49 -
About luna
Sporting 1.4
Fiat Punto mk.2b 1.3 MJet - fuel cut off unavailable
luna replied to Violeta punto1.3mjet's topic in Grande Punto/Linea
Problem je sa elektronikom imao sam isti problem. Idi kod Gorana i rešiće ti problem. -
I ja imam isti problem, nakon ciscenje klapne auto jos gore radi. Stavio sam i drugu klapnu ali isto. Ostalo mi je jos da ocitim dizne ali ne znam koliko to ima veze. Evo ti kako se kalibrise klapna: 1.2 16V engine : With all users off and doors closed, turn the key on Sea and hold this position without touching anything for 60 seconds (you will hear a "click"). After this time, take the key to stop and hold the position for 30 seconds. Then you can start the engine and the butterfly finds its point of 0. (thank the YouTube user rockmaker90 for information) The "click" that you hear comes from the throttle body, it is the same butterfly that snaps. 1.2 8V engine: Bring the engine up to temperature, accelerated up to 5,000 rpm for 2 seconds, return to idle for 2 seconds, riaccelerate at 5,000 rpm for 2 seconds again and so on for 3 times, in this way you have made the ' auotapprendimento. (This procedure is recommended, usually, when you go to disassemble the throttle body, otherwise, as it is commanded through the accelerator cable, is not required) http://www.ilpuntomanutenzione.it/Guide.aspx?idguida=22
I dalje se mučim sa klapnom, i dalje radi neravnomerno i padaju obrtaji. Nabavio sam od 1.2 16V ali je leprit manji za oko 3mm u prečniku od 1.4 pa je nisam ni probao. Jel može MAP senzor da bude uzrok problema? Da probam njega da zamenim? I šta bi se desilo kada bih stavio ovu klapnu sa manjim leptirom?
Fiat Punto mk.2 - problem sa brisačima
luna replied to nenadbmitrovic's topic in Punto mk.1/Punto mk.2
Elektricar resio problem. Nesto je cackao oko kontakta na motoru brisaca, samo ne znam sta. -
Neko? Neki predlog sta da gledam? -
Kod mene se sada desava da kad dam kontakt brisaci pocnu da rade, izvrte jedan krug, i ako su ugaseni? A kad upalim brisace na prvu brzinu ili bilo koju drugu nikad ne zavrse u istom polozaju? I svaki put kad dam kontakt pale se i briisaci. -
luna replied to neshaoct's topic in Članske pogodnosti
Jel imas motor prednjih brisaca za Punto Mk2b? Cena? -
Cene za crevo i klapnu? -
A da, mislio sam na crnog punta. Za 1.4. Crevo je isto, a mislim da je i klapna. -
Cao, treba mi ono malo crevo sto ide iz ibera na vakuum i na usis za vazduh? U kakvom je stanju, nije ispucala i koliko para? I koliko je klapna gasa, jel ispravnja, ne padaju obrtaji na leru? Naravno cena -
Nema na svim kompovima phonic wheel reset. Kao sto je kod mene slucaj.
I dalje imam problema sa radom na leru. Nabavio sam kabl i FES ali u njemu nemam opciju za reset "Phonic wheel learn reset" imam samo "Self adaptation reset" Imam registovanu verziju 1.7 i free 2.1 ali ni u njoj nemam ovu opciju kao na slici. Kod mene ima samo prvo opcija ostale dve ne postoje. E sad da li da uradim Self-adaptation reset i ovu proceduru sa slike?
Jel probao neko ovako da resetuje klapnu? http://www.fiat-lancia.org.rs/forum/index.php?/topic/40221-stilo-16-16v-problem-sa-leptir-gasom/page-2 Nije mi samo jasno da li da gasim auto posle svakog puta ili...? Ja sam probao sva tri od jednom ali nesto nije uspelio
