MS PK 7735 Posted May 18, 2019 Extra sad!Послато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
neshtry 14885 Posted May 18, 2019 Uh, lep! Poslato sa POT-LX1 uz pomoć Tapatoka Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 18, 2019 Ne moze kupe bez Blade felni i kacketa pozadi. To mora da imaПослато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted May 18, 2019 Bice i kacket, imao sam priliku da kupim cela gepek vrata u toj boji sa kacketom za 50e, ali tada sam imao ulaganja oko motora i nisam mogao da odvojim tada novac za to pa sam propustio priliku, ali sigurno ce da naleti neki Sent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 18, 2019 Javi ako bude nesto povoljnoПослато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted May 18, 2019 Vazi ako ti treba nesto posebno javi da kazem ovom da mi sacuva ako naleti, tj kad naleti Sent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 18, 2019 Ok, eto kacket Послато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted May 18, 2019 Ako naleti neki koj nije u 647 boji javljam Sent from my FIG-LX1 using Tapatalk 2 MS PK and neshtry reacted to this Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted May 19, 2019 Zavrseni farovi, izgledaju odlicno, kao fabricki, tako ce i da ostane, jedan projektor i samo gasSent from my FIG-LX1 using Tapatalk 2 Djuk85 and MS PK reacted to this Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 7, 2019 Nesto se ceprkalo danas, neke sitnice koje nisu vredne pomena i jedna stvar koja me iritira, ne prska nazad na staklo vodu, skidao sam motorcic, sve ispravno, menjao creva, napred prska bez obzira na koje je mesto crevo sto mi ostavlja jedino da je crevo za zadnje staklo negde zapuseno, zadnja prskalica nije zapusena, proverio sam je, s obzirom da voda ne curi nigde u kabini ko zna gde je crevo zapuseno. Nesto cudno se desava sa tom vodom, kad povucem rucicu on prska na soferku i pali prednje brisace, a kad gurnem rucicu isto prska napred, pali prednji brisac i posle par sek upali zadnji brisac, i trebalo bi da prska nazad, ali zasto prska napred i pali brisac napred kad gurnem rucicu?Branik sam skinuo da bi imao bolji pristup boci a i ujedno da nastelujem desni far, pa sam resio da olaksam sebi posao i skinem branikSent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7735 Posted June 7, 2019 Bocu skines iz haube, nema potrebe da diras branik. Nesto mi je cudno tu kod tebe, to sto prska napred i pali opet prednje brisace. U redu da pali zadnji i ne prska pozadi ali ovo mi je naopako Послато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 7, 2019 Znam da moze odozgo, ali je mnogo lakse bez branika a branik se skida jos lakse, i meni je to cudno, imam i klip ali ne znam gde da ga izbacim, ok bi bilo recimo da prska vodu, mozda zapuseno crevo pa voda ide gde moze, na drugu stranu, ali opet to ne bi trebalo da se desava.Sent from my FIG-LX1 using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
bit 938 Posted June 7, 2019 Možeš na https://streamable.com bez nalogaNi kod mene ne prska pozadi, nisam još gledao šta kako, a Stilo baš nabacuje na zadnje staklo čini mi se svu vodu koju gume dotaknu. Pomoći će mi ako ti rešiš Kod escorta i kod mondea zadnje bude čak i suvo kad kiša pada ako se ne staje .Послато уз помоћ Тапатока Quote Share this post Link to post Share on other sites
neshtry 14885 Posted June 7, 2019 Meni na Alfi 147nije radilo dve sezone,od kako je kod buraza proradilo...a bude nezgodno kad je hečbekPoslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 7, 2019 Ne baca meni na zadnje staklo mnogo vodu, vidi se super po kisi, ali je problem posle kise, ne znam kako je u vasim gradovima ali ovde u Bor-u se odmah uhvati prasina na kola, pokusacu da slikam tu prasinu, obicno ne bude nesto mnogo prasine, vidi se kroz staklo, ali trebalo bi da se ispere i obrise, da bi se videlo bolje, nekad kad ga ne vozim 2-3 dana bude haos prasina na njega, i malo malo pa ga perem, da koliko toliko bude cist EDIT: Evo klip kako radihttps://streamable.com/8pip5Ablender je menjan, morao sam da ga menjam zbog MF volana ali i sa starim je ista prica bila, znaci nije do ablendera, proveravao sam plus na dzek kod motorcica, kad se povuce samo na jednom ima plus i kad se gurne samo na drugom ima plus, znaci nije prespojio, jedino sto mi pada na pamet je da je zbog toga sto je zapuseno Sent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
