Dimitrijus 3 Posted September 1, 2016 Rešio problem... našao mešavinu od prošle godine... evo koliko ide od min do max.. Quote Share this post Link to post Share on other sites
MS PK 7729 Posted September 1, 2016 Bez konzervansa i bez boja Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted September 1, 2016 Bez dodatka šećera... paraflu .. Quote Share this post Link to post Share on other sites
dare.ivkovski 0 Posted November 10, 2016 (edited) Dali ako sipem 100% antifriz zbog gubenje na isti mozem da napravim problem? Sipao sam sve na sve 1l 100% antifriz na vec postoeci samo sam dosipavao zbog gubenje. Jel ima neki problem? Sent from my SM-A500FU using Tapatalk Edited November 10, 2016 by Ivan Prebaceno Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2016 Ako se vec bavis na dospivanjate, onda dosipaj 40%...kako mozes da znas, ukoliko sipas cist 100% koliko treba vode i kakvu si onda kombinaciju napravio unutra? Quote Share this post Link to post Share on other sites
Ivan 17591 Posted November 10, 2016 Za Paraflu se npr. propisuje mesanje antifriza i destilovane vode u odnosu 50:50. Nadam se da nisi mesao vrste antifriza kod dolivanja (obicno ide crveni G12). @dare.ivkovski Pitanje je prebaceno u postojecu, odgovarajucu temu. Zamolio bih za koriscenje pretrage foruma, pre otvaranja nove teme. Quote Share this post Link to post Share on other sites
punto75 0 Posted December 3, 2016 (edited) Pozdrav svima,hocu da znam koji antifriz ide kod punta mk1 1.2 54kw i blok motora dal je alumijski ili drugi i koji ,hladnjak je alumijski i koji antifriz se koristi g11 zeleno ili g12 paraflu up crveni? Edited December 6, 2016 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Home 56 Posted December 3, 2016 Za aluminijum G12 Paraflu...oko 5 evra litar Quote Share this post Link to post Share on other sites
Memphis 15 Posted December 4, 2016 Original ti ide Paraflu G11 plavi Quote Share this post Link to post Share on other sites
Juba 0 Posted December 4, 2016 g11 ako nemas klimu Quote Share this post Link to post Share on other sites
punto75 0 Posted December 4, 2016 ima klimu i sipao g11 zeleni od fibe bilesten dal je dobar Quote Share this post Link to post Share on other sites
Axic 19980 Posted December 4, 2016 Bilo koji G11, ne moras da stavis iskljucivo fabricki preporucen Paraflu. Vozi, uzivaj i ne brini. Quote Share this post Link to post Share on other sites
Memphis 15 Posted December 4, 2016 On 12/4/2016 at 3:29 PM, punto75 said: ima klimu i sipao g11 zeleni od fibe bilesten dal je dobar Nema veze jel ima klimu ili ne ... i da li je plavi ili zeleni. Bitno je da zadovoljava G11 normu. Quote Share this post Link to post Share on other sites
Juba 0 Posted December 5, 2016 jesi li siguran u ovo sto pises Quote Share this post Link to post Share on other sites
ciklotron 0 Posted December 5, 2016 (edited) Pozdrav ljudi,znam da u 1.3 multijet ide paraflu kao rashladna tecnost,da li mogu neku drugu rashladnu tecnost da sipam. Trebao bih da dolijem nekih 100g. U pitanju je grande punto. Edited December 6, 2016 by neshaoct spojeno Quote Share this post Link to post Share on other sites
pedjavw 7 Posted December 5, 2016 Proveri na koliko ledi, ako je zadovoljavajuće, ti dodaj d.vodu, da dopuniš tih 100ml. Quote Share this post Link to post Share on other sites
punto75 0 Posted December 5, 2016 sipao od febi izvinite nije zeleni pogresno sam pisao plavi je g11 pise,merio sam -25C je za sada dobro hvala od vama Quote Share this post Link to post Share on other sites
ciklotron 0 Posted December 5, 2016 @pedjavw Merio sam, do -30. Mislio sam da dolijem ovag G12 antifriz. Quote Share this post Link to post Share on other sites
Memphis 15 Posted December 5, 2016 On 12/5/2016 at 2:08 PM, Juba said: jesi li siguran u ovo sto pises Naravno. Kakve veze ima klima sa antifrizom? Daj objasni Quote Share this post Link to post Share on other sites
Juba 0 Posted December 5, 2016 ja znam da se razlikuje ako ima aluminijumski blok onda se sipa g12 i ne moze se sipati g11 zbog alu delova,dok g12 menja po sastavu g11 jedino sto je skuplji,ako auto ima klimu ima i alu blok i samim tim se ne sipa g11 (moje shvatanje antifriza) koliko sam auta imao i promenio i savetovanja sa majstorima itd koliko JA znam,ne mora biti tacno al ja nikada niti jedan problem ikada sa tim Quote Share this post Link to post Share on other sites
PremieRacing 5300 Posted December 5, 2016 1 minute ago, Juba said: ...ako auto ima klimu ima i alu blok... Ne. Quote Share this post Link to post Share on other sites
Juba 0 Posted December 5, 2016 dobro nije frka dajte onda neko sveopste objasnjenje kako bi svi znali Quote Share this post Link to post Share on other sites
PremieRacing 5300 Posted December 5, 2016 NEma nikakve filozofije, materijal od kojeg je napravljen motor nema nikakve veze sa klimom. To je to. Nista tu nije uzrocno povezano. Quote Share this post Link to post Share on other sites
Juba 0 Posted December 5, 2016 dobro ali eto dajte neko vece objasnjenje vezano za antifriz i ima li ga neko generalno....??? Quote Share this post Link to post Share on other sites
Memphis 15 Posted December 5, 2016 Kao što rekoh nema veze jel ima klimu ili ne za Punta 75 ide Praflu G11 plavi. Moj ima klimu. G12 i G12+ te G13 idu u motore sa aluminijskim blokom. Al to nema nikakve veze sa klimom. Quote Share this post Link to post Share on other sites
