beli_Punto 123 Posted February 24, 2014 Problem je sto on ne zna sta `oce Quote Share this post Link to post Share on other sites
vicent 1263 Posted February 24, 2014 Ubedljivo najbolji način da saznaš kako ti se uklapaju felne je da se poigraš u Photoshopu! Ima na netu i objašnjeno kako se to radi! Na fotku tvog auta staviš željenu felnu, i odmah ti je jasno,valja ili ne! Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 24, 2014 Ovako nesto ce ici na puntaca, mk2b, 15" / 7.5J Quote Share this post Link to post Share on other sites
DinoG 7 Posted February 24, 2014 Auu koliko izadje tako zadovoljstvo? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 24, 2014 Odlicno izgledaju ... steta bi bila da nesto ne odgovara Quote Share this post Link to post Share on other sites
vicent 1263 Posted February 24, 2014 Preširoko je,kačiće! Na 7,5J idu minimum 205,ili 215,kad sednu 4-oro kačiće nazad,a napred kad namotaš pun! Bolje nadji 7J,manje boli! Ja sam probao 7,25J -et 35 i znam! Quote Share this post Link to post Share on other sites
SikterBre 31 Posted February 24, 2014 Ja sam vozio 195/50 r15 7J ET36 ako se dobro sećam, nisam imao problema, možda ako je ET manji može to bez problema da se uglavi, eventualno ako kači unutra da se odbije malo distancerima... Quote Share this post Link to post Share on other sites
Ticma 537 Posted February 24, 2014 To su fabricke sa dvojke GTI. Ne znam da li su isle bas na sve primerke ali na wolfsburg edition jesu Quote Share this post Link to post Share on other sites
vicent 1263 Posted February 24, 2014 Ja vozim 195/50/15 na felnama 7J et35, gore pomenute felne bi nosile širu gumu (205 ili 215/40),i to je sasvim druga priča!OZ Racing (7J et36),sam prodao drugu,i kod njega je nazad kačilo (skinuli smo podlošku brezona amortizera),a kod mene nije iako su oba JTD! Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 25, 2014 Na 7.5J 195 lezu kao budali samar, tacno iznad ruba se izdizu Na BBS sa slike je ET 20. Quote Share this post Link to post Share on other sites
vicent 1263 Posted February 25, 2014 Obzirom da su toliko izbačene,a guma nije nimalo šira od felne,moraćeš da voziš kao po jajima!Zakon je malo šira guma,po mogućnosti sa prstenastim ojačanjem! Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 27, 2014 Naravno, to stoji. steta sto je covek odustao od prodaje ovih BBS, tacnije, pokusao je ma izvacari, onako po srpski... Dogovor je bio 280e za felne, jer su jako retke u toj dimenziji i kod nas ovako sredjene. Posto sam danas uzeo Punta, zvao sam ga da se vidimo i da nakacimo felne - odgovor: Brate, ponudio mi je decko 350e, dolazi danas da ih pogleda, ako mozes da ponudis toliko, mozemo da zavrsimo. Samo sam prekinuo vezu i nisam se javljao na sledeca dva poziva od njega.... Idu moje stare AZEV, 15", 195/50 guma, 7.5J, tj. vec su na njemu... Odradjen i lagani tjun da poklopi fabricku verziju sa 90ks (moj je 70ks), pa lagano, malo po malo, nekako sa proleca Quote Share this post Link to post Share on other sites
SikterBre 31 Posted February 27, 2014 Ček, jel to neki novi projekat? Daj raspiši se ako jeste, fali na forumu jedna takva tema, sve teme starih tjunera su nekako zamrle... Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 28, 2014 Paaaa, jbm ga i jes i nije, felne metnute, remap bez dima za sada Lagano, videcemo Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 28, 2014 Slaba vajda, izgleda de ce morati manja felna, koji smor Ne znam da li bi distanci od yuga zavrsili posao, koliko su bese oni debeli? To je kod mene situacija, pozadi kaci o sraf od amorta, leva strana vise, desna mislim da i ne kaci, napred felna kaci o crevo od kocnica. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 28, 2014 Distanceri od Yuga su 5 mm, samo gledaj kad napred namontiras distancere da ne kaci u plastiku kad namotas pun levi ili desni ... jel si skidao podloske ? Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 28, 2014 Ma gledao sam po netu, ne moze 7.5J da se upasuje na fabricke amorte, jedino neke gewinde da ga drze zakucanog... Prosledjujem ove dalje, vozim 14" pa jurim lagano neke 6.5J plafon 15ice, smorio sam se. Cak i 7J ne mogu lepo bez da budzim cudesa Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 28, 2014 Ti si lud Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 28, 2014 Pa sta da radim, hajde reci Ako stavim distanc od 5mm i kaci, dzabe sam krecio. Premerio sam pozadi, nema ni 5mm trenutno od ruba.I sta sad pametno uraditi? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 28, 2014 Ajd ponovi sve iz pocetka ... Sirina je 7,5J, a koji je ET na felni Kod mene je 7J, ET35 i sve staje bez problema, samo sto sam ja imao jednu krivu gumu i skinuo podlosku jer je cesao taj deo gde je kriva ! tebi bi trebao da bude ET manji od 35 tj izbacenija felna da bi sve to leglo kako treba, a u slucaju da nije mozes distancerom da ga dovedes da bude kako treba Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 28, 2014 195/50/15, 7.5J ET 35 Quote Share this post Link to post Share on other sites
Ticma 537 Posted February 28, 2014 Kazem 7j na 3 vrata ide bez problema. Na 5 kaci malo rub. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 28, 2014 Ticma, kolika je razlika u mm izmedju 7J i 7,5J ... toliki mu distancer treba i resen problem Quote Share this post Link to post Share on other sites
FantomX 5 Posted February 28, 2014 12.7mm a ja do ruba imam trenutno dlaku manje od 5mm. Quote Share this post Link to post Share on other sites
Ticma 537 Posted February 28, 2014 Pa razlika je 12,7mm ali nema gde da je pomeri. Sa jedne strane je sraf a sa druge rub . . . Quote Share this post Link to post Share on other sites
