77mario 0 Posted June 17, 2017 Trenutno se na oglasu nude ova dva auta. http://www.njuskalo.hr/auti/lancia-phedra-2.0-jtd-max-sacuvana-oglas-10594895 http://www.njuskalo.hr/auti/lancia-phedra-2.0-multijet-diesel-full-oprema-7-sjedala-oglas-21333979 Vozim se normalno, uglavnom po propisima ili malo iznad njih. Ne divljanje, ne palim gume ali volim kad prestižne da to bude brzo. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted June 17, 2017 51 minutes ago, 77mario said: Vozim se normalno, uglavnom po propisima ili malo iznad njih. Dooosta je 120 KS. 51 minutes ago, 77mario said: ...ali volim kad prestižne da to bude brzo. Onda možda nije Phedra model auta za tebe...možda neki manji, tj. neki koji nije kombi. Ona je auto koji prosto nije pravljen za to da bude nešto posebno brz, agilan. Quote Share this post Link to post Share on other sites
77mario 0 Posted June 17, 2017 58 minutes ago, 77mario said: Trenutno se na oglasu nude ova dva auta. http://www.njuskalo.hr/auti/lancia-phedra-2.0-jtd-max-sacuvana-oglas-10594895 http://www.njuskalo.hr/auti/lancia-phedra-2.0-multijet-diesel-full-oprema-7-sjedala-oglas-21333979 Vozim se normalno, uglavnom po propisima ili malo iznad njih. Ne divljanje, ne palim gume ali volim kad prestižne da to bude brzo. Mora biti Phedra, imam 4 djece, 6 nas je Quote Share this post Link to post Share on other sites
djunis82 195 Posted June 17, 2017 Grand Scenic, Grand Picasso, Peugeot 5008, S-Max, Touran/Sharan... Quote Share this post Link to post Share on other sites
77mario 0 Posted June 19, 2017 Ima li model sa 120 ks dpf? Quote Share this post Link to post Share on other sites
Elra 204 Posted June 19, 2017 Svi imaju FAP filter. Quote Share this post Link to post Share on other sites
rasko78 60 Posted June 19, 2017 On 6/17/2017 at 1:54 AM, neshaoct said: @77mario Kod istih onih koji čipuju Stilo, Bravo, ili skoro pa bilo koji dizel. Koje su firme tačno na dobrom glasu u Hrvatskoj ne znam. @rasko78 Meni su rekli uglavnom lepe stvari o automatiku u novoj Cromi 2.4 MJet, isto je japanac. Provozao sam auto sa tim menjačem @DraganUS i lepo radi, brzo menja stepene prenosa. Je l i na njega misliš mada kažeš da treba bežati od svih tih japanskih automatika kod Fiata, ili...? Nerado nešto kritikujem, ali koncepcija menjača koja podrazumeva da filter može da se zameni tek nakon potpunog rasklapanja dekli, po meni je loša na duge staze. Menjači su skoro isti, sem u tome da AF 40 ima 6 brzina. Obzirom da sam puno vremena potrošio da i moj menjač radi glatko, održavanje i vanredni servisi, a u radionici mi stoji još jedan u rezervi, kada podvučem crtu, znam da sam pogrešio. Ali to ne utiče na moju oduševljenost italijanskim mašinama, jer to što mi se kvari, nije ni napravljeno u Italiji. Nadam se da nisam nikoga uvredio. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted June 21, 2017 On 6/19/2017 at 11:27 PM, rasko78 said: ...koncepcija menjača koja podrazumeva da filter može da se zameni tek nakon potpunog rasklapanja dekli, po meni je loša na duge staze. To je sada tako, kao da je postao standard kod dosta automatskih menjača. Skoro sam gledao kako to izgleda kod jednog novijeg BMW-a, čini mi se da mi rekoše da košta 100 evra zamena filtera, tj. novi filter se dobija komplet sa metalnim kućištem. Quote Share this post Link to post Share on other sites
77mario 0 Posted June 21, 2017 Zvao sam čovjeka za auto, phedra 2008. 120ks. Pitam ja njega: kako ide auto s obzirom da ima 1800 kg? Tvrdi on da ima 1400 kg (?) I da je euro5 motor unutra(?). Ja nigdje nisam našao te podatke. Zna li tko više od mene? Quote Share this post Link to post Share on other sites
darkman14 5901 Posted June 21, 2017 (edited) https://www.auto-data.net/en/?f=showCar&car_id=4933 Brand Lancia Model Phedra Generation Phedra Engine 2.0 JTD (107 Hp) Doors 5 Power 107 hp/4000 rpm. Maximum speed 174 km/h Acceleration 0 - 100 km/h 13.4 sec Fuel tank volume 80 l Year of putting into production 2002 year Coupe type Minivan Seats 8 Length 4750 mm. Width 1863 mm. Height 1760 mm. Wheelbase 2823 mm. Front track 1570 mm. Rear (Back) track 1548 mm. Minimum volume of Luggage (trunk) 325 l Maximum volume of Luggage (trunk) 2950 l Position of engine Front, transversely Engine displacement 1997 cm3 Torque 270 Nm/1750 rpm. Fuel System Diesel Commonrail Turbine Turbocharging Valvetrain OHC Position of cylinders Inline Number of cylinders 4 Cylinder Bore 85 mm. Piston Stroke 88 mm. Compression ratio 18 Number of valves per cylinder 4 Fuel Type Diesel Drive wheel Front wheel drive Number of Gears (manual transmission) 5 Front suspension The depreciated rack Rear suspension Helical spring Front brakes Ventilated discs Rear brakes Disc ABS yes Steering type Steering rack Power steering Hydraulic Steering Fuel consumption (economy) - urban 9.2 l/100 km. Fuel consumption (economy) - extra urban 5.9 l/100 km. Fuel consumption (economy) - combined 7.2 l/100 km. Kerb Weight 1736 kg. Max. weight 2505 kg. Tire size 215/65 R15 Edited June 23, 2017 by Woodoo Quote Share this post Link to post Share on other sites
danilo85 0 Posted March 3, 2019 (edited) Pozdrav narode. Posle 6 godina provedenih u Seat Alhambri resili smo da za promenu predjemo na Lanciu Phedru 170hp.. Interesuju me prvenstveno mane, ove dobre stvari se vide na prvi pogled.. inace auto je 2008-o godiste, 150000km na satu, automatik, sa panorama krovom i full kozom... Kakav je taj automatik, motor ??? Na sta najvise obratiti paznju prilikom kupovine ?? Hvala na pomoci... Evo i slika malo... Edited March 4, 2019 by neshaoct spojeno Quote Share this post Link to post Share on other sites
The Punisher 6616 Posted March 3, 2019 A koji je to motor u Phedri od 170 KS? https://www.auto-data.net/en/lancia-phedra-model-531 Quote Share this post Link to post Share on other sites
danilo85 0 Posted March 3, 2019 2.2 jtd 16v, 125kw.. Quote Share this post Link to post Share on other sites
The Punisher 6616 Posted March 3, 2019 To je Pežoov 2.2 hdi, nije baš najsjajniji Quote Share this post Link to post Share on other sites
danilo85 0 Posted March 3, 2019 Znaci da bežim od toga ili ? Mene najvise menjac brine, imao sam Alhambru automatik i prosle godine sam imao problema, 700€ mi izbacio iz dzepa.. Motor tu i tamo, mislim ako se redovno i sve po ps-u odrzava da nebi trebalo da bude vecih problema.. Quote Share this post Link to post Share on other sites
