 2016 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted August 20, 2016 Relej tj automat za sva4 zmigavca. Quote Share this post Link to post Share on other sites
pivopija 2 Posted March 24, 2017 (edited) Sto se migavaca tice... imao sam problem... ponekad rade a ponekad ne... Relej migavaca nalazi se ispod volana kad se skine zastitna plastika i odviju ona tri srafa. Menjao sam ga danas... Jako prosto i jednostavno i nema vise sta da me nervira. Da sam znao koliko je jednostavno pre bih ga zamenio Fiat bravo 1.6 16v 76kw Edited March 24, 2017 by pivopija Quote Share this post Link to post Share on other sites
pivopija 2 Posted August 15, 2017 I jos da napomenem, za model bravo 1.6 16v pasuje automat za zmigavce od zastave 101 Samo on je crne boje a fabricki automat od fiata je plave boje. Kosta 500 dinara i pasuje kao fabricki. radi odlicno. Da znate ukoliko budete imali problem sa pronalazenjem automata za fiat bravo kao sto sam ja imao Quote Share this post Link to post Share on other sites
spaske 1 Posted November 14, 2017 kod mene migavci uglavnom rade normalno ali mi se čini da dok je bilo toplije kada se motor zagreje ponekad neće da rade, pa ponovo dam migavac proradi sada na hlanijem vremenu nisam primetio problem, dali je normalno da kada uključim sva 4 migavca a auto ugašen rade normalno 1-2 minuta a onda se ugase? Marea karavan 1.6 16v 1997 god. Quote Share this post Link to post Share on other sites
pivopija 2 Posted December 12, 2017 Imao sam Isti PRoblem. Zameni automat. Napisao sam gde se nalazi. Resices sve probleme. 500 dinara je mala cifra a resava te velikih muka Quote Share this post Link to post Share on other sites
spaske 1 Posted December 12, 2017 Hvala na pomoći to sam i planirao prvo da odradim jer je najjeftinija varijanta, hvala još jednom. Quote Share this post Link to post Share on other sites
darkman14 5901 Posted June 18, 2018 Ajd da se upisem i ovde. Za vikend sam primetio da mi se ne gase migavci kad ih ukljucim, vec konstantno svetle. I uglavnom se tako nesto desava subotom popodne kad nigde nista ne radi od prodavnica. U nedelju skinuo oblogu volana, malo kucnuo relej te je proradilo. Svakako cu kupiti relej eventualno ovih dana a ako nekome treba, neka bude I ovde kataloski broj dela 7573490 Quote Share this post Link to post Share on other sites
Martin 799 Posted June 18, 2018 Ih kad sam ja to rešio...još pre skoro deset godina. Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 14, 2019 (edited) Desna strana migavaca pod pozicijom ili upaljenim svetlima nekad radi nekad ne a kad radi zadnji migavac ne radi vec blinka pozicija i stop naizmenicno(realno extra izgleda uzivo) kad ugasim pozijiju/svetla sve radi kako treba. sva 4 isti slucaj sa tim naizmenicnim blinkanjem stop/pozicija) ugasena sve normalno. Zna li neko u cemu je problem? Edited February 18, 2019 by neshaoct spojeno Quote Share this post Link to post Share on other sites
sasadoncic02 24 Posted February 14, 2019 Proveri džekove na stop svetlima,možda zaprljani kontakti ili masa na signalizaciji nije dobra 1 Trofeo reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted February 14, 2019 Masa ne valja ili u samom dzeku ili negde drugde 1 Trofeo reacted to this Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 14, 2019 (edited) aj sutra cu bas da proverim. Da napomenem nekad se desava da cela ta desna strana prednji,bocni,zadnji sija zuto non stop migavac onako priguseno znaci upalim auto i upalim poziciju/svetla sijam kao bozicna jelka cela ta desna strana svetle migavci(kao pozicije bez blinkanja) priguseno. Edited February 14, 2019 by Trofeo Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted February 14, 2019 tako znas na kojoj strani da pocnes pretragu Quote Share this post Link to post Share on other sites
Trofeo 115 Posted February 18, 2019 Proverio zadnji stop,sve na svom mestu stoji sve u najboljem redu.Mora se oterati kod majstora da se vidi sta je problem. Quote Share this post Link to post Share on other sites
