SrdjanNS 0 Posted July 5, 2013 Jesi ovo pronasao na net-u ili kupio Jel Stilo ima propremu za ovo ili mora da se prikljucuje iz pocetka? Quote Share this post Link to post Share on other sites
nine84 1 Posted July 8, 2013 ja upravo narucio taj grejac, pa cu da vidim kad stigne kako cu da ugradim Quote Share this post Link to post Share on other sites
Ivan 17683 Posted July 8, 2013 Jesi ovo pronasao na net-u ili kupio Ma oglas na netu (PA), postavio sam link u "Neko negde nesto prodaje".Nego caskali smo oko ovoga jos negde, koliko se secam imenjak je kacio neke slicice vezano za instalaciju.Ne sumnjam da ce postaviti link ako vidi ovo , a probajte i sa Search. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted July 8, 2013 Najlakše za proveru, da se skine bočni panel (15 sec posao) i da se vidi da li ima uopšte grejač. Položaj i izgled grejača na vozilima koja ga imajuAko ga nema ovako izgleda, strelica pokazuje gde treba da budeOpis i funkcija dodatnog el. grejača. FIAT STILO RESISTENZA VENTOLA MAGNETI MARELLI A.521.002.00MAGNETI MARELLI A.521.002.0077363257 Fiat OEM brojADDITIONAL PTC HEATER (1.9 JTD)The additional PTC heater, available as an optional extra on the JTD versions,is designed to heat the passenger compartment more quickly wih the engine running (rpm > 700 rpm)in the case of adverse weather conditions (for example, particularly cold climate).It is a resistance located near the radiant mass with a maximum power of 700W and a voltage of 13.5VThe PTC additional heater control algorhythm manages the enablement checking whether the following conditionsexist simultaneously and persists for 3 seconds:Outside temperature < 20° C (winter temperature)Key onClimate control unit in position other than OFFEngine rpm > 7000 rpmEngine coolant temperature < 64 °CAir flow rate > 0Battery voltage > 12.2 VTreated air temperature Vent 50 °CWaiting for a period of 3 secondsWith the procedure in progress, it is aborted (until the next key-off/key-on) for any of the following conditions:RPM < 700 RPMEngine coolant temperature > 64 °Cwhilst the action is only suspended (and resumed when the condition that caused it to be suspended ceases):if the user manually selects a nil flow ratemanually selects the OFF button at the control unitVent Treated temperature > 50 °CThe outside temperature is no longer detected after this process.The logic involves activating/deactivating the relays according to the temperature of the water according to te P.T.C.thermal balance.PTC THERMAL BALANCEThe PTC control should also take into account the supply voltage (measured at the control unit terminals)to establish the enabling percentage depending on to the electrical balance of the vehicle according to the tablefor the first 120 seconds of the check.ELECTRICAL BALANCEThe P.T.C. is deactivated when the air flow rate is zero.If the P.T.C. heater is fitted on the vehicle the Vezano za el. grejač u Stilu. Koliko sam provalio imaju ih modeli (bila doplata) samo sa automatskom klimom i snage su 2x 100 W, čak ima i tema ovde na forumu http://www.fiat-lanc...pic=45396&st=40Ko hoće da dodatno ugradi može da kupi http://www.ebay.it/i...4#ht_874wt_1159http://www.ebay.de/i...=item53ed0920d5http://www.ebay.de/itm/Fiat-Stilo-192-1-9-JTD-Heizung-Zusatzheizung-Kuehler-/160640433692?clk_rvr_id=438524883314 Quote Share this post Link to post Share on other sites
nine84 1 Posted November 26, 2013 Ja nabavio grejac odavno, kako da proverim dal moj stilo ima pripremljenu instalaciju za grejac? Gde bi trebao da bude konektor gde se ukljucuje kabal od grejaca? Jel neko ugradjivao grejac u stilo? Quote Share this post Link to post Share on other sites
underground79 19 Posted November 27, 2013 Ja sam danas porucio grejac.. Javljam utiske cim montiram Koliko sam cuo sistem je plug and play Quote Share this post Link to post Share on other sites
igor0511 2882 Posted November 27, 2013 Ako budeš zadovoljan mislim da ću ti se uskoro pridružiti Stvarno je mučenje voziti zimi jtd koji prenoći van garaže Quote Share this post Link to post Share on other sites
bglion 401 Posted November 27, 2013 Trebaobratiti paznju i na jacinu alternatora jer je grejac veci potrosac. 600-700w Kod Lybre za ovaj grejac bi trebao da bude od 120A a standard za Lybru sa klimom( mada ne znam da Lybra nema klimu) je 100 ili 120A. Ja mozda danas probam da odradim ako ne onda za vikend. Quote Share this post Link to post Share on other sites
Sale2810 4 Posted November 27, 2013 Gde si nasao grejac i koliko je para ako nije tajna? I znas li proceduru ugradnje? Quote Share this post Link to post Share on other sites
underground79 19 Posted November 27, 2013 Nasao sam preko oglasa kod nekog lika iz Kraljeva. Ima servis i prodaje delove, uvozi kola.. Cena 25€ plus ptt. Sto se tice ugradnje, mislim da je prosta. Tj samo se mune.. Videcemo jos Quote Share this post Link to post Share on other sites
