Gagy.GM 59 Posted April 22, 2017 Odlicno je uradjeno. Koliko su te izasle opruge ako nije tajna? Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted April 22, 2017 11 hours ago, ivansd said: Naravno Karter Man II Quote Share this post Link to post Share on other sites
ivansd 13 Posted April 22, 2017 3 hours ago, Gagy.GM said: Odlicno je uradjeno. Koliko su te izasle opruge ako nije tajna? Hvala 40 evra sam ih platio 2 hours ago, Ivan BG said: Karter Man II Ne prizivaj Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 22, 2017 odlican je za sve pare,bas si dobro prosao sa oprugama,dal je sad malo stabilniji auto Quote Share this post Link to post Share on other sites
nstyner 171 Posted April 23, 2017 Prava visina,samo sad malo više obraćaj pažnju na ivičnjake i ostale "izbočine" po putevima ! Quote Share this post Link to post Share on other sites
ivansd 13 Posted April 23, 2017 Lepo se vozi, oseti se da je tvrdji kad se naidje na spoj asfalta pa je sledeci vislji, a kako se ponasa u krivinama videcemo I sa prethodnim oprugama se fino ponasao jer su bile malo nize i tvrdje od fabrickih... Jedino sad treba da se pripazi na ivicnjake i tako to Quote Share this post Link to post Share on other sites
MS PK 7735 Posted April 23, 2017 Odlicno izgleda ovako! Quote Share this post Link to post Share on other sites
ivansd 13 Posted May 22, 2017 Neka slika sa skupa I novi stiker Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 22, 2017 Pa gde je slika sa skupa? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted May 22, 2017 Pa bile skupe slike, 150din kao na svadbi pa nije kupio Quote Share this post Link to post Share on other sites
ivansd 13 Posted May 22, 2017 Fotograf drao sa cenama pa imam samo one do i posle skupa Quote Share this post Link to post Share on other sites
Dezurni 399 Posted May 22, 2017 Obavezno ispolirati falc, a srce po želji (tamno sivo) Quote Share this post Link to post Share on other sites
ivansd 13 Posted May 23, 2017 Planirao sa to da uradim u preko zime pre nego sto ih stavim na auto ali nisam imao vremena namolicu se valjda uskoro i to da uradim U planu mi je nesto ovako Quote Share this post Link to post Share on other sites
Dezurni 399 Posted May 23, 2017 Tako i nikako drugačije Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 23, 2017 Bas gledam u nedelju. Kako ce ovaj sticker da se uklopi tu pozadi Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
ivansd 13 Posted May 23, 2017 Stiker se uklopio fabricki Quote Share this post Link to post Share on other sites
ivansd 13 Posted June 8, 2017 Dezinfikovana klima Quote Share this post Link to post Share on other sites
Axic 20048 Posted June 11, 2017 3 hours ago, Ivan BG said: Carina? Karina ili između dva plastikanera? Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted June 11, 2017 Masina izmedju dva Resoa Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 11, 2017 (edited) 1 hour ago, Axic said: Karina ili između dva plastikanera? Carina naselje u SD. Edited June 11, 2017 by Ivan BG Quote Share this post Link to post Share on other sites
