marinko AR 0 Posted July 21, 2014 Dakle stilo 1.2 16v 59kw, kod mene oko 1.5god, 220 000 km na satu, 6b, klima itd klasika. Alu felne 16x7 4x100, gume 205 55 16, lajsne sam ofarbao u boju kola, jos kvake ostale da se ofarbaju, nikako da ih skinem Zbog potrosnje, pre svega gradske voznje je pre 5 dana ugradjen plin i to je to za sad. Ko kaze da ovaj motor trosi 5 l benzina po gradu svaka cast... Uskoro bi trebalo da padne spustanje i felne blade 17", cim se otplati TNG Ako nekoga nesto zanima nek pita slobodno Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted July 21, 2014 Jos jedan Sve nas je vise,a moram priznati svaki sa lepim felnama Super su i lajsne u boji.Koje godiste je masina? Quote Share this post Link to post Share on other sites
Djole_M 150 Posted July 21, 2014 Lep Stilo,jesu li ove felne na KP oglasima Quote Share this post Link to post Share on other sites
Stilisa 313 Posted July 21, 2014 Konacno jos neko iz Ar. Odlicno izgleda! Lepe mu i ove felne, ali Blade je Blade, i ja jurim njih. Da sluzi dobro i da sto pre isplatis plin. Ako si raspolozen, baci pogled na ovo: http://www.fiat-lancia.org.rs/forum/index.php?/topic/59724-flcs-okupljanje-kragujevac/page-58 Quote Share this post Link to post Share on other sites
marinko AR 0 Posted July 22, 2014 Hvala svima Zaboravi da napisem, 2002 god je. Nisam ni znao da ima ovoliko 1.2 16v dok nisam poceo da ga vozim. Jesu felne bile na kp jer sam tada nasao blade 17" za manje pare, ali one se prodale i posle sam odustao od prodaje, ostace za zimski set.Raspolozen sam, ali nisam u mogucnosti da idem jer radim :/ Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted July 22, 2014 A koliko moze da razvije? Quote Share this post Link to post Share on other sites
marinko AR 0 Posted July 22, 2014 80-90, puna kapa Quote Share this post Link to post Share on other sites
Stilisa 313 Posted July 22, 2014 Na vr' gasa. Nema veze, vidimo se ovako u prolazu. Quote Share this post Link to post Share on other sites
toma ks 19 Posted July 22, 2014 Koji si gasni uredjaj ugradio i koliko te je to kostalo.Odlican auto i super motor Quote Share this post Link to post Share on other sites
SikterBre 31 Posted July 22, 2014 Baš mi se dopada sa lajsnama u boji Kao što sam već pisao X puta, sasvim korektna motorizacija za moj pojam i ne bih mu ništa zamerio... Fali mu neko diskretno potamnjivanje stakala... Nadamo se da ćeš biti u mogućnosti da posetiš neki od narednih skupova u Šumadiji Quote Share this post Link to post Share on other sites
marinko AR 0 Posted July 22, 2014 Ac stag, 380 evra + atest.Bice prilike, videcemo se na nekom od skupova Quote Share this post Link to post Share on other sites
Sedla 2576 Posted July 22, 2014 Tek sam sad video ovu temu. Dobrodosao,zemljak! Sto rece Stilisa,lepo je sto ima jos nekog iz AR. Ako si raspolozen,i ako imas vremena,mozes sa nama sutra u KG na druzenje? Quote Share this post Link to post Share on other sites
Stilisa 313 Posted July 22, 2014 Jao Sedlicu ne citas, samo ti Stilo u glavi, pitah coveka, radi. Kad zaboravih danas da javim da dodje. Quote Share this post Link to post Share on other sites
Sedla 2576 Posted July 22, 2014 Pa sta znam ja,red je da ga pozovem... Quote Share this post Link to post Share on other sites
marinko AR 0 Posted September 11, 2014 Evo konacno posle dugog traganja stigle 17"-ice Blade . Napred trenutno baloni 215 50 17, ali i to ce biti reseno za neki dan. nazad klasika 215 45 Da napomenem da je juce uradjen i atest plina. Quote Share this post Link to post Share on other sites
SikterBre 31 Posted September 11, 2014 Odličan je! Quote Share this post Link to post Share on other sites
Stilisa 313 Posted September 11, 2014 Uhh, bas su mu cucnule dobro. Znaci sad da se spusti. Quote Share this post Link to post Share on other sites
marinko AR 0 Posted September 11, 2014 Ide spustanje samo malo napred, oko 2cm cisto da se poravna prednji i zadnji kraj Quote Share this post Link to post Share on other sites
Axic 20048 Posted September 11, 2014 I čepove za felne da bude kompletan. Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted September 11, 2014 kako motor podnosi 17" ? Quote Share this post Link to post Share on other sites
Sedla 2576 Posted September 11, 2014 :clap: Koje su bile one prethodne,15" ili 16"? Quote Share this post Link to post Share on other sites
marinko AR 0 Posted September 11, 2014 ^^^16" su bile prethodne felne, za cepove cu videti da probam da napravim, mada meni se svidjaju i ovako bez cepova A motor bi trebao bolje da podnosi 17" Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted September 12, 2014 Ne znam da li koristis neki photo editor za slike ali Stilo izgleda odlicno Blade mu dobro stoje,ali prethodne su meni licno lepse Quote Share this post Link to post Share on other sites
marinko AR 0 Posted September 12, 2014 Slikano je telefonom, alkatel koji ima katastofalnu kameru 5mp Quote Share this post Link to post Share on other sites
Stilisa 313 Posted September 12, 2014 To, to, to Dante, sad jos ga ubedi da da meni Blade. :DI meni se svidjaju i bez cepova, mozes da probas da stavis samo mali plasticni cep u rupu tu, kao kolega sa foruma, potrazicu sliku pa cu ti poslati sta mislim. Jeftina varijanta, ionako skidaju te poklopce ko 2 i 2. Quote Share this post Link to post Share on other sites