nine84 1 Posted November 27, 2013 Ja proverio danas alternator, kod mene je od 120A...javljajte utiske kako je prosla ugradnja Quote Share this post Link to post Share on other sites
Sale2810 4 Posted November 27, 2013 Nasao sam preko oglasa kod nekog lika iz Kraljeva. Ima servis i prodaje delove, uvozi kola.. Cena 25€ plus ptt. Sto se tice ugradnje, mislim da je prosta. Tj samo se mune.. Videcemo josPa odlicno je to...javi samo kako ide ugradnja. Quote Share this post Link to post Share on other sites
dejica 21 Posted November 27, 2013 ja to cudo imam u mom stilu prakticno greje odmah cim startujem motor Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted November 27, 2013 Jel bas za stilo ili je neki univerzalni model? Quote Share this post Link to post Share on other sites
Aleksandar_Nikolic 0 Posted November 27, 2013 (edited) . Edited November 27, 2013 by Aleksandar_Nikolic Quote Share this post Link to post Share on other sites
nine84 1 Posted November 27, 2013 pa ovo sto sam ja kupio je originalni deo za stilo, ima i mesto fabricki predvidjeno gde se postavlja, e sad na nekim modelima je bio fabricki ugradjen, mali broj srecnika ima ovaj grejac Quote Share this post Link to post Share on other sites
bglion 401 Posted November 27, 2013 Ja probao danas ali fali instalacija Quote Share this post Link to post Share on other sites
dejica 21 Posted November 27, 2013 a kod mene sve ima i radi znaci ja sam jedan od srecnika Quote Share this post Link to post Share on other sites
Sale2810 4 Posted November 27, 2013 A jel komplikovano izvuci instalaciju? I moze li se ugraditi bez skidanja table? Quote Share this post Link to post Share on other sites
dejica 21 Posted November 27, 2013 ja mislim da za ugradnju tog grejaca se skida samo plastika sa suvozaceve strane to je plastika koja se skida kada se menja filter klime e ako nemate instalaciju za grejac sto je verovatno jer ga nemate fabricki ko ja u mom stilu onda ce morati neki iskusni auto elektricar da vam izvede instalaciju za grejac to nije problem nego je problem kada izvedete instalaciju kada ce se aktivirati grejac jer drugacije je to fabricki izvedeno . Quote Share this post Link to post Share on other sites
nine84 1 Posted November 27, 2013 koliko sam ja shvatio, veliki broj stila ima vec predpripremu za ovaj grejac, jedino moze da hvali neki relej ili osigurac, i po onome sto sam procitao samo stila koji imaju digitalnu klimu imaju ovu instalaciju...da bi se ugradio grejac nije dovoljno skinuti samo tu plastiku , ima tu malo vise zezanja koliko sam mogao da provalim, ali sve to je nista ukoliko postoji instalacija, ukoliko ne mislim da nije vredno cimanje pustati novu instalaciju Quote Share this post Link to post Share on other sites
bglion 401 Posted November 27, 2013 Ajde malo cu pokusati da pomognem posto sammalo usao u tematiku oko Lybre a vidim po semi da je to manje vise isto. Samo automatska klima moze kontrolisati ovaj sistem jer uzima vise podataka da bi ga aktivirala.Broj obrtaja , napon baterije, temperaturu spoljnu i rashladne tecnosti. Kod mene je slucaj (lybra je u pitanju) da imam napajanje izvedeno do instrument table , sto je dobro. Potrebno mi je:"dovuci dve zice sa automatske klime do releja (2 kom) koji pale 1 ili sva tri grejaca (ovaj grejac fizicki ima 3 kom u sebi)i spojiti releje na grejac. Losa stvar, kod mene, je pozcija grejaca jer preko nje ide metalna greda koja drzi instrument tablu a nemoguce je uvuci pored grejac od tog metalnog nosaca. Ja paniram u subotu odlazak do otpada sa secicama naravno Quote Share this post Link to post Share on other sites
bglion 401 Posted November 27, 2013 Mali edit: po ovoj semi na prvoj strani ima razlike izmedju Lybre i Stila i to velike. Stilo izgleda da ima posebnu centralnu jedinicu za ovaj grejac tj. M75 e sad po slici je skroz odvojena a mozda je i deo centralne jedinice automatske klime.Moze dejica da proveri pa da pomogne Sad je jasno kako je dejica ima malu potrosnju -uvek je auto zagrejan Quote Share this post Link to post Share on other sites
dejica 21 Posted November 27, 2013 ja nemam digitalnu klimu ali imam taj grejac i video sam to cudo prvi put kada sam manjao filter klime ali od pocetka mi je bilo cudno cim upalim auto i pustim ventilator odma greje e sad koliko sam ja primetio taj grejac radi samo kada okrenem tockic na skroz crveno znaci do kraja . Aktivira se cim startuje motor a gasi se sam cim se zagreje malo" motor jer neverujem da taj grejac radi uvek mislim non stop dok radi auto e sad taj sistem nisam nikad cackao i necu ga ni cackam dok mi radi radio je kad se bude taj grejac pokvario necu ga ni menjam jer sam primetio da povuce zrelo struju cim se aktivira a u principu tih desetak minuta necu da izmrznem dok se zagreje auto mozda cak izvadim i prodam taj grejac. Quote Share this post Link to post Share on other sites
