hasanze 0 Posted September 22, 2010 e mozda cu ispasti glup ali nisam do sada znao da libra ima mog.navigacije .kako doci do diska za navigaciju jer ja to nisam dobio prilikom kupovine.hvala i pozdrav Quote Share this post Link to post Share on other sites
Woodoo 23015 Posted September 22, 2010 Navigacija ne radi na teritoriji cele istocne Evrope, tj. ne postoje mape, cak ni da se kupe. Tako da ako zelite iz tog razloga da nabavite disk nece vam biti potreban. Jedino ako ne mozete da namestite sat bez diska to je vec drugo. Quote Share this post Link to post Share on other sites
Dule 021 660 Posted September 22, 2010 Isto tako su i mom drugaru rekli za Ford Mondeo ali....Ima neki lik u Srbiji koji prodaje CD za vecinu automobila i navigacija radi.Jedino sto naplacuje taj CD samo 3000 dinara!Pa kome se svidja taj ga kupi.Mogu i telefonski broj da obezbedim ako treba. Quote Share this post Link to post Share on other sites
joca djavo 0 Posted September 22, 2010 Dule ajde nabavi broj telefona tog lika. Quote Share this post Link to post Share on other sites
hasanze 0 Posted September 22, 2010 ...ako mozete nabaviti bio bih zahvalan za broj i ja cu ovdje u bih pokusati naci ako nadjem gdje distribuirat cu ga dzabe ako kome bude potrebno.pozzzp.s. mislio sam na cd Quote Share this post Link to post Share on other sites
chiki 9 Posted September 22, 2010 A kako se koristi taj CD ? Zar Lybra nema kasetas? Quote Share this post Link to post Share on other sites
bglion 401 Posted September 22, 2010 @chiki Lybra ima kasetas ali ima standardno cd sarzer a modeli sa navigacijom imaju i poseban navigacioni cd rom. Quote Share this post Link to post Share on other sites
vaskez 0 Posted September 25, 2010 a gde stoji taj standardni cd sarzer? Quote Share this post Link to post Share on other sites
Woodoo 23015 Posted September 25, 2010 U gepeku, sa leve strane. Quote Share this post Link to post Share on other sites
bglion 401 Posted September 25, 2010 Na karavanui na limuzini Quote Share this post Link to post Share on other sites
vaskez 0 Posted September 25, 2010 bas cu da proverim sutraHvala puno Quote Share this post Link to post Share on other sites
ellbe 0 Posted March 7, 2011 Ma ta ti navigacija u opšte ne može koristiti tu kod nas, samo za Evropu Ne postoji čak ni CD, za Balkan ili Adrija ruta, tako da je u potpunosti beskoristan Uzmi ko ja ovu garminovu i riješio si problem Quote Share this post Link to post Share on other sites
tomerc 0 Posted March 8, 2011 Nesto sam gledao po internetu i nasao ovo za Platform: RT3/RT4 Navi Drivehttp://www.heroturko.org/softwares/90747-maps-of-europe-for-peugeot-citroen-lancia-rt3-g2-navidrive-12-cd-set-v20092010.htmlPitanje je koju platformu navigacije mi imamo? Kako se to provjerava? Quote Share this post Link to post Share on other sites
tomerc 0 Posted March 10, 2011 Nasao sam ovo na jednom forumuRe: Lancia Lybra IDIS V5.25 Eastern europe has never been available for Lybra cars as far as I know. You can check the Navteq-website (link below) for all countries that are sold. Germany and the Alps like you asked can be updated if you have a G3 system. Witch you probably have because mine is also a 2001 and a G3. You have to do a firmware update before you can read an (Opel)ncdx cd witch you can get elsewhere on this fantastic forum. This update will automaticly be done if you insert a original Lybra Navigation CD of the year 2004 or later. If your system has alraedy the latest software, it should display "software version V5.38". The update is also for the car phone and the trip computer and takes about 20- 30 minutes. After updating, you only have to download and burn the NCDX CD's witch provide you the latest maps in your Lybra. Only difference are the dealer points of interest, witch are Opel instead of Lancia. I can insure you that it is possible because my Lancia Lybra works flawlessly with it. Good luck!...and great car!Da li netko ima CD 2004 ili kasnije?http://gpsunderground.com/forum/alfaromeo-fiat-lancia/5837-lancia-lybra-idis-v5-25-a-2.html Quote Share this post Link to post Share on other sites
tomerc 0 Posted March 12, 2011 Izgleda da moze da se koriste Opelove karte, ali mora da se uradi update softweraOvo je tema sa linkovima za skidanje softwera i karatahttp://gpsunderground.com/forum/opel/7740-opel-siemens-2010-2011-ncdx-systems.htmlOvo je Lybrista iz te teme koji je to i uradio i kaze da mu radihttp://gpsunderground.com/forum/opel/7740-opel-siemens-2010-2011-ncdx-systems-2.html#post57870 Quote Share this post Link to post Share on other sites
MISHONNIUM 15 Posted April 22, 2011 Moja Lybra nema navigaciju, ali ja sam to resio kupovinom Garmina NUVI 255, koji je fantastican uredjaj. Najbolja je stvar sto se dimenzijama tako lepo uklapa u gabarite onog ekrana u Lybri. Ja Garminov vakuum nosac i ne koristim, samo stavim uredjaj u onaj prostor ispred ekrana. Stoji sam, izgleda kao original i sto je najbolje ne ispada. Ekstra resenje. Oakcicu i sliku, da vidite koliko je fora dobra. Quote Share this post Link to post Share on other sites
MISHONNIUM 15 Posted April 23, 2011 Evo i slicica, da vidite kako izgleda. 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2011 ko dupe na noshu Quote Share this post Link to post Share on other sites
MISHONNIUM 15 Posted April 24, 2011 Bash tako Quote Share this post Link to post Share on other sites
vladap 0 Posted July 5, 2011 Izgleda da su se pojavile mape upotrebljive na Lybri posle gorenavedenog update-aMy linkJos da se dokopamo cd-ea br3... Inače košta 1xx€ Quote Share this post Link to post Share on other sites
bglion 401 Posted July 8, 2011 Mislim da ne mogu te mape za VDO.Uklapaju se samo Opelove NCDR posto je siemens ics na lybrama sa navigacijama Quote Share this post Link to post Share on other sites
Marikoni 0 Posted December 16, 2012 Jel možda neko uspeo da namesti navigaciju (da radi) na našem području do sada? Quote Share this post Link to post Share on other sites
Woodoo 23015 Posted December 16, 2012 Radi na nasem podrucju samo nema mape Srbije i istocne Evrope. Quote Share this post Link to post Share on other sites
Marikoni 0 Posted December 17, 2012 E pa to je to. Ja sam mislio da do sada ima nesto sto se promenilo u vezi toga, ali nije. Kada sam tako reci presretao ljude po ulici, pitao za licna iskustva o LYBRI, jedan covek mi rece da "moze da se dekodira" nesto i da radi?!? Navodno to kosta 20-25 e. Jel to istina, ili je i on obmanut pa lose prenosi informaciju?Bas sam nesto zapeo da je namestim Quote Share this post Link to post Share on other sites
M626 0 Posted December 18, 2012 Pa nema sta da se dekodira (osim ako nisu mislili na sam uredjaj ako izgubis kod karticu), mape jednostavno nisu napravljene za nase podneblje... postoje iskustva ljudi na netu koji su uspeli da ucitaju Opelove mape koje navodno imaju Srbiju, ali dok to ne vidim uzivo ne verujem Quote Share this post Link to post Share on other sites
