amladenbk 1 Posted December 28, 2014 mislim da je najsigurnije menjati na svake dve godine bez obzir sta ti " meraci" pokazivali .... Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 29, 2014 Meni je još prvi antifriz i prosle godine je izmereno -29 ... i moracu da ponovim merenje jer najavljuju za novu godinu minus beskonacno... tj od sutra već... Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 Izmereno -15... majstor predlozio da dospem do vrha sto je oko 200ml... ne znam da li ce mi to biti ok ? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted December 30, 2014 Ako već nećeš menjati, ispusti litar i naspi litar novog Paraflu-a ako ti je uopšte on u sistemu. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 Znaci 200ml mi nista ne znaci? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted December 30, 2014 Mislim da ne. Možda dobiješ -17maxSvakako moraš litar kupiti pa nema razloga da ga ne saspeš celog u sistem. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 OK ... a kazi mi da li bi bilo pametno da crevom izvucem iz hladnjaka 1l tecnosti i sipam 1l antiftiza... da ne ispustam odozdo? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted December 30, 2014 (edited) Slobodno. Svakako ti je lakše tako po ovom mrazu nego da se zavlačiš pod auto Edited December 30, 2014 by Markobgd Quote Share this post Link to post Share on other sites
igor0511 2882 Posted December 30, 2014 Odeš u apoteku i uzmeš onaj najveći špric. Ja sam sa njim bez problema izvukao 1l antifriza. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 E pa kod punta ti treba malo veci... Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 Zamenio sam 750ml... toliko mi ostalo u pakovanju ... da li je to dosta ? ... inace g12 ima slatkast ukus ako nekog zanima... Quote Share this post Link to post Share on other sites
MS PK 7734 Posted December 30, 2014 Pa dal je dosta proveris merenjem Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 Sad sam vozio i zbacio mi puno rashladne tecnosti kod cepa... u cemi je fora? Quote Share this post Link to post Share on other sites
paun ts 1 Posted December 30, 2014 Da nisi prepunio bocu? Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 Koliko je bilo toliko sam sipao mozda za prst vise... Quote Share this post Link to post Share on other sites
paun ts 1 Posted December 30, 2014 Po nekom previlu izmedju MIN i MAX bi trebalo da bude onda ce sve da bude ok. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 Ma ja sam ...ako si citao ... vadio iz hladnjaka ... tecnost i toliko moza malo vise za prst dosipao antifriza i malo pre odvozio jedno 10tak km auto je dostigao radnu temp i izbacio tecnost na cepu... Bilo je izmedju min i max... Quote Share this post Link to post Share on other sites
MS PK 7734 Posted December 30, 2014 Izbacio ako si ga vruceg otvarao....i sto si ga pa otvarao Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted December 30, 2014 Bice sutra merenja opet pa... nego ovde je vec -15.. valjda sam mu bar malo spustip temp... Quote Share this post Link to post Share on other sites
MS PK 7734 Posted December 30, 2014 Jesi prilicno ako je promesao kroz ceo sistem Quote Share this post Link to post Share on other sites
majstormica 25 Posted December 30, 2014 (edited) Koji antifriz ide u Fiat Punto 2 1.2 8v 2001 godiste? Kod mene na nalepnici sa unutrasnje strane haube pise Paraflu 11, sto mu dodje onaj plavi. Ja sam ipak sipao G12. Srpska posla Malo me buni ovaj mjerač. Je l' ovo dobar nivo za mjerenje? Jel si merio dok je auto bio hladan? Kad je vruc onda pokazuje vise. Edited December 30, 2014 by majstormica Quote Share this post Link to post Share on other sites
Nidzo 2 Posted December 30, 2014 Bio je ugrijan. Quote Share this post Link to post Share on other sites
majstormica 25 Posted December 31, 2014 Po pravilu se meri kad je hladan. Quote Share this post Link to post Share on other sites
Axic 20048 Posted December 31, 2014 Kod mene na nalepnici sa unutrasnje strane haube pise Paraflu 11, sto mu dodje onaj plavi. Ja sam ipak sipao G12. Srpska posla Nisi jedini da znas. Quote Share this post Link to post Share on other sites
amladenbk 1 Posted January 3, 2015 ako ti izbacuje tecnost na cepu onda si napravio vazdusni cep tj previse antifriza si izvukao iz posude pa kad si dolio iz flase nabio si vazdusni cep u sistem ... prati temperaturu ako se ponovi nemoj samo dolivati vec probaj da odzracis sistem ( ako umes i znas ) da ti se ne pregreje i ne zajebe dihtung i glavu .... hoce to i na minus 30 da se desi nemoj mnogo da se oslanjas na spoljnu temperaturu ... motor proizvodi visoku temperaturu bez obzira kolika je spoljna .. opasno je to i zimi i leti ... meni je punto to uradio prve zime (2012) ali sam primetio na vreme, dodao tecnost, odzracio sistem ( kada je motor zagrejan na radnu temperaturu) i od tada sa tecnoscu nemam problem .... ne gubi uopste a kontrolisem nivo jednom nedeljno ....sada kad prodje ovaj minus tj danas cu prvo to da proverim koliki je nivo .... Quote Share this post Link to post Share on other sites
