ivansd 13 Posted December 17, 2015 Nakon mazde u garazu ulazi crveni puntisa za sad neka fotkica dok ne padne pranje i fotosesn Inace puntisa je 2001god 1.9jtd u hlx opremi (plisana sedista, podizaci, centralna, el retrovizori) boja je crvena metalik, alu felne 15ce presao 151hiljadu i po stanju auta bih rekao da je tacna km Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 17, 2015 Odlican izbor! Sad sredjivanje pa jedna dobra mapa i da nisko leti Ja obozavam punta 1.9jtd. Raketa i stock kad je Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 17, 2015 Srecno Ivane, lepa boja, ali crni je lepsi ... a ti Mico gledaj kako su lepi ovi sa 5 vrata Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 17, 2015 Lep je punto sa 5vrata ali sa 3 je jos lepsi. Pa imao sam dva petovratna, sta da ih gledam Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 17, 2015 (edited) Hvala hvala! nisam ocekivao da cu naci ovako dobar primera al posrecilo mi se zad pocetak ide zatamnjivanje stakala a za dalje videcemo Edited December 17, 2015 by ivansd Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 17, 2015 Pa standardno, v.servis, m.servis, pretreses trapove i kocnice. Ocistis usis i dobra mapa, pa felne i morimoto. I vozis Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 17, 2015 pa da to je to Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 17, 2015 A bre samo me pitaj ako si u nedoumici Quote Share this post Link to post Share on other sites
Axic 20048 Posted December 17, 2015 Lepa boja i deluje bas lepo ocuvan, srecno s autom. Sto mu lepo leze ove felne, jel su bese od starog Brava ili ... Quote Share this post Link to post Share on other sites
nemke 92 Posted December 17, 2015 Sta si se stiso sa slikama Salim se.. Nek je sa srecom.. Lep puntic.. A sve ostalo lagano... Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 17, 2015 A bre samo me pitaj ako si u nedoumici imas pivo i rebarca za pomoc Hvala ljudi! Da felne su sa starog brava i cini mi se da mu lepse stoje nego bravu!! Ocuvan je fenomenalno spolja i ima par sitnica ali enterijer kao nov!! Bice sutra jos slika po danu danas sam ga i kupio pa dok sam dosao kuci vec se smrklo Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted December 17, 2015 bogami,lepo bas dobro izgleda hlx Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 18, 2015 Hvala Rile evo jos koja slicica Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 18, 2015 Svaka cast onome ko je upakovao kasetofon od Brava ... mora da je imao jednog Brava za delove Koliko te kostao ... ? Vuce me nesto opet ka Puntu Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 18, 2015 (edited) Moguce neki mu drugari drze otpad pa ga mozda tu sastavljao 1700 sam ga platio plus registracija gorivo... izasao je negde na 2000evra a alfa159? nista? ne radi mu obrtaljka jel ima neko ideju sta bi moglo da bude gde da trazim kvar? Edited December 18, 2015 by ivansd Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 18, 2015 Ma ja to kad vidim pa me povuce malo nostalgija ... Alfa je sledeca Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 18, 2015 Dacu ti da ga provozas kad dodjes da te mine zelja Kako u ePER-u da ga proverim? Quote Share this post Link to post Share on other sites
Axic 20048 Posted December 18, 2015 (edited) @beli To je fabricki kasetofon za Punta i kod mene je auto stigao sa istim jedino je ovom sa slike kako mi se cini prelepljena neka plasticna maska preko kasetofona i ostatka c. konzole. Edited December 18, 2015 by Axic Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 18, 2015 Ne znam zasto mi izgleda kao da je sa Brava ... pobrkao sam nesto Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 18, 2015 (edited) Ima neku foliju (kao stiker izgleda) preko cele centralne konzole jel imaju u hlx opremi daljinsko zakljucavanje? dobio sam samo jedan kljuc uz njega koji nije daljinac pa ne znam da li poseduje to Edited December 18, 2015 by ivansd Quote Share this post Link to post Share on other sites
Axic 20048 Posted December 18, 2015 Svaki HLX Ima fabricki kljuc sa tasterom, barem jedan. Drugi moze da bude isto sa tasterom ali je to verzija koja ima fabricki alarm i ne secam da sam kod nas video nekog da ima takvog.Vidi i vozacev prozor, verovatno je automatski i kod tebe. Zadrzi na kratko el. podizac i pusti, prozor ce se verovatno spustiti do kraja. Za zatvaranje isto. Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 18, 2015 Ima automatski prozor to sam provalio. Onda verovatno ima i daljinako zakljucavanje. Dobio sam samo jedan obican kljuc bez tastera moram da vidim kod nekog kljucara da li moze da napravi kljuc sa daljincem i da ga kodira Quote Share this post Link to post Share on other sites
ivansd 13 Posted December 20, 2015 Zatamnjena stakla pozadi 80% napred 65% Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 20, 2015 Sad izgleda ozbiljnije Quote Share this post Link to post Share on other sites