darkman14 5902 Posted June 7, 2019 Proveri creva do zadnjeg stakla. To je bio kod mene na marei, u gepeku ima nepovratni plasticni ventil i tamo spalo crevo. Kad prskas, ne vidi se da negde izlazi voda jer je nema mnogo, a ne izlazi nigde. Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 7, 2019 Provericu taj nepovratni ventil, na stila je blizu tog motorcica, ako nije on problem onda cu morati da skidam nebo, ali sve mi se cini da je on problemSent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
darkman14 5902 Posted June 7, 2019 Cek, nije valjda da ide preko neba crevo za prskalicu? Koliko mi je poznato i logicno, crevo ide ka vozacu, pa ulazi u kabinu i ide pored vozacevih vrata dole ispod plastike ka gepeku. Na zadnjem stubu (C) se penje gore ka petim vratima i ulazi u vrata tamo gde i svi kablovi ulaze. 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 7, 2019 Iskreno nadam se da ide tim putem, nisam siguran kojim putem ide ali sam sve mislio da ide preko neba, nisam se mnogo zabavljao time, sunce me opeklo zestoko pa sam gledao da se pomerim sto pre, pogledacu kasnije ovaj ventil pa cu traziti putanju crevaSent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
darkman14 5902 Posted June 7, 2019 Na marei sam pratio, nisam 100% siguran da li ide sa vozaceve ili suvozaceve strane. Preko krova nema logike da ide nikako. Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 7, 2019 Cini mi se da na stari Bravo ide preko krova, komsija je menjao to crevo i video sam da je otkacio zadnji deo neba, e sad da li ide samo na kraj preko neba, da li je zavrsavao posao, ne znam, ali sam zbog toga mislio da ide preko krovaSent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted June 7, 2019 Mislim da je na marei preko suvozačevog krova, tako je kod mene...meni je crevo otišlo negde...ali se ja nisam zezao sa tim, samo sam zapušio crevo. Sent from my Redmi 4X using Tapatalk 1 bit reacted to this Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 7, 2019 Skinuo sam taj ventil, bio je zacepljen, ocistio sam ga wd sprejom, namestio ventil i probao pre nego sto sam namestio ceo sistem, baca extra vodu kroz ventil, namestim ventil, gurnem rucicu iiiiii nista, sad se prednji brisaci ne pale, ne baca vodu napred ali ne baca je ni nazad, sto ostaje da je crevo zapuseno, gledao sam krajeve, kod gepeka crevo ide u nebo, na sredini, nisam mogao da vidim gde skrece ali ispod one plastike kod vozaca ne ide, naravno nisam se setio da pogledam kod suvozaca, tako da to ostaje tako za sadSent from my FIG-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17685 Posted June 7, 2019 (edited) 5 hours ago, MiloshShomy said: gledao sam krajeve, kod gepeka crevo ide u nebo, na sredini, nisam mogao da vidim gde skrece Spusta se niz levi C stub. Sva instalacija ide tuda, sem koaksijalca radio antene koja se spusta niz desni C stub. Stilo je na forumu sazvakan do u detalje, maltene punu deceniju unazad (licno sam ga imao od 2007.). Tako da ces tesko pitati nesto sto vec nije objasnjeno, a najbrze ces odgovor naci pomocu Search foruma. Imas npr. i slike u mom DIY o skidanju neba na Stilu, vidi se lepo i crevo: A i kacili smo ranije i semu sa ePer, 1 slika 1000 reci: Takodje, za samostalne radove, eLearn ti je Alfa&Omega. Edited June 7, 2019 by Ivan 1 MiloshShomy reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted June 8, 2019 @Ivan u kojim prodavnicama bese imaju da se kupe zabice za lajsne i tapacire?Nece kolega da se ljuti, treba ce i njemu Послато са SM-J330F уз помоћ Тапатока Quote Share this post Link to post Share on other sites
