the_reaper 2 Posted September 5, 2008 upravo se vrnuh od elektricara, akumulator je rikenzi, stize novi uskoro :lool: hvala svim na odgovorima! Quote Share this post Link to post Share on other sites
Guest 6739 Posted September 5, 2008 extra sto si sredioa, izgleda da je sad i meni na Octaviji rikenzi Quote Share this post Link to post Share on other sites
the_reaper 2 Posted September 6, 2008 to je neka epidemija :lool: Quote Share this post Link to post Share on other sites
Guest 6739 Posted September 6, 2008 ili nemarnost tokom letaostao je bez vodepocetnicka greska, po ko zna koji putnapunjen je nocas, auto je upalio, videcemo do kada ce drzati struju Quote Share this post Link to post Share on other sites
Guest 7047 Posted September 6, 2008 Kako ostao bez vode kad se moderni akumulatori ni ne dopunjavaju? Quote Share this post Link to post Share on other sites
chikavili 511 Posted September 6, 2008 ^ To je i mene zbunilo :? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 6, 2008 ...i dalje možeš kupiti akumulator sa ili bez održavanja... :cool Quote Share this post Link to post Share on other sites
the_reaper 2 Posted September 6, 2008 malopre uzeh vartu neku 470A 52Ah umesto 250A 50Ah starog :lool: upalio je, da li ce upaliti posle voznje, iskreno se nadam da hoce Quote Share this post Link to post Share on other sites
nidza 621 Posted September 6, 2008 RIP akumulatore. Nije ni predviđen večno da traje. Jesi li imao bilo kakve simptome pre toga, čisto da dignemo nivo ove teme na viši edukativni nivo? Quote Share this post Link to post Share on other sites
the_reaper 2 Posted September 7, 2008 shto je zanimljivo nisam, nikakve, sto mi i jeste bilo cudno :lool: Quote Share this post Link to post Share on other sites
chikavili 511 Posted September 7, 2008 Cest slucaj kod novijihautomobila/akumulatora kad umru - nema nikakvih indicija, samo odjednom popali sve lampice i nece vise da kresne. Quote Share this post Link to post Share on other sites
BaneT 0 Posted September 9, 2008 a što vartu??? Dosta ljudi (i autoelektričara) priča da je njesra.... Kolika je garancija? Quote Share this post Link to post Share on other sites
the_reaper 2 Posted September 9, 2008 od svega sto sam nasao, samo varta pravi tu debilnu dimenziju koja je meni trebala, garanciju cu pogledati nisam siguran Quote Share this post Link to post Share on other sites
BaneT 0 Posted September 9, 2008 kad kažaš dimenziju misliš na gabarite akumulatora? Šta malo mesta ima da se zbudži?živo me interesuje dal je samo godinu dana garancija... Quote Share this post Link to post Share on other sites
the_reaper 2 Posted September 9, 2008 o da, 21.5 x 17 ili tako neshto, garancija je 2 godine Quote Share this post Link to post Share on other sites
TOGO 0 Posted September 9, 2008 Da, da, samo varta http://www.andreja.co.yu/exide%20x-tra%20sr.htm Quote Share this post Link to post Share on other sites
Shicky 0 Posted September 9, 2008 Dakle potreban mi je nov akumulator za Brava 1.2 (kraći model,mislim da je 55ah),uzeo bih Vartu,pa ako možete da mi date adresu neke prodavnice gde ima povoljnije (cene se dosta razlikuju) ili da mi preporučite nekog drugog proizvođača.Hvala unapred na odgovorima! Quote Share this post Link to post Share on other sites
the_reaper 2 Posted September 9, 2008 ma da pa da zvekne posle mesec dana Quote Share this post Link to post Share on other sites
Shicky 0 Posted September 12, 2008 I ja imam isto EXIDE trenutno,od 45 ah,ali je počeo da kuva i pušta kiselinu,zato ga i menjam.Potražiću EXIDE u BG-u,pa ću uporediti cene sa npr Vartom.Hvala na odgovoru. Quote Share this post Link to post Share on other sites
boki 10 Posted September 13, 2008 ima li negde u Beogradu da se kupi? Quote Share this post Link to post Share on other sites
chila 0 Posted September 19, 2008 Ja danas kupio za mog palia 1.9D Vesna starter 75Ah za 60 eura,ali sam imao frku da ga ubacim. Akomulator koji sam imao je bio Black Horse od 55 Ah i bilo je jos nekih 2 do 2.5 cm prostora viska.Meni je nekako bilo malo 55Ah pogotovu posto ide zima i mislio sam da kupim od 66 Ah,ali duzina prelazi za nekih 2 cm preko onog nosaca,plus creva,plus kablovi,haos.Sve u svemu(posto su dimenzije od 66 i 75 iste ja kupim ovaj veci) upakujem ga ja nekako na jedvite jade i kad da zatvorim hubu,naslanja se na akomulator(preciznije na klemu) za nekih 2-3 mm,zatvara se ali se primecije. Moracu da potrazim neku drugu klemu jer se na nju kace jos neke zice i zavrtanj koji ih pricvrscuje za klemu je okrenut na gore tako da bas on udara u haubu! Quote Share this post Link to post Share on other sites
KA3AHOBA90 0 Posted September 26, 2008 ljudi pomagajte, jutros da upalim autokad ono cvrc ima kontakt ali nema dovoljnostruje da upali auto????Da ne znate mozda u cemu je problem,naime auto je stajao dva dana na parkingupa mi se desio problem sa osiguracima (nekima je poznato)pa je na blic provozan (vozio burazera u skolu)i jutros da upalim kad ono nece. poz. Quote Share this post Link to post Share on other sites
jboban 0 Posted September 26, 2008 Ako su kleme dobro postavljene i normalno stegnute, vreme je za novi akumulator... Quote Share this post Link to post Share on other sites
KA3AHOBA90 0 Posted September 28, 2008 Reseno!!!!! :lool: :lool: :lool: Bilo mu je potrebno malo punjenje,sad pali ko zmaj. hvala poz. Quote Share this post Link to post Share on other sites
chila 0 Posted September 28, 2008 Nemoj da ga palis par dana i desice se isti problem,akomulator ti je ri kraju! Odi kod auto elektricara nek ti ga ispita,ali za svaki slucaj spremi nekih 60 do 70 eura za novi akomulator :lool: Quote Share this post Link to post Share on other sites
