tatamata 2 Posted November 17, 2012 ali ovaj bez ABS-a ima kraći zaustavni put Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted November 18, 2012 Za pesak i sneg je bolje kad malo blokira točak, dokazali ovi iz Bosch-a. Quote Share this post Link to post Share on other sites
Mijailović P. 3737 Posted November 18, 2012 :stuart: :stuart: :stuart: :stuart: :stuart: Quote Share this post Link to post Share on other sites
integralac 2786 Posted November 28, 2012 pismeni kinezi Quote Share this post Link to post Share on other sites
chikavili 511 Posted November 30, 2012 pismeni kineziImaju moji roditelji zidni sat star preko 30 godina koji ima isto napisanu cetvorku, nije to nista cudno, niti ima veze sa kinezima A evo sta kaze wikipedia na tu temu:"IIII" on clocksClock faces that are labeled using Roman numerals conventionally show IIII for four o'clock and IX for nine o'clock, using the subtractive principle in one case and not the other. There are many suggested explanations for this:Many clocks use IIII because that was the tradition established by the earliest surviving clock, the Wells Cathedral clock built between 1386 and 1392. It used IIII because that was the typical method used to denote 4 in contemporary manuscripts (as iiij or iiii). That clock had an asymmetrical 24-hour dial and used Arabic numerals for a minute dial and a moon dial, so theories depending on a symmetrical 12-hour clock face do not apply.Perhaps IV was avoided because IV represented the Roman god Jupiter, whose Latin name, IVPPITER, begins with IV. This suggestion has been attributed to Isaac Asimov.Louis XIV, king of France, who preferred IIII over IV, ordered his clockmakers to produce clocks with IIII and not IV, and thus it has remained.Using standard numerals, two sets of figures would be similar and therefore confusable by children and others unused to reading clockfaces: IV and VI are similar, as are IX and XI. As the first pair are upside down on the face, an additional level of confusion would be introduced—a confusion avoided by using IIII to provide a clear distinction from VI.The four-character form IIII creates a visual symmetry with the VIII on the other side, which the two-character IV would not.With IIII, the number of symbols on the clock totals twenty Is, four Vs, and four Xs, so clock makers need only a single mould with a V, five Is, and an X in order to make the correct number of numerals for their clocks: VIIIIIX. This is cast four times for each clock and the twelve required numerals are separated:V IIII IXVI II IIXVII III XVIII I IX The IIX and one of the IXs are rotated 180° to form XI and XII. The alternative with IV uses seventeen Is, five Vs, and four Xs, requiring the clock maker to have several different patterns.Only the I symbol would be seen in the first four hours of the clock, the V symbol would only appear in the next four hours, and the X symbol only in the last four hours. This would add to the clock's radial symmetry. Quote Share this post Link to post Share on other sites
integralac 2786 Posted November 30, 2012 mene u skoli nisu tako ucili, a ni wiki tad nije postojao, ali eto sad znam Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted December 2, 2012 mene u skoli nisu tako ucili, a ni wiki tad nije postojao, ali eto sad znam I mene učili da rimski brojevi imaju samo do tri ponavljanja, zato su bili ograničeni do tri hiljade i kusur. Ono verovatno kinezi nisu najbolje shvatili Marka Pola ili im jednostavno falilo V a ovo sa četiri IIII se svidelo pa zadržali do danas. Bolje kad iz nezadovoljstva pokažu kolektivno zadnjice. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 3, 2012 (edited) Ruski ako ne znate naucicete Edited December 3, 2012 by beli_Punto Quote Share this post Link to post Share on other sites
kicerica 6 Posted December 9, 2012 ovo je vrh Quote Share this post Link to post Share on other sites
Mijailović P. 3737 Posted December 9, 2012 Pa sve vreme sam imao utisak da poznajem ove NA-crtane likove a sad' mi je i potpuno jasno da sam bio u pravu ! Quote Share this post Link to post Share on other sites
kicerica 6 Posted December 9, 2012 Eto vidis odakle krade veliki brat. Quote Share this post Link to post Share on other sites
silenci 2697 Posted December 9, 2012 eee ovo mene treba da ocistim sneg,jel od snega nemogu da isteram auto iz garaze uzas Quote Share this post Link to post Share on other sites
miske17 0 Posted December 9, 2012 jesi probao lopatom? Quote Share this post Link to post Share on other sites
