FantomX 5 Posted March 7, 2014 Imace, 7.5J ne pokusavaj da stavis, kacibpozadi amort i sraf, napred kavi sraf od creva kocionih... 7.5J, ET35 Quote Share this post Link to post Share on other sites
bane17 24 Posted March 7, 2014 Ove su 7j et 35...sa gumama 195 50 r 15...koliko sam razumeo kolege ovde to ne bi trebalo da pravi probleme.. Quote Share this post Link to post Share on other sites
FantomX 5 Posted March 7, 2014 Dok pozadi ne sedne dvoje... Probaj, pa vidi... Quote Share this post Link to post Share on other sites
bane17 24 Posted March 7, 2014 (edited) Tih problema nemam,nisam alav za zenama toliko,jedna napred jedna pozadi i dosta :-) :-) :-) ....tri bi vec bilo mnogo...:-) :-) :-)...tako da ne planiram da vozim dvoje pozadi.. Edited March 7, 2014 by bane 17 Quote Share this post Link to post Share on other sites
FantomX 5 Posted March 7, 2014 Ne planiram ni ja da hebem svaki dan, al' kad zena zamane oklagijom... Quote Share this post Link to post Share on other sites
vicent 1263 Posted March 7, 2014 Ove su 7j et 35...sa gumama 195 50 r 15...koliko sam razumeo kolege ovde to ne bi trebalo da pravi probleme..Ja to nosim na Puntu,i nemam nikakav problem! Felne 15" 7J,ET 35, 195/50/15 ! Quote Share this post Link to post Share on other sites
bane17 24 Posted March 7, 2014 Bez distancija, ono nemas nista..znaci samo staf na sraf i teraj...? Quote Share this post Link to post Share on other sites
vicent 1263 Posted March 7, 2014 Upravo tako! Quote Share this post Link to post Share on other sites
bane17 24 Posted March 7, 2014 Pa tooo majstore,to mi reci,ti si mi trebao,gde si bio do sada :-) :-) :-) :-) :-) Quote Share this post Link to post Share on other sites
FantomX 5 Posted March 7, 2014 3 ili 5 vrata? Quote Share this post Link to post Share on other sites
bane17 24 Posted March 7, 2014 Moj je 5 ako mene pitas,a njegov mi deluje da je 3 Quote Share this post Link to post Share on other sites
FantomX 5 Posted March 8, 2014 Na 5v oce da kaci pozadi sa putnicima kada stavis 7J. Quote Share this post Link to post Share on other sites
DinoG 7 Posted March 8, 2014 Ovisi o et-u. Moje 15x7 sa 195/50/15 i et29 su zapinjale iza o saraf amortizera na puntu 3v Quote Share this post Link to post Share on other sites
bane17 24 Posted March 8, 2014 Sta je bolje kad je et veci ili manji Quote Share this post Link to post Share on other sites
DinoG 7 Posted March 8, 2014 Et ti je udaljenost u mm izmedju figurativne sredine felge do mjesta dosjeda. Znaci kada bi gledao felgu iz profila to ti je polovica udaljenosti izmedju 2 ruba do tog dosjeda. Znaci ako imas 2 felge istih sirina, ova s manjim et-om ce imati srce blize dosjedu, a rub vise prema van i samim time ce felga biti vise vani Quote Share this post Link to post Share on other sites
bane17 24 Posted March 8, 2014 Hvala na objasnjenju...koje su vase dimenzije na puntu? Quote Share this post Link to post Share on other sites
DinoG 7 Posted March 8, 2014 Ove koje se sada rade su 15x7 et29 i kace pozadi pa ce ici distance od 10mm pa ce ukupni et biti 19 Quote Share this post Link to post Share on other sites
bane17 24 Posted March 8, 2014 A sta kazes za ove moje...dal ima sanse da stanu Quote Share this post Link to post Share on other sites
DinoG 7 Posted March 8, 2014 Koliko su siroke i koliki je et?Cim ima rub trebale bi imati manji et Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 8, 2014 Na 5V et35 i et38 koje sam probao su malo kacile o levi rub ali beznacajno. Tj kacila je guma a ne felna. Quote Share this post Link to post Share on other sites
vicent 1263 Posted March 8, 2014 Kod mene je i prethodni,i sadašnji Punto JTD 3vrata! Ovaj plavi je napred i spušten 2-3cm,i ništa ne kači! Quote Share this post Link to post Share on other sites
bane17 24 Posted March 8, 2014 Koliko su siroke i koliki je et?Cim ima rub trebale bi imati manji et195 50 r15 et35 7j Quote Share this post Link to post Share on other sites
DinoG 7 Posted March 8, 2014 Eto kolega kaze da njemu ne kaci nista, meni kaci, ali s tim da su gewinde pa je spusten 5,6 cm ako ne i vise. Ako planiras spustati auto imaj to na umu Quote Share this post Link to post Share on other sites
Ticma 537 Posted March 8, 2014 Samo na 5v kaci... Quote Share this post Link to post Share on other sites
bane17 24 Posted March 8, 2014 Vidim ja da ce felne u oglase,jesam se zajebao...bqcio pare bzv.. Quote Share this post Link to post Share on other sites
