danijel55 700 Posted June 2, 2018 Ajmo malo i o potrosnji Quote Share this post Link to post Share on other sites
Martin 799 Posted June 3, 2018 Može to i manje a brže. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 3, 2018 To je to.Ma ubijaju me seoski putevi,tacnije brda.Los put pa uspori ,ubrzaj ...Inace do CG kada sam isao 5.1l,u povratku 5.8l al sam ga vozio bez stednje. Quote Share this post Link to post Share on other sites
Martin 799 Posted June 3, 2018 U suštini, da - između 5.5 i 6.6 je ta potrošnja. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 3, 2018 Sve varira od goriva. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 3, 2018 U sustini ja zadovoljan, klima,4 nas,pun gepek,6h Cacak-Bar.Pri tome 15min granica i oko 20min nekih radova. Jos onu crnogorci sto se plase krivina. Popraviceno vreme kada bude stigao neki jaci jtd tj. Mjet od 150ks pa na vise. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 5, 2018 Malo da skinem prasinu. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 10, 2018 Jel ok ovaj nivo ili treba biti do cepa? Quote Share this post Link to post Share on other sites
Martin 799 Posted June 10, 2018 Kod mene je uvek na "pola" - do sredine posude, a i imam merač pa na njemu vidim nivo (kao za ulje). Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 10, 2018 Ok jeПослато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 10, 2018 Znaci nista ne treba pipati Quote Share this post Link to post Share on other sites
Martin 799 Posted June 10, 2018 Takoe, žaliće se gospođa ako nešto zafali. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 10, 2018 Nekad i nekad upali lampu za rezervu.Ali to brzo resimo hahah Quote Share this post Link to post Share on other sites
Lj_ubica 78 Posted June 11, 2018 Lepo i uredno Poslato sa ALE-L21 uz pomoć Tapatoka Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 14, 2018 Libra dobila nove distancere.Posto su stari imali po prilicno lufta,lako nailazili na srce i pri tome setali malo u felnu,sto je prouzrokovalo na nekim deonicama puta blago podrhtavanje na 80kmh.To je pocelo od kako sam stavio letnji set,posto je pregledano sledece: poluosovina,trap i delovi trapa i sve bilo odlicno.Na redu su bile felne i gume.Felne nisu krive, gume jes da su bile kupljene pred kraj leta nova,al ajde i njih i to je u redu.Dakle distanceri i brezoni ostali.Brezoni jeste da hvataju kraca nego kod original felni,za 5mm krace hvataju,pa sam to odbacio.Zvao komsiju strugara,skinuo tocak i pokazao mu.Na sta mi je rekao,kupi materijal poliamid.Kupio i otisao kod njega,za nesto manje od 3h je bilo sve gotovo.Novi distanceri teze se navlace na srce,a da bi ih ubacio u felnu mora da nagazim,tj udarim nogom da bi uglegli,dakle sve fest.Vibracije su sve nestale.Jos jedan update uzeh i navodno jace halogenke sijalice,daju beli svetlost 100W.Njih sam stavio na duga svetla,posto na kratka su xenoni.E sad jos uvek nisam vozio po mraku pa da uporedim.Bice utisak u narednih par dana.O ovim sijalicama je rec: Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 15, 2018 Lepo navedeni razlozi zasto mi nikada nije padalo na pamet da se bakcem sa tockovima koji nisu OEM. Uz svu zaje*anciju oko PCD, CB, ET, srafova... A bar kod Zabara ima lepih modela da se izabere, em sigurica, em stilski idu uz model za koji su pravljeni. Intensa mi je jednostavno savrsena za Lybru, Blade za Stilo, Sport za Bravo, itd... 12 hours ago, danijel55 said: Jos jedan update uzeh i navodno jace halogenke sijalice,daju beli svetlost 100W. Momentalno bih tu "no-name" 100W zamenio sa standardnom od 55W, ako ti je ostala fabricka instalacija. Da kojim slucajem tata ne bi spalio Djenku... Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 15, 2018 Iskreno i ja sam hteo da kupim fabricke felne. Ali su dolazile u obzir samo R15 sa 7 kraka ,posto su gume skoro nove i one su mi se jedino svidele.E sad ni jedne nisam nasao dobre u mojoj okolini.Intesa jestr lepa felna,ali mi jednostavno je lezi na sivu libru.Bas uzivo sam imao priliku da vidim kako to sve stoji.Mislis da su prejake ove od mene 100w za duga svetla? Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted June 15, 2018 Ja sam jednom uzeo te sijalice za Bravo, lose su sijale i kratko su trajale. 55w je preporucena sijalica a te su duplo jace. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 15, 2018 (edited) Prilicno verovatno da moze da bude problem, posto je instalacija predvidjena za 55W, a ove su 100W. Pozeljno je bar ugraditi odgovarajuci relej, ako je to potrebno. Imao sam identican slucaj pre nekih 15-20 godina, igrali se sa tim 100W sijalicama na Peugeotu, bez ikakvih prepravki. Mislim da je prvi na udaru bio prekidac, ako se dobro secam, takodje i da su se farovi vise grejali... 58 minutes ago, danijel55 said: Ali su dolazile u obzir samo R15 sa 7 kraka ,posto su gume skoro nove Ako zelis da skockas auto po svom ukusu, bar gume u "narodskim" dimenzijama ne bi trebalo da budu neki problem - 205/55 su bagatela za 16'', kao i 195/65 u 15''. Ako ti odgovaraju performanse i izgleda sa 16'' - verujem da bi bila vrlo mala doplata za konverziju, pogotovo ako ti je lepo ocuvan trenutni set. Edited June 15, 2018 by Ivan Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted June 15, 2018 E da pre 2,3 god je neko pd drugova na Puntu imao taj problem sa takvim sijalicama. Ona instalacija oko sijalice je bila izgorela. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 15, 2018 (edited) O tome i pricam, sto se mene tice vise nikad ne bih stavljao 100W sijalice, danas ima mnogo boljih resenja za pristojne pare. A od felnica, ako vec ide balonjara, recimo ove su mi simpaticne, na njih si i ti mislio? A evo primera gunmetal Intense na sivoj Lybri, sta znam, ukusi su razliciti... Meni pije vodu, sigurno je lepse nego sa 15'', a sto je bitnije mnogo je bolji osecaj u voznji, pogotovo kad se imalo zgazi po krivinama: Edited June 15, 2018 by Ivan Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 15, 2018 Marko sto drzi delove za libru upravo ima intesa felne na libri limuzini,iskreno nije bas nesto.Sto se krivina tice AP Ljig-Preljina krivinu svaku opeglam sa 140-150 pa cak i 160.A krivine te i nisu bas sala. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 15, 2018 Ne pricam uopste o AP, gde se to dosta manje primeti... Bilo koja zahtevnija deonica pokaze sve mane balonjara - iako su uvek bile propisno napumpane, na Stilu JTD sam uvek po ostrijim krivinama imao osecaj bezanja preko nosa i ljuskanja zbog previsokih bokova (cak i kada je auto bio malo jace od 4 godine star). O izgledu tek da ne pricamo, mada je Lybra ipak specificna limuzina pa ne treba ni preterivati sa dimenzijama. A izmenjao sam na njemu od 195/65/15 do 215/45/17, za moje potrebe i taj auto pravu meru performanse/udobnost/odrzavanje nasao sam sa 205/55/16. Sada na Sportu imam standardne 225/45/17, a auto je toliko drugacije trimovan - aj' sto je ocekivano stabilniji, nego je i ususkaniji i udobniji nego Stilo sa 16''. Na njega komotno imam osecaj da moze i 18'' (fabricki je 225/40/18) a da se to bas toliko drasticno ne odrazi na udobnost. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 15, 2018 Klisura,kanjon morace,put Guca-Cacak preko karaule.Poprilicno sam zadovoljan performansama 15.Evo recimo za novu godinu put ka Zlatiboru,klisura.Bmw 5 sa 18,samo je bio levi u prvoj pregledanoj krivini sa 150 sam ga osisao. Sto se brzine tice,uvek volim po gasu da to bude.Pogotovu po krivinama. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 15, 2018 Drugarski savet malo iskusnijeg kolege - bar probaj koja je razlika vec i sa 55 profilom na istom autu, pa ces se uveriti i sam. Cak, najveca razlika mi je izmedju 15'' i 16'', nego bilo sta drugo, kako za zoll povecavas precnik. Ne kazem ja da auto staje , nego da je dosta opustenija, sigurnija i prijatnija voznja. Jedina prednost balonjare je udobnost (gde je put los, a i to zvisi od trima auta) i niza cena. A zadnjih 7-8 godina i 205/55/16 i 225/45/17 su se izdvojile kao jeftini standard, tako da im ni ovo poslednje nije vise nikakva prednost. Quote Share this post Link to post Share on other sites
