Ja sam danas ugradio u Punto Classic 2 Bear daljinsko otkljucavanje (DK-LD-009-095 skakavac kljuc), 2300 din. Stavio crvenu led diode za indikaciju, spojio na migavce, cak sam ugradio motorcic u gepek da otkljucavam gepek daljinski. Sve lepo radi, ja sam zadovoljan. At the bottom of the fuse box is a 40pin connector. In this, you will find: White and green wire, this is your LOCK wire. Blue and purple wire, this is your UNLOCK wire. Also in the 40 pin connector at the bottom of the fuse box, are a pink wire, and a pink and white wire. These are for your indicators and can be connected to your RCL control box so that they flash when you lock/unlock the car.
