Milos911 2 Posted April 29, 2014 Kao sto se da videti iz prilozenog velika sam cepidlaka, zato sam mislio da ipak mora u mikron Veceras cu da ili odlemim otpornik ili da pokvarim adapter, pa ce sutra biti svasta kad krenem da stelujem Quote Share this post Link to post Share on other sites
milan-jtd 319 Posted April 29, 2014 Ma samo opusteno, ja sam moj otpornik odvalio malim srafcigerom... u nedostatku lemilice...i nista mu ne fali Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 29, 2014 (edited) Imam elm bluetooth i lap top sa eksternim tzv usb-bluetoothom.Uparim uredjaj, nadjem ga na port15, podesim u MES uredjaj i port, ali nece da se konektuje. Izbaci mi nesto kao "not conected, unreliable conection detected....bla bla"Bez obzira na podesenu brzinu... Edited April 29, 2014 by kolega.jankovic Quote Share this post Link to post Share on other sites
Nidzo 2 Posted April 29, 2014 Meni sa tim BT adapterom izbaci 2 porta, npr. port 3 i port 4. Preko jednog hoće da se konektuje, preko drugog neće. Quote Share this post Link to post Share on other sites
Milos911 2 Posted April 29, 2014 kolega.jankovic imas u opcijama kad biras port i ono ostalo dole kucicu "high latency mode". Probaj nju da cekiras pa vidi da li ce raditi.. Quote Share this post Link to post Share on other sites
milan-jtd 319 Posted April 29, 2014 Da, to High Latency Mode je i kod mene imalo uticaja. Kada sam ukljucio nije se vise tako cesto MES zaglupljivao. Inace i meni izbacuje dva porta Quote Share this post Link to post Share on other sites
Nidzo 2 Posted April 29, 2014 TIP: Inače MES čuva log fajl u folderu u kom je instaliran svaki put kada se konektujete na ECU Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 30, 2014 (edited) Namestio sam port - bez obzira na to NECECekirao ili ne high latency mode - NECE Znaci komp je nasao BT adapter, nasao je ELM i upario se. promenio sam HD Volume ID, instalirao MES i registrovao. Onda nastaje problem. Znaci podesim elm bt....., podesim port, podesim brzinu ..... i na testu mi izbaci "time out" Kada hocu da se vezem naravno izbacuje gresku jer ga ne vidi uopste.... Ovo je danas na desk topu u firmi, Juce na lap topu nije pricao ovo za tropinski adapter nego neki "unreliable conection detected" ili tako nesto... Edited April 30, 2014 by kolega.jankovic Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted April 30, 2014 Ništa ti ne preostaje nego da pošalješ meni. Da se poštediš nabreklih vena! Sa TNG-a Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 30, 2014 kad promenim na stila umesto alfe izbacuje ovako : Quote Share this post Link to post Share on other sites
Nidzo 2 Posted April 30, 2014 Na jednom skrinšotu ti prikazuje 1.4 verziju? Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 30, 2014 Probao i sa 1.4 i sa 1.7 Quote Share this post Link to post Share on other sites
Nidzo 2 Posted April 30, 2014 Evo kako kod mene ide (uparivanje, konekcija...) : Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 30, 2014 Kod mene isto tako do klika na "test" Quote Share this post Link to post Share on other sites
Nidzo 2 Posted April 30, 2014 Imaš li od nekoga da pozajmiš drugi ELM da s njim probaš? Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 30, 2014 Nemam...Ma zabole me! Ispizdeo sam skroz, instaliraj ovo deinstaliraj ono, drkam se ko da saljem spejs satl u svemir! ide u djubre i gotovo! pogubi zivce sa komadom plastike Quote Share this post Link to post Share on other sites
Dovla 9 Posted April 30, 2014 Možda nije do ELM-a možda je do Stila Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted April 30, 2014 Kažem ti, pošalji meni pa ako valja daću ti neku crkavicu. Sa TNG-a Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 30, 2014 Probao na dva stila i na dva racunara i nece! Sada mi trenutno izbacuje da ne radi dobro jer nemam driver za elm bt koji ne moze da nadje na netu..... Quote Share this post Link to post Share on other sites
Coa123 0 Posted April 30, 2014 Ja sam juče dobio elm i kupio bt.Instalirao drajvere za bt, upari se sa elm-om ali neće, mes ga ne vidi... Na kraju, u bt prozoru na obd desni klik, connect i proradio... Mali previd, ali za malo da elm odleti u zid. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted April 30, 2014 Daj te drivere na pp Quote Share this post Link to post Share on other sites
gogi1101 0 Posted April 30, 2014 @kolegaProveri da li je elm do kraja ustekan u obd.Meni je elm-usb tako brljavio ,poveze se na body... ali nece na ecu i kad sam ga bas muski ustekao u obd proradi Sent from my PMP5097CPro using Tapatalk Quote Share this post Link to post Share on other sites
DraganUS 450 Posted April 30, 2014 Jos jedan savet. Posto uzimamo jeftine verzije elm-a desi se da pri ubadanju u obd port od kola pinovi na elm se uvuku u njega i ne ostvaruju kontakt. To sam se nagledao dosta puta. Elm svetli da ima struju, ali par pinova se od ubadanja u obd port uvuklo u njega i nema kontakta. Sent from puntosaki. Quote Share this post Link to post Share on other sites
deki87 7 Posted May 8, 2014 Moze li na osnovu ovoga nesto da se vidi???http://s27.postimg.org/i3qxsiv03/image.pnghttp://s27.postimg.org/odm7fiuer/image.pnghttp://s27.postimg.org/x3jagdbw3/aa1.pnghttp://s27.postimg.org/jnw9qx3eb/aaa1.png Quote Share this post Link to post Share on other sites
milan-jtd 319 Posted May 21, 2014 Moze li sa ovim da se obrise Airbag greska na puntu? http://www.obd2-scanner.com/new-bmw-inpa-ediabas-kdcan-usb-interface-dcan-can-obd-obd2-o-p-112.html Kolega kupio za svog BMWa pa ga cimam da donese Quote Share this post Link to post Share on other sites
